Calculating Fluid Pressure for Viscosity-Injection Problem
  • Thread starter Thread starter afg_91320
8 replies · 5K views
afg_91320
Question Details:
A hypodermic syringe is attached to a needle that has an internal radius = .300mm and Length=3.00cm
The needle is filled with solution of viscosity= 2.00 x 10^(-3) Pa.S
And injected at a vein with a gauge pressure of 16mm Hg
What must the pressure of the fluid in the syringe be in order to inject the solution at a rate of .250 mL/s?
Answer = 6850 Pa
Poisellous equation
I attempted to use Poisellous Law for Viscous flow
this is my setup
delta p =
[(8/pi *delta V/ delta t)/(r4)]*L*Viscosity
and here i should be able to solve for fluid pressure
my gauge pressure us 16mm Hg-do i need to convert it to Pa?
oh wow...my bad...never mind -_-
thanks!
does anyone how delta p and gauge pressure are related?
i need to find pressure of fluid, and delta p is only unkown variable i have...so i know
i am solving for it, right?
Well, blood pressure is at 16mm Hg + atmospheric pressure and you just found delta-P, so just add them together and you'll get the pressure in the needle.
ok I am not getting the answer which is suppose to be 6850 Pa.
anyone able to help me out here??
yes it is-so how would i approach the problem?
You know the pressure inside the blood vessel and you know delta-P, the difference in pressure. It's very easy to get the answer from those two values.
