Calculate the speed with which the ball hits the ground
  • Thread starter Thread starter discombobulated
    Ball Ground Speed
The discussion focuses on calculating the speed at which a ball hits the ground after being thrown vertically upwards with an initial speed of 10 m/s from a height of 2 meters. The relevant equations of motion used include s = ut + 1/2 at² for displacement and v² = u² + 2as for final velocity. The correct displacement for calculating the speed upon hitting the ground is 2 meters, leading to a final speed of 11.8 m/s. The time the ball remains 3 meters or more above the ground is calculated to be 1.82 seconds.
  • Understanding of kinematic equations in physics
  • Familiarity with concepts of displacement, velocity, and acceleration
  • Knowledge of gravitational acceleration (g = -9.8 m/s²)
  • Ability to solve quadratic equations
  • Study the application of kinematic equations in vertical motion problems
  • Learn how to derive and apply the quadratic formula in physics contexts
  • Explore the concept of projectile motion and its equations
  • Investigate the effects of air resistance on falling objects
Students studying introductory physics, educators teaching mechanics, and anyone interested in understanding the principles of motion and acceleration in vertical trajectories.
discombobulated
I need some help with this mechanics question please,
A ball is thrown vertically upwards with speed 10ms/s from a point 2m above horizontal ground.
a) calculate the length of time for which the ball is 3m or more above the ground.
b) calculate the speed with which the ball hits the ground.
so..i think i have to use the equation s=ut + 1/2 at2
u= 10
a= -9.8
but I'm confused about s, should it be 2m or 3m?
discombobulated, this is an Introductory Physics kind of problem, not a Precalculus Mathematics one. :)
That's neither 2m nor 3m.
s=ut + 1/2 at2
This equation will return the displacement the object has travelled.
The u is the initial velocity of that object, t is the time the objevt has spent travelling, a is its acceleration.
Now, if the ball goes from 2m above the ground to 3m above the ground. What's its displacement? What's s?
Having s, u, a, you'll be able to find t, right?
From there, do you know how long does the ball is 3m or more above the ground?
Can you go from here?
Can you do part b?
Thanks, so s=1 then I worked out t = 1.82 by using the quadratic equation to solve and finding the difference.
I think i need to use v2 =u2+2as for part b, but which value of s should i use?
I tried 2m but then i got v=6.26 whichis wong as the correct answer is 11.8.
The answer you got for a looks good. But don't forget to add the measure unit to t, it should read: t = 1.82 s, not just t = 1.82.
No s is not 2. Let's think about it. You choose a = g = -9.8 m / s2, which means the positive y is upward.
So from 2m above the ground, the ball flies up, reaches its highest point, then falls back down and finally reaches the ground. So from 2m above the ground, the ball finally reaches the ground, what's the displacement, is it positive 2m? Or what is it?
Can you go from here? :)
  • · Replies 38 ·
  • · Replies 17 ·
