Calculating Area of a 396ft Tall Wall for 100,000 People
  • Context: High School
  • Thread starter Thread starter Takeio
    Plots
The discussion revolves around calculating the radius of a circular wall that is 396 feet tall, intended to hold approximately 100,000 people. Participants explore the volume and area required for this scenario, considering different assumptions about how people are arranged within the wall.
  • One participant proposes calculating the total volume of 100,000 people based on an assumed volume of 6 cubic feet per person, leading to a total volume of 600,000 cubic feet.
  • Another participant calculates the radius of the wall using the formula for the volume of a cylinder, arriving at a radius of approximately 22 feet.
  • A different participant expresses concern about the feasibility of fitting 100,000 people within a 22-foot radius, suggesting it seems problematic.
  • Further clarification is provided regarding the arrangement of people, with one participant emphasizing that the calculation should consider people standing side by side rather than stacked.
  • Another participant suggests that if people are standing shoulder to shoulder, the area each person occupies is 4 square feet, leading to a new calculation for the radius of 357 feet.
Participants express differing views on the assumptions regarding how people are arranged within the wall, leading to multiple competing calculations for the radius. The discussion remains unresolved with no consensus on the correct approach.
Participants note the importance of distinguishing between mass and volume, and the implications of how people are positioned (standing vs. stacked) on the calculations. There is also mention of the need for a diagram to clarify the scenario.
Takeio
Hey I am a new guy here...and I am trying to do research for a story of mine...i am trying to figure out the radius of a 396 foot tall wall, (flat on the inside) in the shape of a circle that can hold approx. 100 000 people...and in order to do that...i need to figure out the approximate mass of a human being, having rough measurements of 6 x .5 x 2 feet...can anyone help me figure it out?
im a bit stumped on it...i already know how to figure out the diameter from the total mass/ volume...in just trying to figure out the total volume based upon the standard human mass, multiplied by the height of the wall and by 100 000 (people)
:bugeye:
Mathematics news on Phys.org
First you calculate the total volume of the bodies (assuming 6ft x .5ft x 2ft), which is 6ft^3 per person. 600,000ft^3 total.
We know this is the total volume for the bodies, thus the total volume of the silo.
We know that the volume of a cylinder is equal to the radius squared times the height times pi.
V=pi*r^2*h
We know V, pi, and h. Just solve for r.
600,000ft^3 = pi * r^2 * 396ft
r^2 = 482.3ft^2
r ~ 22ft.
A 22 ft radius.
a 22 ft raduis to fit in 100 000 people with the approximate mass of 6 feet cubed...?
I find this to be a little bit...problematic... :frown:
:bugeye:
Please note that mass and volume are completely different physical quantities. Also, there is the question of packing human beings. I don't understand what you mean by a circular wall that is flat on the inside. Please provide a diagram.
What's problematic about that? This means that the silo is 44ft wide and almost 400ft high. I think that's a reasonable size.
Well... I assumed that these bodies are going to be stacked and densely as possible. Are these dead bodies in this silo or did you want to know the size if people were only standing on the ground? If so, then the height of the people would be irrelevant.
okay..i was trying to specify...but it seems i failed to do that...i can't provide a diagram at the moment...but the people...would be standing...and to fit 100 000 people from where they are standing...not piled up on each other...
in their view...they are surrounded by a wall that's 396 feet high... no piling of any sorts. if they were all standing, side by side...shoulder to shoulder...(from the head...2 feet apart in all directions)...so i guess to multiply their height to the height of the wall would be the proper thing to do as well then...ack~
i'm really trying hard to describe what it is I am trying to figure out...but my words are noo good at all...ill try to create a diagram to better explain what it is I am trying to figure out...
So what I'm envisioning is a large circular wall. People standing, filling in this circle so that the center of their bodies are 2 ft away in each direction. This would mean that their shoulders are touching, and there is about 1 ft between each line of people.
We can do this by saying that the total area each person takes up is 2ft * 2ft = 4 sq ft.
Now, because the people are standing, the height of the people and the height of the wall is irrelevant.
A = 4 sqft * 100,000 people
A = 400,000 sq ft
A = pi * r^2
400,000 sq ft = pi * r^2
r = 357ft
So the wall would have a radius of 357 ft, or a diameter of twice that, 714 ft.
ahhhh...thank you...i was in the middle of making a diagram...because i thought i wasnt being clear enough (im not very good with communicating my thoughts aloud...)
  • · Replies 20 ·
11K
