Calculating Speed of MRO Orbiting Mars
  • Thread starter Thread starter 462chevelle
    Mars Speed
10 replies · 3K views
462chevelle
what is the speed of MRO in its orbit around mars.
M mars=6.4X10^23
m MRO=907 Kg
d between the two=200 km
R of mars=3400 km
G=6.7X10^-11
D=(mMG)/r^2=(mV^2)/R=(MG/R)^1/2
I attached a pic of some of my work. if I need to add more detail or its hard to read let me know. I am just curious where the mistake is.
thanks
Lonnie
to clarify since I noticed its hard to interpret. the answer I got was appx 27 km/s and the correct answer is 3.5km/s
thanks
Lonnie
thanks
Lonnie
You are certainly right that I can't interpret that. Hence I have no idea how you got 27km/s instead of the correct answer. Can you explain clearly how you got 27km/s?
if I use D=mV^2/R
I get 200km = (907(V^2))/3400
multiply 3400*200 then divide by 907
to get 749=V^2
then (749)^1/2=appx. 27
that's the only equation from lecture that has velocity in it is the reason I am using it. I would think I would need to use an equation with G or M in it. but I don't have one written down here
462chevelle said:
if I use D=mV^2/R
to get 749=V^2
You don't understand what your equations mean. mV^2/R is the centripetal force exerted on the satellite by its rotation around the planet. It's not equal the distance from the planet. R is the distance to the center of the planet from the satellite, I hope you know what the rest mean. Now GMm/R^2 is the gravitational force. If the satellite is in a stable circular orbit then the two forces are equal. Set them equal and solve for V.
youre correct. I wasn't understanding what I was doing. I guess I just started plugging stuff out of frustration.
I started over and set them equal to each other like so
mV^2/R=GMm/R^2
factored out useless variables and rewrote as
V=(GM/r)^1/2
solved It again and got crap numbers again. I think I need to get some sleep and try it tomorrow with a clear mind. I know I am doing something wrong that is very simple. I have to be. because in order to get 3.5 as velocity I will have to get somewhere around 12 as my answer inside of the parenthesis and that seems impossible with my lack of sleep or focus right now.
mV^2/R=GMm/R^2
V=(GM/r)^1/2
Yes, try it again. Now you've got the right formula, but keep units in mind. G is probably given in units of meters, put everything in the same units and expect to get ~3500 m/s as your answer.
ahh crap.. i think you're right. i always screw up the units. after class ill have another stab at it and let you know how it goes.
thanks
the only way i can get it to work out right is if i convert
6.7X10^-11 to 6.7X10^-20
and i figured that out by leaving G as a variable and plugging 3.5 into v and solving for G
i wouldn't think that i would have to move my units as far as 9 places. but as many values are in the constant g its hard for me to interpret how to convert it
my lesson says G=6.7X10^-11m^3kg^-1s^-2
i guess i should understand what all of those units are interpreted as.
The units on G and M are fine! kg,m,s. The only ones that aren't fine are 200km and 3400km. Just change those to meters.
awesome. that worked out perfect. thanks man. i would have to say units is something that messes me up a lot.
