Calculus II Problem: Describe the region
The problem involves describing the region containing all planes that pass through the point (4, 5, 6) and are parallel to the vector <1, 2, 3>. The subject area is Calculus III, focusing on geometric interpretations of planes and vectors in three-dimensional space.
  • Participants express confusion about how a plane can be parallel to a vector and discuss the implications of this relationship. Some suggest visualizing the planes as rotating around a line defined by the vector, while others question the clarity of the problem statement and the nature of the required description.
The discussion is ongoing, with various interpretations being explored. Some participants have suggested that the planes could sweep out three-dimensional space, while others are seeking clarification on whether a narrative description or an equation is expected. There is no explicit consensus yet.
Participants note ambiguity in the problem's wording, particularly regarding the description of "all planes" versus "the plane," and the necessity of additional information to determine a specific plane's equation.
lizbeth
Sorry, this should say "Calculus III problem".
Describe the region that contains all planes passing through (4, 5, 6) that are parallel to <1, 2, 3>.
I cannot imagine how to answer this. I expect that there are multiple planes that could pass through a single point and be parallel to a vector, since the vector can move around in space. But what would that look like? Would the planes form a sphere as you move the vector around the point in a circle? Very confused by this question.
How can a plane be said to be "parallel" to a vector?
I think it is confusing too. Think about the line through (4,5,6) with direction vector <1,2,3>. Now pass a plane through that line. Think of the line as a straight wire and the plane glued to it. Now if you grab that wire and rotate it around its own axis, that plane will swing around sweeping out all of 3 space. Maybe that's what is wanted.
OR - a plane is parallel to a vector if it's normal vector is parallel to it ... not happy with that either because that is just a plane and there is only one of them that goes through that point and "a plane" is not much of a description.
BUT maybe, by "description", then mean the equation of the plane?
I don't know if this is supposed to be a narrative description or an equation, either. I could not think how to find the equation of the plane given this information. I could find the equation of the line, but not the plane. Wouldn't I need a point outside the plane? Plus, it says "All Planes", not "The Plane". And "planes" is in bold in the homework as well.
Then you need to clear up the ambiguity.
You may have a previous example in your notes - otherwise you'll have to ask the person who set the problem of someone else.
As a final resort, you can provide each interpretation of the question with the answer.
I don't agree with that at all. A plane is parallel to a vector if the vector is perpendicular to the plane's normal.
Imagine the vector <1,2,3> sticking out from the point (4,5,6); this will be part of the line ##(x,y,z) = (4,5,6) +t(1,2,3) = (4+t,5+t,6+t)##. Now put a plane through this line; rotate the plane about the line and through 360 degrees. That sweeps out the region you are asked for, and it is the entire 3-dimensional space, as LCKurtz has already indicated. (In other words, any point (x,y,z) is on some plane through (4,5,6) that is parallel to <1,2,3>.)
That is what I was thinking as well, Ray and LCKurtz. Thank you all so much for your help with this.
  • · Replies 21 ·
