Calculating force and work done with 3D vectors
The discussion centers on calculating the force and work done for an object following a specified trajectory. The force acting on the object is derived as F(t) = -4t^-2 i - 3/2 t^-3/2 j, which is confirmed to be in the correct vector form. To find the work done between t=1 and t=2, the user is advised to compute the integral of the dot product of force and displacement, expressed as ∫(F ⋅ dr). However, the user encounters a negative value when applying the limits, indicating a potential error in the integration or limits used. Clarification is sought on the correct approach to ensure accurate calculation of work done.
r.physics
The question is as follows:
An object of mass m=1 follows the trajectory:
r(t) = 4 ln(t) i + 6t1/2 j + 2t k
Calculate the force acting on the object and hence find work done between t=1 and t=2.
I know that Force = Mass * Acceleration
Therefore, F(t) = 1 * a(t)
I also know that a(t) = r(t)''
After differentiating I end up with r(t)'' = -4t-2 i - 3/2 t-3/2 j
So I've ended up with
F(t) = -4t-2 i - 3/2 t-3/2 j
Is that my final answer for the force acting on the object, do I leave it in vector form?
For the work done part, I know that Work Done = Force x Distance
I have force and displacement in vector form but I don't know how to end up with a completely numerical value as I've got a time interval for t, I'm assuming there will be some sort of integration involved.
Can someone please tell me if I have done the first part correctly (calculating the force acting on the object) and if so how can I use this along with the conditions t=1 and t=2 to calculate work done? Thanks!
I think so, for the general concept of force contains its direction.
For the remained part, I suggest you try to calculate the tiny work ##dW## with the tiny displacement ##d\mathbf{r}## and then get their sum.
Thankyou for your reply. If I'm understanding what your suggesting correctly, I would now do:
∫dw = ∫ (F ⋅ dr) between the limits of t=2 and t=1
This leaves me with
Δw = [ 4t-1 i + 3t-1/2 j + 2 k ]⋅[4 ln(t) i + 6t1/2 j + 2t k]
With the limits being 2 and 1, I don't think I have done what you meant correctly as when I plug the limits in I end up with a negative answer for work done, any idea where I'm going wrong?
Thanks!
