Calculate Kinetic Energy in Elastic and Non-Elastic Collisions
In a non-elastic collision involving two spheres of equal mass (0.3 kg), the first sphere collides with a stationary second sphere, resulting in speeds of 0.6 m/s and 1.1 m/s, respectively. The kinetic energy before and after the collision was calculated, revealing that 0.2 J of kinetic energy transformed into heat. The discussion highlights confusion regarding whether the collision is elastic or inelastic, with clarification that elastic collisions do not convert kinetic energy into heat. Participants confirm the calculations align with the principles of inelastic collisions. The conversation emphasizes the importance of correctly identifying the type of collision for accurate energy transformation analysis.
EPhoenix
NONElastic Collision
One sphere collides with other sphere that has speed of u2 = 0... Both spheres have same mass (m1 = m2 = 0.3 kg)... After collision first sphere has speed of v1 = 0.6 m/s, second sphere v2 = 1.1 m/s ... How much of kinetic energy has been transformed into heat
Ek= (m1 * u1 ^2) / 2
m1u1 + m2u2 = m1v1 + m2v2
from second formula i got u1 = 1.7 m/s
and after doing Ek = Ek1 + Ek2 + heat,
heat = Ek - Ek1 + Ek2
heat = 0.2 J
Can anybody confirm this...7
If the collision is elastic, as you say in the title, you don't need any more data to answer this question.
yeah i know... elastic collision do not transfer heat and stuff...
so it will be 0
BUT proffesor told my GF (she took that exam) that there is solution and it's not 0
dunno how, but I guess then he meant nonelastic but wrote elastic...
Here... I will edit it...
Well if the collision is inelastic, I get the same answer as you do, to 2 sig fig. As long as it isn't a trick question!
If it was for me, i wouldn't ask here... but this is girls be or not be exam...
Any more thoughts?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
