Can a 250 cc Honda Engine Be Integrated into a Car with a Button Gear Shift?
  • Thread starter Thread starter nikhilesh
    Gear Shift
The integration of a 250 cc Honda engine into a car using a button gear shift is feasible, with discussions highlighting the use of solenoids and mechanical linkages for gear shifting. A double throw solenoid can effectively shift gears, but a mechanical linkage system is recommended for simplicity and reliability. The weight of the solenoid system compared to a mechanical setup is a concern, with suggestions to explore cable systems or pivoting rods for efficiency. Overall, a mechanical approach is favored for its practicality in this application.
  • Understanding of solenoid operation and applications in automotive systems
  • Knowledge of mechanical linkage systems for gear shifting
  • Familiarity with 250 cc Honda engine specifications and gearbox patterns
  • Basic principles of hydraulic systems and their use in automotive applications
  • Research mechanical linkage systems for automotive gear shifting
  • Explore the use of solenoids in automotive applications
  • Investigate cable systems for gear shifting mechanisms
  • Learn about hydraulic shifting systems and their components
Automotive engineers, DIY car builders, and enthusiasts interested in custom gear shifting solutions for small engine vehicles.
nikhilesh
I've a gearbox from a 250 cc Honda engine. The pattern in one down and four up. This engine will be integrated into a car, so the changing of gears will be difficult with the foot pedal. wouldn't it ? :) . So i decided to integrate a small motor to the gear shift pedal so that it can change gears. Is this feasible?
Will it work?
any answers?
what about hydraulic shifting? Like using a paintball CO2 bottle or those 12 gram CO2 cartridges.
Is weight a concern? Would the motor and its power supply be lighter than a CO2 shifting system?
It shouldn't be hard to add a linkage from the gearbox to a regular floor-mounted stick. A cable system would probably be easiest.
SELENOID A DOUBLE should work to shift up and down
trick is to match it to the effort required
not too strong or weak
but there are a lot of car [12v] selenoids in use
a trip to a junk yard should get you a bunch
what exactly is a selenoid? what's it used for in a car?
and the idea behind the motor, is to make the gear shift with a button or paddle... while still using the clutch with the other hand... all this on the steering wheel
a selenoid is a el-trick magnet that moves something
a double throw selenoid moves in and out depending on current direction
most are switches but some move things like on a starter or a air flow flap
You may have better luck searching for a 'selenoid' if you spell it 'solenoid'.
Personally, I think this sounds like the kind of application where you'd be much better off with a mechanical linkage of some sort. Danger's suggestion of cables would be worth looking at, or (depending on packaging constraints) a simple system of pivoting rods.
This is an excellent way to do it. I recently saw an internet video that had just this setup in a dune buggy with a rear-mounted 1200cc crotch-rocket engine in it. There was a "shifter" next to the driver, forward was shift up and backward was shift down.
Using a solenoid is extra weight and extra trouble. I too would go for the mechanical shift linkage approach.
25K
12K
16K
