Calculating Horizontal Force for 3 Boxes on Frictionless Surface
  • Thread starter Thread starter [KNIGHT]
The discussion revolves around calculating forces acting on three boxes with given masses on a frictionless surface, specifically focusing on horizontal force requirements and interactions between the boxes. The participants are exploring concepts related to Newton's laws of motion and free body diagrams.
  • Mixed
  • Participants attempt to calculate the horizontal force needed to accelerate the system and the forces exerted between the boxes. There are discussions about using F=ma for calculations and the importance of free body diagrams. Some participants express confusion about the setup and seek clarifications on the reasoning behind the calculations.
Several participants have provided calculations for the first question, while others are exploring the subsequent questions. There is a mix of correct and incorrect reasoning, with some participants questioning assumptions and seeking further explanations. Guidance has been offered regarding the application of Newton's laws and the relationships between the forces acting on the boxes.
There are discrepancies in the mass values mentioned by participants, leading to confusion. Additionally, some participants are considering scenarios with friction, which introduces new variables into the discussion. The original poster's attempts and the responses from others indicate a collaborative effort to clarify the problem setup and calculations.
[KNIGHT]
I need help with a physics question
Figure shows 3 boxes with mass 50kg, 20kg & 30kg on a frictionless surface.
1. What is the horizontal force required to push the system with an acceleration of 1ms-1?
2. Find the Force exerted by 50kg on 20kg
3. Find the force exerted by 20kg on 30kg
I was able to find the answer for the 1st question by using F=ma. And the answer i got was F=100N. But i don't know how to do question 2 & 3. So please help.
[knight];3483442 said:
i need help with a physics question
figure shows 3 boxes with mass 50kg, 25kg & 30kg on a frictionless surface.
2. Find the force exerted by 50kg on 20kg
i was able to find the answer for the 1st question by using f=ma. And the answer i got was f=100n. But i don't know how to do question 2 & 3. So please help.
f->50<->20<->30
fbd's
f ->50<- fa
fa->20<-fb
fb->30
i don't understand how you have done it. So can you please explain it further?
Look at the 30kg box.
it is accelerating at 1 ms-2
What force is necessary to make that happen?
What is touching the 30kg mass, so what is providing the force?
EDIT: the diagram shows boxes of 50, 20 and 30 - your opening sentence says they are 50, 25 &30 ??
for some reason i don't understand this :( :( Can someone try re explaining again in the simplest form and answer those questions as if you are doing the sum? (but in the simplest way)
thanks for pointing it. corrected it
You've got to draw Free Body Diagrams...Isolate the block you are investigating, identify the forces acting on it...and apply Newton's Laws. As PeterO has noted, the acceleration of each block is the same as the acceleration of the entire system of blocks.
Think about action/reaction forces and Newton's Third Law
can you do the questions step by step. then i might be able to understand
The step by step solution to part 3, which you do BEFORE part 2 is. as I stated before;
There .. I have asked 2 questions - the answers to which give the answer to question 3.
What are your answers to those two questions?
By using F=ma
= 30x1
= 30N
20kg mass is touching it
Then is 30N the the force exerted by 20kg on 30kg? I that the answer?
[KNIGHT];3484269 said:
By using F=ma
= 30x1
= 30N
Then is 30N the the force exerted by 20kg on 30kg? Is that the answer?
That is certainly part 3.
Now you need to look at Part 2 ...
If i have to redo the same question (all the parts) when the 3 boxes are on a rough surface of coefficient of static friction 0.6, how do i do it? Is it by using the equation F=miu.R? If so what should i substitute for F & R?
R will be the reaction force to the weight of what ever you were considering.
When you did part 1, you [correctly] just used a total mass of 100kg.
When you did part 3 you just used a mass of 30.
When you did part 2 you will have either used a mass of 20 or 50 depending which way you evaluated it.
F is the size of the friction force opposing what ever force you are calculating - the set of boxes, just 2 boxes, just 1 box; depends what you are analysing.
This is how i did part 2 (without friction)
F =ma
=20x1
= 20N
Then i did 2 parts with friction.
part 1
The total mass of the system = 100Kg.
g = 10Ms-2
Therefore mg = 1000N.
Since mg = R
R = 1000N
F=miu.R
=0.6X1000
= 600N
Frictional force = 600N
F=ma
F-600 = 100X1
F= 700N
part 3
Force exerted by 20kg on 30kg
Mass = 30kg
g = 10ms-2
mg = R = 300N
F= miu.R
= 0.6 X 300
= 180N
F=ma
F-180 = 30X1
F = 210N
Force exerted by 20kg on 30kg = 210N
Have i done it correctly
F =ma
=20x1
= 20N
part 1
g = 10Ms-2
Since mg = R
R = 1000N
F=miu.R
=0.6X1000
= 600N
F=ma
F-600 = 100X1
F= 700N
part 3
Mass = 30kg
g = 10ms-2
mg = R = 300N
F= miu.R
= 0.6 X 300
= 180N
F=ma
F-180 = 30X1
F = 210N
Your part 2 is incorrect [both times not surprisingly]
Without friction:
The net force on the 20 kg block is indeed 20N, but there are two blocks touching it.
The 50kg block pushes to the right, the 30kg pushes to the left.
The 30 kg block pushes left with 30N [Newtons 3rd law on the answer to part 3]
To get a net 20N force to the right, the 50N block must push with 50N.
[the fact that 30 goes with 30 and 50 goes with 50 is a bit of a co-incidence here]
The other way to do part 2 is a bit like you did Part 1.
In Part 1 you said F was accelerating a total of 100kg at 1 m/s^2 so F = ma gave 100N
Well the 50kg block is pushing against the other 2 blocks , of total mass 50Kg, and thus with a force of 50N.
You can fix up the Part 2 with friction with one of those methods now.
so part 2 without friction
from left to right
F=ma
F-30 = 20x1
F= 50N
Then is it ok?
And what about part 1 & 3 with friction?
from left to right
F=ma
F-30 = 20x1
F= 50N
Then is it ok?
Your with friction for 1 & 3 were fine. ANd that above is one way of doing part 2 - no friction.
Then how should i do part 2 with friction? Is it like this
F=miu.R
= 0.6 x (200N+300N)
= 300N
F=ma
F-300 = (20N+30N)x1
F = 800N
  • · Replies 21 ·
  • · Replies 95 ·
