Calculate Volume of Bubble at Surface from Pressure & Temperature: Panama City
  • Thread starter Thread starter Rasine
    Pressure
The discussion revolves around calculating the volume of an air bubble released by a scuba diver at a depth of 43.0 m in seawater, considering changes in pressure and temperature as it rises to the surface. The specific gravity of seawater is also mentioned, and the problem involves understanding the relationships between pressure, volume, and temperature in the context of gas laws.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of the ideal gas law and the need to correctly calculate pressure at depth using the specific gravity of seawater. There are questions about unit conversions and the correct values to use in calculations.
Participants are actively engaged in troubleshooting their calculations, with some providing corrections and clarifications regarding the use of units and the formula. There is a recognition of the need to include atmospheric pressure in calculations, and some participants express confusion about the results they are obtaining.
There is an emphasis on ensuring that all values are in consistent units, and participants are navigating the complexities of applying the ideal gas law under varying conditions. The original poster mentions using a homework program that is not accepting their answers, indicating potential discrepancies in their calculations.
Rasine
A scuba diver at a depth of 43.0 m below the surface of the sea off the shores of Panama City, where the temperature is 4.0°C, releases an air bubble with volume 17.0 cm3. The bubble rises to the surface where the temperature is 19.0°C. What is the volume of the bubble immediately before it breaks the surface? The specific gravity for seawater is 1.025.
so (p1v1/t1)=(p2v2/t2)
v2=v1(p1/p2)(t2/t1)
p1=101 kPa+ (roe)gh where roe is 1.025 x10^3 Kpa
what is g here?
and i am not sure what units this all should be in
this is what i did...
v2=.17m^3(44176kPa/101kpa)(292.15K/277.15K)
should .17m be in 17 cm^3 or what and what about he kPa can it stay that way
i am confused
The units in this case are easy. In v2=v1(p1/p2)(t2/t1), you can see that the units of pressure and temperature simply cancel and the units of v2 are the same as v1. So just put v1=17cm^3. BTW 17cm^3 is NOT the same as .17m^3!
i still get the wrong answer
And in rho*g*h, rho is not a pressure, it's the density of the water. And g is the acceleration of gravity.
some one please tell me what values i have wrong
44176kPa is dead wrong. Try doing g*rho*h again.
ok so (1.025x10^3)(9.8)(43)=431935 ...is that right
Yes. But remember that it's in Pa not kPa. Convert to kPa before taking the ratio.
ok ok let me try
so now for the entire equation i am getting 7.66 cm^3 but that is wrong
What is the 'entire equation'? The decrease in pressure and the increase in temperature should both cause it to expand.
v2=v1(p1/p2)(t2/t1)
v2=17cm^3(431935kPa/101kpa)(292.15K/277.15K) and for this i am getting 7.66 cm^3
Make that 431.935kPa (I TOLD you). And how can v2 be less than 17 if both ratios are larger than 1!
ok so now that i corrected 431935 to 431.935 i get 76.64 which is not right
Ok, I'll bite. What is the right answer?
i don't know
i am putting this into a homework program and it keeps saying that my answer is not right
Ah. You didn't add atmospheric pressure to p1 like you did last time. p1=101 kPa+ (roe)gh.
i am putting the values that i get into a homework program online and it keeps saying that it is wrong...and it won't say what the right answer is
ok ok let me try
i get 94.56 cm^3...but i ran out of ties
Sorry to hear you ran out of time. But the answer is correct.
thank anyways but now i know how to do it
