Calculus Highway Construction Problem
1 reply · 7K views · last reply
harshey
A segment of interstate highwya under consideration lies in a vertical plane. A segment with a grade of -5% is to be joined smoothly to a segment with a grade of 3%. The vetical parabolic curve which will accomplish this transition is to begin at a point with elevation 1250 ft. The length of the vertical curve is to be 1000 ft. See figure. I have attached the figure as an attachment.
Using a suitable coordinate system in which the horizontal and vertical units are feet, determine the equation of the vertical parabolic curve which makes the smooth transition between the two grades.
y = Ax^2+Bx+C
Grade of 3% means for every 100 ft. in highway length, there is a 3 ft. increase in elevation of the highway.
Same for -5%.
What I think is necessary to solve this problem is the coordinate point at B. Also, where the parabolic curve has a tangent of 0. With that I think I would be able to solve the problem.
However, I can't figure out how to find where the parabolic curve has a tangent of 0.
I may be on the wrong path completely so please let me know if you think there's a better way to solve the problem.
Another thing I tried was saying that well, if it begins as a -5% grade, and ends as a 3% grade, the overall grade is -2%, thus from that I thought I could find the y coordinate point of B, but that got me nowhere I think.
I would really appreciate it if anyone could help.
Thanks a lot.
  • Hand-drawn sketch on lined paper of a vertical parabolic curve joining two road grades; the curve starts at point A on a -5% slope and ends at point B on a 3% slope, with a horizontal length labelled L = 1000 ft. and a vertical drop labelled 1250 ft.
You've recognised the general equation of a parabola to be y = Ax^2 + Bx + C. Because we're dealing with gradients, I suggest you differentiate this equation with respect to x. In this situation, y is the elevation, and x is the horizontal distance.
A sensible co-ordinate system would be to have x = 0 when the parabola starts, i.e. y = 1250 when x = 0. Find C from this. Use the gradient when x = 0 to find B, and then also you known when x = 1000, the gradient is 3%, and so find A. Remember to turn the percentage gradients into fractions.
Hope this helps.
