Calculating Tension and Reaction Forces in an Overhead Garage Door System
The discussion focuses on calculating the tension in cable AE and the reaction forces at the rollers in an overhead garage door system. The door, weighing 70 kg, is supported by a cable and two sets of frictionless rollers, with specific dimensions provided. A user suggests using the moment around point B to find the reaction at point A, followed by applying equilibrium equations for horizontal and vertical forces. The thread indicates a need for further assistance with the calculations, highlighting the complexity of the problem. The urgency for help is emphasized as the user expresses frustration over the lack of responses.
Jaspworld
A 70 kg overhead garage door consists of a uniform rectangular panel AC, 2100 mm high, supported by the cable AE attached at the middle of the upper edge of the door and by two sets of frictionless rollers A and B. Each set consists of 2 rollers located on either side of door. The rollers A are free to move in horizontal channels, while the rollers B are guided by vertical channels. If the door is held in the position for which BD =1050 mm, determine
a.) Tension in cable AE
b.) Reaction at each of the four channels
(For an image go to http://www.freewebsite.0nyx.com/images/garage.bmp Sorry for the crappy image. I made it in paint and by the way, that G is supposed to be W.)
Any thoughts...?
I'm not too sure but..
I think I can calculate the moment around point B and then get the value for A. Then I can let Fx=0 and Fy=0 and get the rest of the answers.
Does this make sense?
Help
How come my thread ended up on the third page! I still need help..
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
