Calculating Tray and Food Weight: Torque Question Help Requested
  • Thread starter Thread starter Student3.41
    Torque
The discussion focuses on calculating the forces exerted by the thumb and fingers while holding a lunch tray with specific weights and dimensions. The tray weighs 0.218 kg, the food plate weighs 1.28 kg, and the coffee cup weighs 0.255 kg. The calculations involve using torque equations, specifically T = Fl, to determine the forces acting on the tray. The final force exerted by the fingers is calculated to be 67.8 N, while the net torque indicates a downward force of -51.0 N, confirming static equilibrium.
  • Understanding of static equilibrium principles
  • Familiarity with torque calculations and the equation T = Fl
  • Basic knowledge of weight and mass conversions (N = kg·m/s²)
  • Ability to perform calculations involving distances and forces
  • Study advanced torque applications in physics
  • Learn about static equilibrium in multi-body systems
  • Explore the effects of center of gravity on stability
  • Investigate real-world applications of torque in engineering
Students in physics or engineering courses, particularly those studying mechanics, as well as educators looking for practical examples of torque and equilibrium in action.
Student3.41
A lunch tray is being held in one hand, as the drawing below illustrates.
The mass of the tray itself is 0.218 kg, and its center of gravity is located at its geometrical center. On the tray is a 1.28-kg plate of food and a 0.255-kg cup of coffee. Assume L1 = 0.0590 m, L2 = 0.109 m, L3 = 0.242 m, L4 = 0.373 m and L5 = 0.398 m. Obtain the force T exerted by the thumb (enter first) and the force F exerted by the four fingers. Both forces act perpendicular to the tray, which is being held parallel to the ground.
Attached picture.
T=Fl
I first solved for F.
I have subtracted L1 all the other L values because I have started from the thumb.
Tcup = Fl = (0.255kg*9.8m/s^2)(0.373m-0.0590m) = 0.785N*m
Tfood = (1.28kg)(9.8m/s^2)(0.183m) = 2.30N*m
I am not sure about this one but I am thinking I use the CG as the L because it is uniform. Therefore;
Ttray = (0.218kg)(9.8m/s^2)(0.200m(CG)-0.0590m) = 0.301N*m
TF = Fl = F(0.05m)
T[/SUB]NET[/SUB] = 0 - - - > Static Equilibrium
TF = Ttray+Tfood+Tcup
F(0.05m) = 0.301+2.30+0.785
F(0.05m)= 3.39N*m
F=3.39/0.05
F=67.8N
F[/SUB]NET[/SUB] = 0 ------> Equilibrium, Calulate the Weights of the objects.
W[/SUB]tray[/SUB]W[/SUB]cup[/SUB]W[/SUB]food[/SUB]F[/SUB]f[/SUB]
(2.14N) + (12.5N) + (2.50N) + (-67.8N) = T
T=-51.0N (-) indicates direction.
Did some work and need help.. thanks.
Your work approach looks very good. To be sure you did not make a math error, it is always a good idea to sum moments about the other unknown force (about the fingers) to see if you get the same result for T. Good work.:approve:
13K
10K
9K
