Calculate the resulatant downward force of a submarine on the seafloor
  • Thread starter Thread starter Richie Smash
    Force Submarine
The discussion revolves around a physics problem involving a submarine submerged 325 meters deep in seawater. The problem includes calculating the upthrust acting on the submarine, the resultant downward force on the seafloor, and the mass of water that needs to be expelled from the submarine's ballast for it to float. Key parameters include the density of seawater, the volume of the submarine, and its mass.
  • Mixed
  • Participants explore the calculation of upthrust using fluid density, gravity, and volume, with one participant arriving at a value of 2300N. There is discussion about the resultant downward force, considering the weight of the submarine and the normal force from the seafloor. Some participants question the implications of a net downward force of 700N and whether the problem setup makes sense.
Participants are actively engaging with the problem, raising questions about the assumptions and calculations involved. Some express confusion regarding the net forces and the implications of the submarine's buoyancy. There is no explicit consensus, but some guidance has been offered regarding the interpretation of forces acting on the submarine.
Participants note potential issues with the problem's parameters, such as the volume of the submarine and the mass of water to be expelled. There is mention of a lack of an answer key and uncertainty about the problem's clarity, suggesting that further clarification may be needed.
Richie Smash
Hi I have uploaded a picture of a pressure question.
It says that there is a submarine 325 m deep, with the sea water of density 1150Kg m-3 and acceleration of gravity 10m/s and the volume of the submarine is 0.2m3 with mass 480Kg
They first ask for the upthrust.
Then they say the normal force of the sea floor against the submarine is 1800N, what is the resultant downward force?
Then they ask what mass of water must be emptied from the ballasts for the submarine to float?
Pressure =pgh
Upthrust = m(fluid disaplaced) *g
I know that Upthrust is equal to the density of the fluid times gravity times the volume of the object.
Thus I have worked out the upthrust on the submarine to be 2300N.
Now they ask for the resultant force.
Normally I would think it would be 1800 as well, but I realized there are more force acting downwards, the first being the weight of the submarine itself, which is 4800N, now i must subtract the upthrust from this to find the remaining downard force I believe, so I would get 2500N is what is remaining acting in the downwards direction.
So I have 1800 going upwards from the seafloor, and 2500 going downwards from the submarine, would the resultant force be 700N?
But then I have to remember the pressure of the sea acting on the submarine itself which is 375 m* g*p(of the water)
I feel I'm somewhere alng the correct lines.
Pressure =pgh
Regarding "pressure of the sea acting on the submarine itself", you don't have to consider that as it is already considered in the upthrust itself: it's the pressure difference of the water at different heights.
Generally it looks sound. Although I find it kind of weird that there's still a net 700N that's pushing onto the sea floor as though the sea floor can be pushed down.
So you're saying what I've speculated seems correct?
Yes. I just woke up so I'll take a closer look later when I'm more sane lol. Or wait for someone else to come along to confirm / reject
so would that be 250 KG of water required for the submarine to float yes?
Yep, that is right :)
It's worse than that. It implies the sub is accelerating downward at 700/480=1.46m/s2.
The net force is surely 0.
The question as posed makes no sense. You can either ignore the 1800N information and arrive at 250kg, or ignore the .2m3 and get 1800N/g = 180kg.
I note that if 250kg of ballast can be expelled then it occupies a volume greater than the sub itself, so I suggest the 0.2m3 is suspect. Perhaps one needs to pay attention to the number of significant figures, i.e. it is anything < .25m3.
I did wonder if the mass given for the sub excludes the contents of its ballast tanks, but that makes matters worse.
Okay so I wasn't mad to think the 700N was off phew
@Richie Smash Where did you get this question? Do you have a source?
Yes its from CXC examinations past papers January 2007 paper 3, but I doubt you'll find that online, I got it emailed from a teacher.. so My asnwer is wrong then?
Considering stuff is kinda weird here... I suggest you either look at the answer key if you have one to find out what they're trying to say, or follow @haruspex advice. Alternatively, you might want to do other similar questions instead.
Umm, there's no answer key, I'll have class ina few hours where the answer will be revealed, so I will let you guys know tonight
Ok Actually, He didn't review this paper in class yesterday, He's actually doing it next thursday, so I'll find out and see
17K
  • · Replies 18 ·
9K
