The discussion revolves around calculating drag in a physics experiment involving a square open-sided cube dropped through a vertical distance. The original poster is attempting to understand the relationship between drag, velocity, and displacement, particularly in the context of reaching terminal velocity.
- Exploratory, Assumption checking, Problem interpretation
- Participants discuss the need for instantaneous velocity to calculate drag and the circular reference issue that arises when trying to find displacement without knowing velocity. There are attempts to apply kinematic equations to find velocity and questions about the implications of negative values in calculations.
The discussion is ongoing, with participants exploring different interpretations of the equations involved. Some have provided calculations and insights into the relationship between forces acting on the cube, while others are questioning the assumptions made in the calculations.
Participants note the specific parameters of the experiment, including the dimensions of the cube, its mass, and the conditions under which the drag is being calculated. There is an acknowledgment of the potential for reaching terminal velocity and the implications of the calculations leading to negative values.
