Calculating the Voltage for a Proton Floating Between Two Boards
The problem involves calculating the voltage for a proton floating in an electric field between two boards, with given parameters such as gravitational acceleration, distance, and charge of the proton.
  • Exploratory, Assumption checking
  • The original poster attempts to calculate the voltage using two different approaches, questioning the validity of using gravitational force directly. Some participants raise concerns about the use of gravitational acceleration as a force and suggest considering the weight of the proton instead.
Participants are exploring different interpretations of the problem, with some providing feedback on the calculations presented. There is no explicit consensus, but guidance has been offered regarding the correct application of gravitational force.
There is a mention of the need to consider the weight of the proton in calculations, which may indicate a misunderstanding of the relationship between gravitational force and electric force in this context.
Mushroom79
A proton just floating in a field in a between two boards (g=9,82 m/s^2)
What is the voltage U?
distance d = 2 m
charge for protone Q = 1,602*10^-19
E = F/Q
E = U/d
I've tried two different ways of which I don't know is correct
In both cases I assume that F = 9,82 as something must be lifting it upp to make up for the gravitation
Attempt 1.
F = g = 9,82
E = F/Q = 9,82/(1,602*10^-19) = 6,13
E = U/d --> U = E*d = 6,13*2 = 2,26 V
Attempt 2.
E = U/d --> U = E*d = 19,64 V
Careful, you're using g (acceleration due to gravity) as a force. The force due to gravity on the proton would be its weight, m*g.
Oh, I forgot about that
Probably not the right solution considering the answer:
F = m*g = 1,672*10^-27 * 9,82 = 1,642 * 10^-26
E = F/Q = (1,672*10^-26)/(1,602*10^-19) = 1,044*10^-7
E = U/d --> U = E*d = (1,044*10^-7)*2 = 2,088*10^-7
Looks okay to me.
gneill said:
Looks okay to me.
Okay, thank you for the help :smile:
