Calculating Fluid Density: Beyond the Formula
  • Context: High School
  • Thread starter Thread starter mmg0789
    Density Fluid Formula
3 replies · 4K views
mmg0789
are there different ways to calculate fluid density?
i know there's a formula using temperature and salinity but are there other ways?
Thanks in Advance
Well salinity would apply to solvent which dissolve salt, e.g. water.
Density is mass per unit volume, so the basic method would be to measure mass and volume from which one would calculate density. Density can be 'correlated' with temperature. Temperature affects volume by virtue of thermal expansion - and volume could be measure by displacement of a calibrated volume, e.g. column of liquid with fixed cross-sectional area in a graduated cylinder.
Adding salt may increase the volume slightly, but the mass would increase at a greater rate.
could you use the perfect gas law- pressure =densityx universal gas constantx Temp
Thanks in Advance
The easiest way is to use a pycnometer or a calibrated volumetric flask and weigh it.
