Calculating Vector Quantity with Given Magnitude and Direction
  • Thread starter Thread starter Physicsnoob90
    Vectors
The problem involves calculating a specific quantity related to two vectors, A and B, each defined by their magnitudes and directions. The vectors are given in terms of their magnitudes and angles relative to the positive x-axis, and the task is to determine the expression |A + B|^2 − |A − B|^2.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the calculation of vector components and the interpretation of the expression involving the vectors A and B. Questions arise regarding whether the terms A+B and A-B are vectors or scalars, and there is exploration of how to properly compute their lengths.
Participants are actively engaging with the problem, clarifying the nature of vector addition and the significance of the notation used. Some guidance has been provided regarding the correct approach to find the lengths of the resultant vectors A+B and A-B, and the discussion is focused on understanding these concepts without reaching a final conclusion.
There is an emphasis on understanding vector addition and the geometric interpretation of the vectors involved, including references to drawing vectors and visualizing their relationships. The discussion reflects an ongoing exploration of the problem rather than a resolution.
Physicsnoob90
Vector A has magnitude A = 4.0 units and is directed θA = 15◦ counterclockwise from the positive x-axis. Vector B has magnitude B = 4.0 units and is directed θB = 85◦ counterclockwise from the positive x-axis. Determine the following quantity: |A + B|^2 − |A − B|^2.
Steps) 1. i calculated their components: Ax= 4.0 cos 15º = 3.86, Ay= 4.0 sin 15º = 1.04 , A= 4.898979486
Bx= 4.0 cos 85º = 0.35 , By= 4.0 sin 85º = 3.98 , B= 4.333401763
2. plug into the format: |(4.898979486)^2 + (4.333401763)^2| - |(4.898979486)^2 - (4.333401763)^2| = 38
Look at the A+B and A-B terms in your expression are they vectors or scalars?
they are vectors
So what you wrote added the lengths of the components of A and B together which is not right.
when instead you should find the length of the new vector A+B and square it for your expression.
i thought it was asking to add the components of the vector A and B while also figuring out the quantity |A+B|^2 - |A-B|^2?
The notation |A+B| means the length of the vector A+B just as |A| means the length of The vector A.
So would creating a new vector like vector C = A+B?
Yes and then find the length of C to use in your expression similarly for the |A-B| term which is the length of the vector A-B.
Have you drawn these four vectors on paper? The A and B represent the sides of a parallelogram and the A+B is one diagonal.
Do you know what the other vector is?
isn't the other vector the opposite diagonal to A+B?
Yes it is.
Did you figure out the answer now?
  • · Replies 16 ·
10K
