Calculating Work Using Dot Product: Constant Force and Particle Position
6 replies · 3K views
PsychonautQQ
A constant force of 1i - 5j -8k moves (1,-4,2) (-3,2,-1), what is the work done on the particle?
Avector*Bvector=ABsinθ
?? I think?
I really am quite lost... but I found the coordinates for the position vector...
(-3-1)i + (2--4j) + (-1-2)k and the magnitude of the position vector is 7.81
so the unit vector is -.512i + .768j -.384k... am I on the right track here?
?? I think?
For a constant force F, the work done is just the dot product of the force with the displacement. Use that.
so the force is 1i - 5j -8k and the displacement is -4i +6j -3k? so dot product would be -4 -30 - 24 = -58?
How do I find the angel between these vectors?
Yes, if the force isn't constant you need to work harder and integrate, but if it's constant, it's that easy.
Why do you think you need the angle?
If you are required, separately, to find the angle between vectors, the dot product can be defined as
[tex]\vec{u}\cdot\vec{v}= |\vec{u}||\vec{v}|cos(\theta)[/tex]
where [itex]\theta[/itex] is the angle between the vectors.
