Calculating Dim(ran(T) & Dim(Ker(T)
  • Context: Undergrad
  • Thread starter Thread starter squenshl
The discussion focuses on calculating the dimensions of the range and kernel of a linear transformation T, specifically when T is one-to-one and onto. According to the rank-nullity theorem, for a linear transformation from a vector space of dimension n to a vector space of dimension m, the equation dim(Ran(T)) + dim(Ker(T)) = n holds true. When T is one-to-one, it follows that dim(Ker(T)) equals 0, while if T is onto, dim(Ran(T)) equals m. The terms "rank" and "nullity" are also defined in this context.
  • Understanding of linear transformations
  • Familiarity with vector spaces
  • Knowledge of the rank-nullity theorem
  • Basic concepts of isomorphisms
  • Study the rank-nullity theorem in detail
  • Explore examples of one-to-one and onto linear transformations
  • Learn about isomorphisms in linear algebra
  • Investigate the implications of kernel and range in vector spaces
Students and professionals in mathematics, particularly those studying linear algebra, as well as educators teaching concepts related to linear transformations and vector spaces.
squenshl
I have a problem.
Calculate Dim(Ran(T)) if T is 1-to-1. Also calculate Dim(Ker(T)) if T is onto.
How do you think I should do this?
There is nothing to calculate. You just need to think about it. A 1-1 map is an isomorphism onto its image for example - plus there are the standard results like the rank nullity theorem to help you.
If T is a linear transformation from a vector space of dimension n to a vector space of dimension m, then dim(Ran(T))+ dim(Kernel(T))= n. That's the "rank-nullity" theorem matt grime mentioned. If T is "one-to-one", then it maps only the 0 vector to the 0 vector so dim(Kernel(T))= ? If T is "onto" what is dim(Ran(T)).
dim(Ran(T)) is also called the "rank" of T and dim(Kernel(T)) is the "nullity" of T.
  • · Replies 24 ·
