Calculating Vector Quantity with Given Magnitude and Direction
  • Thread starter Physicsnoob90
    Vectors
9 replies · 2K views · last reply
Physicsnoob90
Vector A has magnitude A = 4.0 units and is directed θA = 15◦ counterclockwise from the positive x-axis. Vector B has magnitude B = 4.0 units and is directed θB = 85◦ counterclockwise from the positive x-axis. Determine the following quantity: |A + B|^2 − |A − B|^2.
Steps) 1. i calculated their components: Ax= 4.0 cos 15º = 3.86, Ay= 4.0 sin 15º = 1.04 , A= 4.898979486
Bx= 4.0 cos 85º = 0.35 , By= 4.0 sin 85º = 3.98 , B= 4.333401763
2. plug into the format: |(4.898979486)^2 + (4.333401763)^2| - |(4.898979486)^2 - (4.333401763)^2| = 38
So what you wrote added the lengths of the components of A and B together which is not right.
when instead you should find the length of the new vector A+B and square it for your expression.
i thought it was asking to add the components of the vector A and B while also figuring out the quantity |A+B|^2 - |A-B|^2?
So would creating a new vector like vector C = A+B?
Yes and then find the length of C to use in your expression similarly for the |A-B| term which is the length of the vector A-B.
Have you drawn these four vectors on paper? The A and B represent the sides of a parallelogram and the A+B is one diagonal.
Do you know what the other vector is?
isn't the other vector the opposite diagonal to A+B?
