Calculate Temperature for White to Grey Tin Conversion | Thermodynamic Data
  • Thread starter Thread starter physicsss
The conversion temperature of white tin (Sn) to grey tin (Sn) can be calculated using Gibbs free energy principles. The reaction is thermodynamically spontaneous when the free energy equals zero, indicating the transition is possible. Although the kinetics of the conversion are slow, white tin is metastable at room temperature, gradually converting to grey tin over time. Reference materials such as "Mellor's Modern Inorganic Chemistry" provide additional insights into this phenomenon, known as "tin pest."
  • Understanding of Gibbs free energy and its application in thermodynamics
  • Familiarity with phase transitions and metastability concepts
  • Knowledge of the properties and allotropes of tin
  • Basic mathematical skills for calculating free energy changes
  • Research Gibbs free energy calculations for phase transitions
  • Study the kinetics of metastable phases in materials science
  • Explore case studies on tin pest and its historical implications
  • Investigate the thermodynamic properties of tin and its alloys
Materials engineers, chemists, and anyone interested in the thermodynamic properties of metals and their phase transitions.
physicsss
Based on thermodynamic data found in your textbook, calculate the temperature at which white tin will convert into grey tin.
I have no idea how to do this...what equation should I use?
Chemistry news on Phys.org
Ah, the "tin pest"... I don't know for sure how to do it, but I think you might have better luck in getting help if you ask the question in the materials engineering forum.
To me it sounds like one would need more than thermodynamic data. The phase might be metastable at certain temperatures, i.e. thermodynamically white tin should convert to grey tin, but the kinetics are not sufficient for the conversion.
Wow, I really wouldn't know how to tackle this one. Do notify us when you know more ;)
what's the reaction pertaining to this problem?
Gray Sn is an allotrope of Sn which is more stable than white Sn at lower temperatures. Actually, at room temp, white Sn is slowly turning into gray, though the process is extremely slow. There's a case I read about involving a old pipe-organ in Germany, which had pipes made of Sn that crumbled (became gray Sn) during a very cold winter day. Also, pewter, which is an alloy of Sn, should be protected from low temperatures. "Mellor's Modern Inorganic Chemistry" has info on this so-called "tin pest."
Interesting. Well, one general way to solve this problem is to use Gibb's free energy, find the temperature at which the reaction is spontaneous, when free energy equals 0. Zero indicates no overall reaction, while anything below indicates an overall reaction. You can either find the net free energy by subtracting the free energy of the reactant from the product.
Although there may be a more mathematically elegant way to do this.
OK, if the formulation "will convert to grey tin" should be interpreted as over time, maybe not even within some millennia, but it will happen, then the procedure sounds right and you need only thermodynamical data.
  • · Replies 16 ·
