Calculating Triangle Ratios: Problem of the Week #66
  • Thread starter Thread starter Jameson
The forum discussion centers on calculating the ratio of the areas of two equilateral triangles, one inscribed in a circle and the other circumscribed around the same circle. Members caffeinemachine, MarkFL, soroban, and Sudharaka successfully provided correct solutions to the problem. Soroban's solution was highlighted as the primary method, while MarkFL offered an alternate approach. The discussion emphasizes the geometric relationships between the triangles and the circle.
  • Understanding of equilateral triangle properties
  • Knowledge of circle geometry
  • Familiarity with area calculation formulas
  • Basic algebra for ratio calculations
  • Study the properties of inscribed and circumscribed figures in geometry
  • Learn about the area formulas for triangles and circles
  • Explore advanced geometric ratios and their applications
  • Investigate problem-solving techniques in competitive mathematics
Mathematics enthusiasts, geometry students, educators teaching geometric concepts, and anyone interested in solving geometric problems and ratios.
Jameson
Insights Author
MHB
The diagram shows a circle with an equilateral triangle inside of it and one equilateral triangle outside of it. Calculate the ratio of the larger triangle to the smaller triangle.
Congratulations to the following members for their correct solutions:
1) caffeinemachine
2) MarkFL
3) soroban
4) Sudharaka
Solution (from soroban):
The diagram shows a circle with an inscribed equilateral triangle
and a circumscribed equilateral triangle.
Calculate the ratio of the areas of the large triangle to the small triangle.
Code:
              *   o * o   *
             *o    *:*    o*
            o     *:::*     o
           o     *:::::*     o
         *o    *:::::::::*    o*
        * o   *:::::::::::*   o *
       *  o  *:::::::::::::*  o  *
    *       o               o       *
   *          o           o          *
  *  *  *  *  *   o o o   *  *  *  *  *
Rotate the small triangle 60o.
Code:
We have four congruent equilateral triangles.
The ratio is 4:1
Alternate solution (from MarkFL):
I will let the are of the larger triangle be $A_L$ and the area of the smaller triangle be $A_S$. We may find both areas in therm of $r$, the radius of the circle.
If we draw line segments from the center of the circle to the vertices of the smaller triangle, we obtain 3 isosceles triangle, where two of the sides of the triangles is $r$, and the angle subtended by the two known sides is $$\frac{360^{\circ}}{3}=120^{\circ}$$
Using the formula for the area of a triangle $$A=\frac{1}{2}ab\sin(C)$$ and summing the areas 3 triangles, we find:
$$A_S=3\left(\frac{1}{2}r^2\sin\left(120^{\circ} \right) \right)=\frac{3\sqrt{3}}{4}r^2$$
If we draw line segments from the center of the circle to the mid-point of each side of the larger triangle, and to each vertex, we will have divided the larger triangle into 6 $30^{\circ}-60^{\circ}-90^{\circ}$ triangles. Thus, we may add the areas of these triangles to find:
$$A_L=6\left(\frac{1}{2}2r^2\sin\left(60^{\circ} \right) \right)=3\sqrt{3}r^2$$
And so the requested ratio is:
$$\frac{A_L}{A_S}=\frac{3\sqrt{3}r^2}{\frac{3\sqrt{3}}{4}r^2}=4$$
  • · Replies 59 ·
85K
