Calculating Desired Length for Capacitor with Specific Capacitance
17 replies · 4K views
Apprentice123
A capacitor is constructed commercial wrap two sheets of aluminum separated by two sheets of paper coated with paraffin. Each aluminum foil and paper has width of 7cm. A sheet of aluminum has 4x10^{-6}m and thickness of paper is thick 25x10^{-6}m and a dielectric constant of 3,70. What is the length that the leaves should be desired is the capacitance of 0.95 pF? (Capacitor as the parallel plates)
Seems like you might need an equation which relates plate area, separation and dielectric constant to the total capacitance, yes? And, of course, some super-basic geometry.
Yes. But what equations ?
Presumably for your coursework, you have covered these. There is only one which applies here. See if you can't figure it out and post it here; I'll tell you if you have the correct equation. Then, you can take the next step.
C = (E. * A) / (d) With dielectric C = (E. * A * k) / (d)
How do I find the area?
In your equation above, A is the area, specifically, the area of overlap between the two plates (which in your problem is the area of either plate since it's implicitly assumed they overlap completely) and it is stated is square meters. C, of course, is the capacitance in Farads, E is the permitivitty of free space (8.854x10^-12 F/m ), k is your dielectric constant and d is the separation between the two plates (in meters). Now, apply your algebra to isolate A on one side of the equation.
A is length of the leaves X width ? What is the value of d?
Yes, exactly. And since the width is known, the rest is easy
What do you think the value of d is? What must determine that value in the problem setup?
d is thickness of the paper X thickness of aluminum foil ?
You're getting there. Since charge collection is a surface phenomenon only, the separation distance need only concern itself with the inner surfaces of the plates. It's how far apart these surfaces are that matters.
And remember to keep in mind how many layers of paper are being called for here.
Yes. d is is (thickness of the paper X thickness of aluminum foil) / 4. Why have 2 thickness of the paper and 2 thickness of aluminum. Correct ?
No, there is a reason the problem does not specify the thickness of the foil.
I do not understand what is d in formula.
I find:
C = (E * x * y * k)/d
C * d = E * x * y * k
x = (C * d) / (E * y * k)
x = 1,036x10^{-5}m
It is correct ?
Almost, but you're forgetting to take into account the number of layers of paper. Your answer is correct for a single layer of the stated paper.
How so? Why do I have two sheets the distance is 50x10^{-6} and not 25x10^{-6} ?
I'm pretty sure the problem as stated gives the thickness of one sheet of paper and specifies that two such sheets are used. Is that not the case? You're in a better position than I to definitively answer that, as I don't have (and probably couldn't read) the problem in its original language.
To be clear, if the problem gives the total thickness of the two sheets of paper, your answer is correct; if it gives only the thickness of one you obviously must multiply by 2.
Yes thank you. If possible, I am very grateful if you help me in other problems. Thanks
