Calculating Nitrogen percentage in food products.
  • Context: Undergrad
  • Thread starter Thread starter brobertson89
    Food Nitrogen
The discussion centers on the challenges faced by a food manufacturing company in maintaining acceptable nitrogen levels in packaged products. The company uses 100% nitrogen gas at flow rates of 16 and 14 m³/h and pressures around 3 bar. Testing revealed that higher flow rates resulted in less deviation in nitrogen levels, yet occasional high values persisted. Potential causes identified include equipment malfunctions, pipe blockages, and packaging defects that may allow oxygen infiltration.
  • Understanding of nitrogen gas properties and its role in food packaging
  • Familiarity with flow rate measurements in gas systems
  • Knowledge of packaging integrity testing methods
  • Basic principles of gas leak detection and troubleshooting
  • Investigate nitrogen flow rate optimization techniques
  • Learn about packaging integrity testing methods, such as seal testing
  • Research common causes of gas leaks in food packaging systems
  • Explore maintenance best practices for gas delivery systems in food manufacturing
Food manufacturing professionals, quality assurance specialists, and packaging engineers seeking to optimize nitrogen usage and maintain product integrity.
brobertson89
I just thought I would ask some people's opinions about this as I am stuck on what to do.
I am currently working for a food manufacturing company that pack their food with nitrogen gas to increase shelf life. However they have an acceptable limit of how much nitrogen can be within the product. Recently they have had some products that have come close to breaching this limit.
The trouble is they do not know why every so often one item does.
I took 100 samples of the products with two various nitrogen flow rates and it turns out that the deviation in the results of a higher flow rate is quite less then compared to the ones with a lower flow rate. However there still is the one or two randomly high values.
The flow rates i tested were 16 and 14 m^3 / h with a pressure of about 3 bar.
I am really stuck on what it could be. Does anyone have any ideas?
Off hand I would suggest a careful study of the equipment being used.
Try getting the maintenance dept. to check for pipe blockages or obstructions, we have had this with some lines in the workshop recently
Are you guys using 100% nitrogen or a mixture of different gases?
Also, what do you mean by "how much nitrogen within the product"? The amount that gets absorbed by the food? The amount in the packaging?
yes it is 100% nitrogen gas
it is a test of how much is in the packaging, we measure the oxygen percentage in the pack by putting a prob with a seal through the package
sorry i forgot to mention that we have done this, my other guess is that there may be leakages in the pipe work
I have decided my next cause of action is to find out whether the packages have holes in them and this is the cause or to see whether the product has defects which are entrapping oxygen and then braking whilst within the packaging, releasing the oxygen.
What do you think, are these possible causes?
I really don't know, but it sounds like you are either getting too much flow rate or the process is going on for slightly too long, causing more nitrogen to build up. A leak wouldn't let ONLY the oxygen out.
  • · Replies 16 ·
