Calculate Moment of Inertia: Thin Rod, Length 3.14m, Mass 2.11kg
The moment of inertia for a uniform thin rod with a length of 3.14 m and mass of 2.11 kg, when calculated about an axis perpendicular to the rod and located 0.67 m from one end, utilizes the Parallel Axis Theorem. The formula applied is I = I(cm) + Mh², where I(cm) is calculated as 1/12 * M * L². Substituting the values, I(cm) equals 0.196 kg-m², and h is the distance from the center of mass to the new axis, which is 0.67 m - 1.57 m (the center of the rod), resulting in a total moment of inertia of 0.392 kg-m².
  • Understanding of moment of inertia concepts
  • Familiarity with the Parallel Axis Theorem
  • Basic knowledge of physics equations related to rotational motion
  • Ability to perform algebraic calculations with physical constants
  • Study the derivation and applications of the Parallel Axis Theorem
  • Learn about different shapes and their moment of inertia calculations
  • Explore rotational dynamics and its relation to linear motion
  • Investigate real-world applications of moment of inertia in engineering
Students in physics, mechanical engineers, and anyone involved in the study of rotational dynamics and moment of inertia calculations.
ViewtifulBeau
A uniform thin rod has a length 3.14 m and mass 2.11 kg. Find the moment of inertia in kg-m2 about an axis that is perpendicular to the rod and passes through the rod at a distance of 0.67 m from the end of the rod.
I know that if the axis was in the center of the rod the equation would be 1/12 * M *L^2 . M =mass L = length.
I don't know what to do with the axis being in a different place. is it the same eqation(doubt it) or the left half minus the right half or what?
Use the Parallel axis or Steiner's Theorem.
Have you heard of the Parallel Axis Theorem?
Did you learn about the parallel axis theorem?
hahahahaha
ECHO, Echo, echo! ;)
well thanks for the quick relpies, ummm yeah here in my book it is I = I(cm) +Mh^2
is I(cm) = 1/12 * M *L^2?
M is total mass
and h would be... distance from the center of mass?
This is true.
  • · Replies 21 ·
11K
