Calculus-I: discontinuity of piecewise function HW problem
7 replies · 3K views
grey2q
Screenshot of my homework problem along with my solution so far. I'm not sure if I'm doing this correctly and if I am... if I'm answering correctly. Thank you. (EDIT: I made 1 small error with the piecewise definition. Ignore the f(x) before g(x).)
What about where x < 0 or where x > 3? Your function is defined on those intervals, as well.
Also, the homework template you deleted is required here. In future posts, please don't delete this template.
You have shown that the piecewise function is continuous at the boundaries of the pieces. If you are going to investigate the continuity of the function, you should also find out if there are any other discontinuities.
Thanks for the response.
I think I understand. So, would it make more sense for me to say that the piecewise function isn't discontinuous? Or that the piecewise function is continuous?
And what about my math? Am I going about this the correct way?
Right, either way. The function is continuous on the entire real line.
Looks OK to me.
For more clarity I would see whether you could simplify the second function - might bring new insight. :oldwink:
It doesn't in this problem, but the OP might or might not have done this. The second function (the rational expression) is continuous at each point on the interval [0, 3]. @grey2q, did you consider this?
I did.
Thanks for the help guys. I think I understand now.
