Calculus Work Problem (Spherical Water Tower)
2 replies · 12K views · last reply
dbai
A spherical water tower 40 ft in diameter has its center 120 ft above the ground. That means, there is a 120 ft pole connected to the 40 ft diameter spherical tank. Water is being pumped at the ground level to fill the tank with water of density 62.4 lb/ft3,
a) How much work is done in filling the tank half full?
b) How much work is done in filling the tank ENTIRELY full?
dW = (dV)*(density)*(displacement)
  • I calculated that dV would be a cylindrical section of the tank with height dy --> πx2 dy
  • Density is given 62.4 lb/ft3
  • I used (120 - y) as my displacement
    ∫(Pi)x2(120 - y) dy Limits: 0-120 ??
    I don't know if the displacement is correct and how to convert x in terms of y.
I am not sure what it is are using x for? Do you mean r?
What is x supposed to be here? You should draw a picture of a right-angle triangle whose L-shape rests upright on the infinitesimal cylindrical slice of water. Then the hypotenuse would be constant, namely 20^2. Denote the base by x (or r) and the height as 20-y. See how to take to it from here?
