Calculating sample size?
  • Context: Undergrad
  • Thread starter Thread starter Andy Resnick
Andy Resnick
Education Advisor
Insights Author
There has to be a simple way to calculate this, I just don't have a clue how.
The setup:
I'm teaching cell culture methods to some students, and part of the process is checking for contamination- after making culture media, a small volume is put into the incubator overnight and checked for bacterial growth in the morning.
The question (using 'normal' units for things)
"When you made 100 milliliters of solution, there could also be a small number of bacteria present, perhaps as much as 0.1 nanomolar. How much volume do you need to sample in order to be at least 99% confident that you captured at least 1 bacterium?"
Thanks in advance....
It seems 1ml would work. I guess you could imagine from 0.1 nanomolar = numerically how many bacteria (6.9E12). Then assume they are evenly distributed.
Take your volume of 100ml and divide it into 100 1ml. So each 1ml would have 1/100th the number of bacteria (6.0E10).
I'd approach it by noting that if there were one bacterium in a volume ##V## (##V=100\mathrm{ml}## in your case) and I drew a volume ##v##, the probability of not getting the bacterium would be ##1-v/V##. The probability of not getting any of ##n## bacteria whose locations are independent random variables is therefore ##(1-v/V)^n##. Requiring this to be less than 1% gives us $$
\begin{eqnarray*}
0.01&>&(1-v/V)^n\\
0.01^{1/n}&>&1-v/V\\
v&>&V(1-0.01^{1/n})
\end{eqnarray*}$$For your case where the number of bacteria is ##n\approx 6×10^{12}##, ##v## is pretty much indistinguishable from zero. You would have to try really really hard not to get a bacterium unless they all clump in one corner or something.
Is that a valid assumption, though? @Andy Resnick -- what are the typical causes of contamination in this setup? Does it usually come from contaminated dishes (so likely evenly distributed), or contaminated dispensing gear (so likely the contamination will be washed out with the first solution dispensed), or something else?
Sometimes you need to put a stick in the ground and make a guess.
Thanks to everyone for the replies, let me address them:
Apparently, I grossly overstated the (maximum) contamination level- obviously, as the number of contaminants decrease, I need to sample larger and larger volumes, but that would seem to quickly approach a limit when I need to sample the entire volume (or a substantial fraction of it. This is clearly not what is done in the biomedical or food industries:
"[xxx] brand, [YYY] cell culture liquid products are prepared by an aseptic process for which each step has been validated to ensure that all products meet the industry standard sterility assurance level of 10^-3; i.e. product that demonstrates a contamination level of no more than 1 of 1,000 units during the manufacturing process. The highest level of sterility assurance (equal to or greater than 10^-6) cannot be achieved without terminal sterilization which is harmful to the performance of cell culture products."
If I understand this correctly, the "industry standard sterility assurance level of 10^-3" means less than 0.01 bacteria/milliliter. If I make up a 1 liter batch, there can be up to 1 bacterium present. How much volume do I need to sample to meet the assurance level?
Other than grossly overestimating the contamination level, it a valid assumption. Ultimately, the typical causes of contamination are 'user error': touching any surface with a sterile pipette tip; improper sterilization of gloves or work area; rapid movement that brings outside air into the culture hood; stuff like that.
Which is what I have been doing all along :) So far it's worked out well (using the secret weapon of 'geometrical mean', I typically withdraw 2ml out of a 100 ml batch), I am/was hoping for some rational calculation to support my guess.
I think it depends a bit what that ##10^{-3}## means. You could argue that "of every 1,000 bottles we sell, 999 are sterile and the last one is actual swamp water" meets that standard, in which case you don't need to sample at all, you just throw away the bottle with the silt in it. Reading your quote of how the manufacturers describe it and your comments about typical contamination sources I think they do mean something of this sort, although not quite so exaggerated. So the question you are trying to answer seems to be "do I have the swamp water or not". Is that where the 0.1 nanomolar came from? You either have a sterile sample or a 0.1 nanomolar solution? If so, then 2ml is way more than enough.
I made up 0.1 nanomolar, the reality is that even a single bacterium (or mold spore, or yeast cell, or...) is too many. I should have phrased my original question like this:
"A volume of media may have a single bacterium present. How much of the volume do you need to sample to be 99% confident that no bacteria are present?"
A colleague mumbled something about Poisson distributions but then wandered off....
jedishrfu said:
Perhaps what you need is an EPA test protocol where you filter the 100ml through a couple of filters and culture the filters for aerobic, anaerobic and fungal contamination.
The sampling strategy to get to 99% means testing most of the water if not all of the water.
https://www.epa.gov/sites/default/files/2015-08/documents/method_1604_2002.pdf
I don't want to wander too far off topic here- I'll simply note that the protocol references "An appropriate volume of a [water] sample", and my question is specifically targeting the word "appropriate". How is that volume determined?
Was it simply a guess that has been converted into accepted practice? Is there any rational basis for determining what the appropriate sample volume is, given a total volume of material under test?
Maybe "A volume of media may have a single bacterium present. How much of the volume do you need to sample to be 99% confident that no bacteria are present?" is not a simple question to answer...
Yeah, sometimes a heuristic is used that's easy to remember, like the famously wrong one used during COVID to stand 6 feet apart, which was traced back to some journal papers in the 1950s and to the droplet model vs. aerosol transmission, where there is no set distance. Aerosols continue to follow air movement, whereas droplets fall based on their weight and size.
Personally, though, I feel the filtering and culturing approach gives much better safety than doing subset testing.
  • · Replies 23 ·
  • · Replies 19 ·
10K
