Calculate the current in the coil
  • Thread starter Thread starter mba444
    Coil Current
15 replies · 17K views
mba444
A circular coil of 394 turns and area 0.78 m2
is in a uniform magnetic field of 0.8 T. The
maximum torque exerted on the coil by the
field is 0.0059 N · m.
Calculate the current in the coil. Answer in
units of A
torque= i*A*B
what i did is that i solved for the current using the above equation i= torque/(A*B) but i keep getting the wrong answer .. i think because of the number of turns but i don't know were to include it
i need ur help thanks in advance
Assume the 394 turns of wire are used to form
a single-turn coil with the same shape but
much larger area.
What is the current if the maximum torque
exerted on the coil by the field is 0.0059 N · m?
this a second part of the question but i really didnt understand the difference
You need to figure out the area of this larger coil. Hint: What's the length of the wire?
i tried to figure out the length where i came up with this equation but still i couldn't figure what to put for the F
length = F/(i*B)
im kind of lost
Figuring out the length of the wire is a geometry problem. You had a coil of a given area and number of turns. What was the circumference of that coil?
ok i did so know
1 loop = 2*pi*r (i just found)
394= X
so do i do the cross multiplication to solve for X which is the new area
mba444 said:
ok i did so know
394= X
Do this:
Use the area of the original coil to solve for the radius, using A = pi*r².
Use the radius to find the length of each loop, using the circumference formula.
Find the total length of the wire by multiplying the length of each loop by the number of loops.
That becomes your new circumference of your big coil. Work backwards to find, its radius then area.
ok thanks a lot i got it know .. sorry if i wasted your time
i got for the larger area = 121084 m^2
i plugged in this eqs i = (.0059)/(394*121084*0.8)
but i got the wrong answer =(
That looks OK.
When used to make the giant coil there's only one turn.
