Calculating Final Velocity Using Force-Displacement Graph
12 replies · 12K views · last reply
df102015
If the following Force v. Displacement graph is for a 9.9kg object and it's initial velocity is 28.6 m/s the what is its velocity at 30 m?
Line graph titled Force vs Displacement: force in N on the vertical axis (0 to 120) against displacement in m on the horizontal axis (0 to 30). Force holds at 100 N from 0 to 20 m, then falls linearly to 0 N at 30 m, with a dashed vertical line at 20 m.
I am not certain that i am even using the right equations with this but:
W = fd
KE = 1/2mv(final)^2 - 1/2mv(initial)^2
I thought since W=Fd and work is proportional to kinetic energy, which is
KE=1/2mv(final)^2 - 1/2mv(initial)^2 and i then could substitute in the Fd, making the new equation:
Fd = 1/2mv(final)^2 - 1/2mv(initial)^2
This could then be rearranged to find final velocity:
sqrt { (Fd + 1/2mv(initial)^2) / 1/2m } = v(final)
Only the issue is that i do not know which F to use to find the final velocity at d=30meters. Because if i use the 0 the whole Fd cancels out, and i get the wrong answer. But if i use 100 then it comes out as larger than the initial velocity, which is not possible as it is losing speed due to lack of force after 20 meters.
Actually work done is a scalar product of force and displacement vector and the amount of work done is sored with the body as kinetic energy so calculate the work done from the graph and use it to find the final velocity.
thanks, haha so i was way off, isn't work then supposed to be the area under the line on the graph?
Line graph titled Force vs Displacement: force in N is 100 from 0 to 20 m displacement, then falls linearly to 0 N at 30 m, with a dashed vertical line at 20 m.
W = fd
As the force changes over time, The best way to find the work in graphs is by getting the area
Line graph titled Force vs Displacement, with Force (N) from 0 to 120 on the vertical axis and Displacement (m) from 0 to 30 on the horizontal axis. A solid blue line stays flat at 100 N from 0 to 20 m, then falls linearly to 0 N at 30 m. Red curves show several separate force-displacement traces, drawn between roughly 0 and 27 m.
You have a triangle and a rectangle. Find the area and sum it up. You will end you will the the work done
in the graph the value of force and displacement is given so calculate the work done
Graph titled Force vs Displacement: a horizontal blue line at 100 N from 0 to 20 m, then a straight blue line falling from 100 N at 20 m to 0 N at 30 m, with dashed vertical line at 20 m; red curved segments show other force-displacement traces.
And do i use the numbers of the x and y axes to find area? in this case the rectangle being 100x20 and the triangle as 1/2x100x10 ?
i keep getting an answer larger than the initial velocity of 28.6, is that at all possible?
Graph titled Force vs Displacement with Force (N) on the vertical axis from 0 to 120 and Displacement (m) on the horizontal axis from 0 to 30. A solid blue line holds at 100 N from 0 to 20 m, then falls linearly to 0 N at 30 m. Red curved segments lie at various force levels between 0 and 20 m, with a dashed vertical line at 20 m.
I got 2500 for the work, is that correct?
I haven't calculated the velocity but it should be larger than the initial. Work is adding energy to the system. You add more energy this energy will be kinetic. While the mass and 0.5 obviously don't change then the only thing that will change is the velocity.
and the work is 2500 right :D
So yes it should be larger.
Yes. So, show us your detailed calculations for getting the final velocity. Incidentally, what are the units.
W = 1/2mv(final)^2 - 1/2mv(initial)^2
2500 = (0.5 x 9.9 x V^2) - (0.5 x 9.9 x 28.6^2)
2500 = 4.95V^2 - 4048.9
6548.9 = 4.95V^2
1323.0 = V^2
36.4 = v(final)
Units:
W is in Joules
Mass is in kilograms
Velocity is in meters per second
Displacement is in meters
Force is in Newtons
Chestermiller said:
I didn't check your arithmetic, but your approach looks OK.
Thank you, i got the right answer, just checked it! (:
