Camera Specifications computing focal length and f/#
The discussion centers on calculating focal length and f/# for a narrow field of view camera based on given specifications. The initial calculations suggest an impractically large focal length and f/#, prompting questions about the formulas used. Clarification is provided that the field of view is measured in degrees, and the resolution spec is influenced by the lens used. It is noted that atmospheric distortion can affect imaging quality over long distances, potentially hindering the resolution. The importance of clear specifications when communicating with suppliers is emphasized to avoid misunderstandings.
thiirane
So I have come across a specification of a narrow field of view camera. The specification states
IFOV=30 microrad
FOV=2x2
resolution=<.1m at 1 km
If I assume a 1K sensor at 9micron pitch and an aperture = 3.7cm
I have resolution at .013 m
Chip size = 9.2mm
Focal length is 6.167E5mm?? can this be right? Also f/#=1.6E4
Do I have the formulas correct
f/#=Focal Length/Aperture
Focal Length=Aperture/2*tan(IFOV)
Can you provide additional information- for example, the field of view = 2x2 what- radians, degrees, other? Any specific information on the lens?
Alternatively, do you have a product ID/name?
Hi Andy,
Actually the only thing specified is the IFOV, FOV and resolution at 1Km I think it is up to the supplier to design the rest. FOV is degrees. I assumed a sensor 1K sensor at 9 microns.
It's still not entirely clear- are you specifying a sensor, a lens, or an integrated sensor+lens? The IFOV and FOV specs define the sensor array size (I also got a 1k x 1k array), but the resolution spec involves a lens (which will operate at f/15 at a magnification of 1*10^-6, according the spec and assuming you are using visible light), and combining everything indicates a 400mm focal length lens, if the pixel size is 9um.
Note- imaging over 1 km distance is complicated by atmospheric distortion, you are unlikely to meet your resolution spec unless your application is able to avoid this. Some friendly advice- providing the OP specs to a supplier will result in an irritated supplier.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
16K
13K
  • · Replies 34 ·
14K
