Calculating Electrostatic Potential for a Uniformly Charged Sphere
  • Thread starter Thread starter Fazza3_uae
    Potential
10 replies · 3K views · last reply
Fazza3_uae
How To Find Potential ??
Consider the uniformly charged sphere with
radius R = 4.65461 m,
Q = 6.66731 μC is the
total charge
inside the
sphere.
a) Find the total flux passing through the
Gaussian surface (a spherical shell) with ra-
dius 2.08762 m.
b) Find the electric field at radius r =
2.08762 m.
c) Find the value of the electrostatic potential
at the same radius r = 2.08762 m.
E=kq/r^2
v=kq/r
I have answered Parts A & B , I got for part A : Total Flux = (Q/Epsilon)*(r/R)^3
& for part B : E = kQr/R^3 , But part C have stopped me so any hint or clue will be gratefull and thanks in advance.
Welcome to PF!
Hi Fazza3_uae! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
[STRIKE](But isn't the total flux independent of radius?)
[/STRIKE]
What definition do you know for electric potential?
Hi Tiny-Tim! Thx 4 Welcoming ^^
Please check my steps of solving this part & tell me if i made a mistake :
[tex]\phi=\int\vec{E}.d\vec{A}[/tex]
= Int(EdACos[theta]) = Int(EdA) = EA
E : Electric Field inside a uniform sphere of charge = KQr/R3
A : Area of the spherical Shell of radius r = 4*Pi*r2
Inserting these Values we get :
[tex]\phi=[/tex] (Q/epsilon)(r/R)3
As far as i knew from the lectures the electric potential is the potential energy divided by the charge of a point in space.I also do know that Difference in potential is the same as Flux.
If i understood it wrongly please correct it for me & let me know & it will be appreciated. ^^
Hi Fazza3_uae! :smile:
(have a pi: π and an epsilon: ε :wink:)
oops! ignore that … I misread the numbers. :redface:
No …
i] when we say "potential", we always mean the difference in potential anyway (and the same for "potential energy")
ii] Flux is the integral of a vector across a surface.
(In particular, there is no such thing as flux "at a point".)
So electric flux is the integral of the electric field (E) across a surface.
(Read http://en.wikipedia.org/wiki/Flux#Flux_definition_and_theorems_2" :smile:)
So the way you answer a) (the flux) is simply by measuring the charge inside the surface, and dividing by ε0 …
then you answer b) (the field) by using your formula flux = EA.
It would be more accurate to say that electric potential = potential energy per charge.
But for c) you need an equation for the potential (or for the potential energy) … what equation do you know? :smile:
Hi again sir ^.*
Thx a lot for the information and corection that U've posted & I appreciate your help to me Sir.
Part C ) MmmMmmm... I actually know an equation for potential which is V=kq/r but I tried it and got wrong answer. I've tried for r once and for R once & still got wrong answer.
I doubt if there is another formula of potential that is related to the Formula I got in part B. I mean it could be like this : V=kqr/R
I know that My doubt is Maybe 1% correct but still a try. I can't check if this new equation is right or not because I have tried to put an answer twice in the website & still one chance to insert my last answer otherwise i'll get Zero in this part.
Thank you again sir. ^^
( Please Excuse Me If My English Is So Bad, I will Try To Improve It )
oh i see … you used v for the potential.
Yes, if E = kq/r2, then E = -gradU, so U (or v) = -kq/r. :smile:
You said if E=kq/r², then E=-gradU , What do u mean by (gradU) & why it is minus ?
and here we have E=kqr/R³, so what V must equal now??
If you haven't done grad, then just read it as (d/dr) … so E = -dV/dr.
And it's minus because that's how the potential is defined.
(For example, the field outside the sphere is K/r2, and the potential is -K/r, so that the potential is 0 at r = ∞ :wink:)
oh, I forgot that E=kqr/R³ … ok, then dV/dr = -kqr/R³, so V = … ? :smile:
Yup , Finally I got right answer Thx a lot Sir.
& thanks also for the clarification about grad ^^ Appreciate it.
May God Bless You Sir.
thanks …
but no need to call me Sir …
i'm only a little goldfish! :smile:​
