Calculating Work Required to Move Test Charge
The problem involves calculating the work required to move a test charge in the electric field created by two identical positive charges. The original poster presents a scenario with two +30uC charges and a +0.5uC test charge, seeking to determine the work needed to move the test charge from a midpoint to a point closer to one of the charges.
  • Participants discuss various methods to calculate work, including potential energy differences and forces acting on the test charge. Some participants question the assumptions made about potential energy and the calculations involving forces.
There are multiple interpretations of how to approach the problem, with some participants suggesting different methods for calculating potential energy and work. Guidance has been offered regarding the use of potential energy formulas, and some participants express confusion about the reasoning behind certain calculations.
Participants note the complexity of the problem, including the need to consider the contributions of both charges to the potential energy of the test charge. There is also mention of the challenge in reconciling the forces and energies involved in the calculations.
dotcom
A +30uC charge is placed 40cm away from an identical +30uC charge. How much work would be required to move a +0.5uC test charge from a midway between them to a point 10cm clover to either of the charges?
E=V/d, W=qV, k=8.99*10^9
well...
W=qV=(0.5*10^(-6)){(30*10^(-6)k/0.1)-(30*10^(-6)k/0.2)}=1.32
the answer should be 0.45J...
Please, anyone who understands this question, explain me how to get the answer!
There shouldn't be a negative sign there, so that part of your answer is wrong.
I think you need to find the change in potential energy from when the test charge is sitting between the two +30uC charges, to when it is moved 10cm over. That is the work done in moving it. So if you fix the calculation above, you are half done.
I tried with
W=qV=(0.5*10^(-6)){(30*10^(-6)k/0.1)(30*10^(-6)k/0.2)}
but the answer was then too big...
I then assumed that the potential energy is 0 when the test charge is sitting between the two +30uC charges (as it's balanced).
And the energy when it is moved 10cm over is:
force to the left=(0.5*10^(-6))(30*10^(-6))k/0.1^2=13.485
force to the right=(0.5*10^(-6))(30*10^(-6))k/0.3^2=1.498
using E=F/q,
E=(13.485-1.498)/(0.5*10^(-6))=11.987
therefore, W=qEd=0.5*10^(-6)*11.987*0.1=1.198
which is not the right answer...
can anyone suggest me the correct way to go?
The PE of the test charge sitting between the others is just twice what you'd get if there was only one 20cm away.
After moving, you are 10cm from one charge and 30cm from the other. Find the difference between the initial and final energies.
So the initial PE is
net initial force =2*((0.5*10^(-6))(30*10^(-6))k/0.2^2 =6.7425
PE=F/q=6.7425/(0.5*10^(-6))=13485000
W=qEd=(0.5*10^(-6))*13485000*0.2=1.3485
net final force =((0.5*10^(-6))(30*10^(-6))k/0.1^2 +((0.5*10^(-6))(30*10^(-6))k/0.3^2=14.9833
PE=F/q=14.9833/(0.5*10^(-6))=29966666
W=qEd=(0.5*10^(-6))*29966666*0.1=
W required=1.4983-1.3485=0.1498
I still cannot get the right answer...
Where did I fall into a trap?
Well, you can't be faulted for effort. You're doing it the hard way.
You don't need to calculate the forces, because PE = k.q.q/r.
So,
initial energy=2*((0.5*10^(-6))(30*10^(-6))k/0.2 = ??
final energy=((0.5*10^(-6))(30*10^(-6))k/0.1 +((0.5*10^(-6))(30*10^(-6))k/0.3=??
and
work = final energy - initial energy
Oh, I finally got the right answer, following Mr/Ms Mentz114's way! Thank you so much!
But...I still can't understand why the energy in both directions are added together for calculating the potential energy. Aren't the charges at right and left end both positive? Then don't they exert equal and opposite force on the test charge in the midway?
I'm glad to hear it.
Your question is a good one. If we moved the test charge to the left, the big charge on the right is helping us, so we are doing negative work wrt to it. But the big charge on the right opposes us, so we do positive work against it.
There are two terms in the final energy, and if we compare with the two (equal) terms in the initial energy, one as gone up, and the other down.
9K
