Calculate the recoil momentum and kinetic energy of the atom
The problem involves an iron atom at rest that emits an X-ray photon with an energy of 6.4 keV. Participants are tasked with calculating the recoil momentum and kinetic energy of the atom, while considering whether classical or relativistic mechanics should be applied.
  • Participants discuss the relationship between the energy of the emitted photon and the momentum of the atom, with some attempting to derive the atom's velocity from its momentum. Others express confusion about the relevance of energy in the context of momentum calculations.
The discussion is ongoing, with participants exploring various interpretations of the problem. Some have provided hints and guidance regarding the use of classical mechanics and the importance of unit conversions. There is a recognition of the need to clarify the relationship between momentum and kinetic energy.
Participants are grappling with the implications of using classical versus relativistic mechanics, and there are indications of uncertainty regarding the necessary conversions and calculations involved in determining the atom's velocity and recoil energy.
tauristar
Suppose an atom of iron at rest emits an X-ray photon of energy 6.4 keV. Calculate the “recoil” momentum and kinetic energy of the atom. (Hint: Do you expect to need classical or relativistic kinetic energy for the atom? Is the kinetic energy likely to be much smaller than the atom’s rest energy?)
Where E is the energy of the photon (in this case 6.4 KeV), Ei is the initial energy of the atom (I believe it is zero), Ef is the final energy of the atom and K is the "recoil" kinetic energy of the atom.
E = (Ei − Ef) − K
Since the atom starts at rest Ei =0 and so I get
6.4 Kev=(0-Ef)-K
6.4 Kev = -Ef-K
Not sure where to go from here
Hint: Read the question. The problem starts with asking about the momentum.
I tried going that route using P=E/c so P=6.4 kev/c now what...?
So you know the momentum of the atom. Why not try to calculate its velocity?
Not sure what to use. pc/E=v/c --> v=pc^2/E so then v= (6.4 kev/c)c^2/(6.4 kev) --> v=c I feel like I'm going around in circles I have no clue what to do and I've been working on this for two days I just don't get this stuff. I feel like I'm missing a big piece of the puzzle and I just don't know where to find it.
I repeat my hint: read the question. Consider classical mechanics.
classical mechanics Ki+Ui=Kf-Uf so (1/2) m vi^2 + mgyi = (1/2) m vf^2 + mgyf
initial Ki=0 the Ui and Uf are zero so that doesn't leave me with anything useful
Ok, go back one step: you know the momentum of the atom. Why not calculate its velocity? (That is what I wrote in message #4.)
I got v=c
You are overthinking this. Forget energy. What is the momentum of a particle in classical mechanics?
p=mv
if I plug in what i found for p then I get v= 6.88e28 eV/kg
6.4 keV = 9.3E-26 kg v
v= (6.4 keV)/(9.3E-26 kg) = 6.88E28 ev/kg
6.4 keV is not the momentum.
I thought it was p=E/c and E (energy of the photon) is 6.4 keV which would give me p=6.4 keV/c
So convert to SI units. Or imperial, or whatever you prefer.
(6400 eV/c)(c/1eV)(5.34e-28 kg m/s)= 3.42e-24 kg m /s
Correct. I usually let Google handle unit conversions: https://www.google.se/webhp?q=6400+eV/c+=
Now what is the velocity of the iron atom?
You know p=mv.
You know p=3.42e-24 kg m /s
You know m.
What is v?
so the velocity is (3.42e-24 kg m /s)(1/9.27e-27)= 36.7 m/s
I know i close but not sure how to finish it off
oh i just need to convert!
Correct.
Now you can calculate the recoil energy as you have mass and velocity.
You can edit your posts if you want to add something.
  • · Replies 38 ·
  • · Replies 54 ·
10K
  • · Replies 30 ·
