Can a 1kg Black Hole Be Manipulated and Moved?
  • Context: Graduate
  • Thread starter Thread starter Jarfi
    Black hole Hole
A 1 kg black hole will evaporate almost instantaneously, with an estimated evaporation time of 1.44e-17 seconds, radiating energy at a rate of 3.6e32 joules per second. To counteract this loss, it would need to consume approximately 4e15 kg of matter per second. While it is theoretically possible to manipulate a black hole by throwing mass at it to conserve momentum, the extreme evaporation rate of a 1 kg black hole makes practical manipulation unfeasible. Additionally, such small black holes cannot form through known stellar processes, though primordial black holes may have existed shortly after the Big Bang.
  • Understanding of black hole physics
  • Familiarity with Hawking Radiation
  • Knowledge of momentum conservation in physics
  • Basic concepts of mass-energy equivalence
  • Research Hawking Radiation and its implications for black hole evaporation
  • Explore the concept of primordial black holes and their formation
  • Study momentum conservation principles in particle physics
  • Investigate the theoretical frameworks surrounding black hole manipulation
Physicists, astrophysicists, and students interested in advanced concepts of black hole dynamics and theoretical physics.
Jarfi
And if so what would happen if it would be created on Earth is there any way to push it out of the orbit could you actually manipulate such a small black hole?
Astronomy news on Phys.org
A black hole can be of any size but a 1kg black hole will evaporate long before you can move it. Unless it fell through the floor and ate enough of the world per second to over come its evaporation.
As for moving a black hole there's I'm not sure if perhaps just chucking mass at it will result in it moving. Not my field though
That probably wouldn't even be enough. The estimated exaporation time of a 1 kg BH is 1.44e-17 sec. It would radiating energy away at a rate of 3.6e32 joules/sec, and thus would have to eat matter at a rate of ~4e15 kg/sec just to keep up with the loss.
It would indeed evaporate VERY quickly. Moving a black hole can indeed be done by throwing mass on it from a certain direction, as the total momentum of the system needs to be conserved. For a 1 kg black hole this si still easy (if it wouldn't evaporate), more massive ones are going to need excessive amounts of mass...
A one kilogram black hole can exist. But it will be microscopic, perhaps even smaller than an electron! Anything can be made into a black hole there is enough mass in an extremely small amount of space. In other words, any squeezed down enough would turn into a black hole. The planet Earth weighs much, much more than one kilogram. Earth would turn into a black hole if it was squeezed down into the size of a marble. So just imagine how much you would have to squeeze down a one kilogram mass to turn it into a black hole? That's why I said it's microscopic.
harcel said:
... Moving a black hole can indeed be done by throwing mass on it from a certain direction, as the total momentum of the system needs to be conserved. For a 1 kg black hole this si still easy (if it wouldn't evaporate), more massive ones are going to need excessive amounts of mass...
If you don't want to increase the mass of the black hole you can "pull" it with another massive body. For example a 1kg black hole at the surface of the Earth will fall at the same 9.8m/s/s rate as will a slug of lead.
Of course where the slug of lead will hit the ground with a thud, the sub-microscopic BH will pass right through the Earth and "orbit" through the ground.
Such a small BH cannot be formed naturally by any stellar process of which we are aware, however speculations have been made that so called Primordial black holes might have formed soon after the BB. One might look for some of theses by moving asteroids around and seeing if there's any mass left in their previous orbit... (also one would look for the Hawking Radiation they would emit.)
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 22 ·
