Calculate Max Lever Length for Toppling Block
9 replies · 4K views · last reply
Saints-94
Moderator note: Thread moved from technical forum so formatting template is missing
Hi, I have a block with a specified weight and a lever with a force at the other end. I was hoping someone could tell me what formula i need to work out the maximum length of lever before the block falls over.
  • Diagram of a rectangular block labelled 34.2kg, with a horizontal lever arm on top marked 570mm to the block's right edge and X beyond it, ending in a downward arrow labelled 530N.
Hi there. This homework ?
And: how come you don't worry about the height of the block ?
Thanks for your response.
Yes. Sorry, the height of the block is 1100mm.
Thank you for the response to the second question. Now how about the first one ?
Fair enough. Around what point (axis) will it rotate when it topples ?
Where does gravity act ?
Just before it topples, what is the equilibrium condition ?
The CoG of the block is in the centre of the block, and I assume the block will topple at the bottom right point?
I am unsure what formula to use to work out the equilibrium and toppling?
Isn't the aim of the project to find that out ?
No, this is additional work I wanted to include but needed some guidance on what formula to use. No worries if you can't assist, its not essential work.
