Calculate the electostatic field outside a finite cylinder
The discussion focuses on calculating the electrostatic field outside a uniformly charged finite cylinder with radius R and length L. The primary interest is in determining the radial field E(r) at the plane z = L / 2. The user, Palaj, references the complexity of integrating potential V(r) using Legendre polynomials for the case where L is much smaller than R. Suggestions include using a multipole expansion of the potential and assembling a cylinder from multiple disks, which may simplify the integration process.
  • Understanding of electrostatics and electric fields
  • Familiarity with Legendre polynomials
  • Knowledge of multipole expansions in physics
  • Basic calculus for integration techniques
  • Research the application of Legendre polynomials in electrostatics
  • Study multipole expansion techniques for electric potential
  • Explore integration methods for complex functions in physics
  • Investigate the electric field calculations for charged disks and cylinders
Students and professionals in physics, particularly those specializing in electrostatics, as well as researchers working on problems involving electric fields around charged geometries.
Palaj
Hello,
I am looking for an expression to calculate the electrostatic field outside a uniformly charged cylinder, radius R and finite length L. What interests me most is the radial field, E(r) in the plane z = L / 2. I found an expression of the potential V (r) in the case where L <<< R which involves the Legendre polynomials, but the integration is difficult. This particular case (L tends to 0) is sufficient.
Any help to move me forward would be very appreciated!
Thank you in advance for this help,
Palaj
There was a recent discussion about the E(r) in the plane of a charged ring. The integrals involved were complicated enough. Your question seems to be even more complicated because one way to proceed after solving the ring problem is to assemble a disk from many rings and then a cylinder from many disks. You might also try a multipole expansion of the potential and then take derivatives.
https://www.physicsforums.com/threa...-of-a-ring-of-charge-in-the-x-y-plane.950299/
Hello,
I will try to use this informations to solve my problem. A big thanks !
Palaj
