Calculate the minimum uncertainty
5 replies · 9K views · last reply
Kaspar
Hello,
can anybody help me with solving the problem.
:[/B]
Calculate minimum uncertainty?
A horizontal beam of laser light of wavelength 604 nm passes through a narrow slit that has width 0.0600 mm . The intensity of the light is measured on a vertical screen that is 2.40 m from the slit.
a.) What is the minimum uncertainty in the vertical component of the momentum of each photon in the beam after the photon has passed through the slit?
∆p_y=?
b.)Use the result of part A to estimate the width of the central diffraction maximum that is observed on the screen.
d=?
and
[/B][/B]
a.) I tried using this equation and I got for ∆p_y=0.02416m
But it was wrong. :frown:
See in picture.
Can anybody help me?
Thank you.
M
Handwritten inequality: delta p_y is greater than or equal to p_x times lambda over a, with lambda/a written as a fraction.
Mathematica session: a = 0.06*10^-3; λ = 604*10^-9; x = 2.4; then x * λ/a evaluated to 0.02416.
  • Mathematica session: a = 0.06*10^-3; λ = 604*10^-9; x = 2.4; then x * λ/a evaluated to 0.02416.
  • Handwritten inequality: delta p_y is greater than or equal to p_x times lambda over a, with lambda/a written as a fraction.
Hello Kaspar, :welcome:
I suppose you tried ##\Delta p_y = p_x{\lambda\over a}## ? Where does that come from ? And for ##p_x## you use the distance to the screen ?
I got for ∆p_y=0.02416 m
A ##\Delta p## with the dimension of m ?
In what context is this exercise ? Does the textbook mention uncertainty somewhere ?
BvU said:
Hello Kaspar,
Hi BvU, thanks for your reply. The equation comes from the textbook "University of Physics - Modern physics" by Zemansky (https://drive.google.com/drive/folders/13rAnc_ryXgKa3YQOXms2AGnbpFvqeXXd , book page 1268)
In what context is this exercise? Does the textbook mention uncertainty somewhere ?
Yes its the chapter "38.4 WAVE–PARTICLE DUALITY, PROBABILITY, AND UNCERTAINTY"
But I still don't know how to calculate: ##\Delta p_y##
Dimension should be kg*m/s .
Ok, but the story continues on the next page !
BvU said:
And for pxpxp_x you use the distance to the screen ?
The distance to the screen cannot be relevant for part a). Isn't it just a matter of ΔyΔpy≥ etc?
You are right.
I solved my problem. Here you can see. Thank you.
Mathematica notebook cell showing a = 0.06*10^-3, lambda = 604*10^-9, R = 2.4, then Part A: p_y = h/(4 pi a) = 8.78801e-31, Part B: p_x = h/lambda = 1.09702e-27, and d = Tan[p_y/p_x]*R = 0.00192259.
  • Mathematica notebook cell showing a = 0.06*10^-3, lambda = 604*10^-9, R = 2.4, then Part A: p_y = h/(4 pi a) = 8.78801e-31, Part B: p_x = h/lambda = 1.09702e-27, and d = Tan[p_y/p_x]*R = 0.00192259.
