Can a Basis Vector be Lightlike?
  • Level: Undergrad
  • Thread starter cianfa72
    Basis Vector
28 replies · 4K views · last reply
cianfa72
[Moderator's note: Spin off from another thread due to topic change.]
I was thinking about the following: can we take as a basis vector a null (i.e. lightlike) vector to write down the metric ?
Call ##v## such a vector and add to it 3 linear independent vectors. We get a basis for the tangent space (the first vector in the basis is the ##v## vector itself).
Then in such a basis the metric coefficient ##g_{00}## should be zero since the vector ##v## has coordinate ##(1,0,0,0)## and by definition it has zero length. Hence we are not allowed to use it, I believe.
cianfa72 said:
Sorry I was thinking about the following: can we take as a basis vector a null (i.e. lightlike) vector to write down the metric ?
Yes, you can do that.
cianfa72 said:
Then in such a basis the metric coefficient ##g_{00}## should be zero since the vector ##v## has coordinate ##(1,0,0,0)## and it has zero length. Hence we are not allowed to use it, I believe.
You are not allowed to use what?
If we use the vector ##v## as element in the basis we get a metric in which ##g_{00}## is actually zero. Does a such metric make sense ?
Of course. That is just a component in a given basis, it can be zero or anything else.
BTW it does mean the metric in that basis cannot be diagonal, otherwise components in ##v## direction do not appear in the metric at all !
Take the most simple (1+1)-dimensional Minkowski-space example. A basis must just two linear independent vectors. Let's choose the two light-like vectors ##\boldsymbol{e}_1=(1,1)## and ##\boldsymbol{e}_2=(1,-1)## (written as component vectors wrt. a usual pseudo-Euclidean/Lorentzian basis). Then the Minkowski product of two vectors ##\boldsymbol{x}## and ##\boldsymbol{y}## wrt. this "light-like basis" is
$$\boldsymbol{x} \cdot \boldsymbol{y}=x^1 y^1 \boldsymbol{e}_1 \cdot \boldsymbol{e}_1 + (x^1 y^2 + x^2 y^1) \boldsymbol{e}_1 \boldsymbol{e}_2 + x^2 y^2 \boldsymbol{e}_2 \cdot \boldsymbol{e}_2 = 2 (x^1 y^2+x^2 y^1).$$
vanhees71 said:
Take the most simple (1+1)-dimensional Minkowski-space example. A basis must just two linear independent vectors. Let's choose the two light-like vectors ##\boldsymbol{e}_1=(1,1)## and ##\boldsymbol{e}_2=(1,-1)##.
Yes, indeed the (1+1) Minkowski metric in that basis is not diagonal.
Of course not. They can not. Think about what you can say if you have two light-like vectors that are Minkowski-orthogonal to each other! Can they be (part of) a basis?
isaacdl said:
Yes, I can see it graphically, but my problem is to show it in a free cordinate way.
You can do it in a coordinate-free way.
Given ##\vec A## and ##\vec B##, then ##\vec B= \vec A+ (\vec B-\vec A)##. (No coordinates were used in this calculation.)
Two linear independent null (light-like) vectors ##\boldsymbol {u}, \boldsymbol {w}## in Minkowski standard basis have components:
##\boldsymbol {u} = (k, k) , \boldsymbol {w} = (m , -m) \text{ } k,m \in \mathbb R##
then the further condition ##\boldsymbol{u} \cdot \boldsymbol{w} = 0## implies ##km + km = 2km = 0##. Hence either ##\boldsymbol {u}## or ##\boldsymbol {w}## would result in the zero vector.
vanhees71 said:
You can rather prove that two Minkowski-orthogonal lightlike vectors are collinear.
Yes, if both ##\boldsymbol {u}## and ##\boldsymbol {w}## are not the zero vector then it follows ## \boldsymbol {u} = k \boldsymbol {w}##, hence they are not linearly independent (it actually includes the case at least one vector is the zero vector).
Also look at the textbook by Stephani et al. for usage of complex null tetrads, formed of two real null vectors ##\mathbf{k}## and ##\mathbf{l}## with ##g_{kl} = \mathbf{k} \cdot \mathbf{l} = -1## and two complex null vectors ##\mathbf{m}## and ##\overline{\mathbf{m}}## with ##g_{m \overline{m}} = \mathbf{m} \cdot \overline{\mathbf{m}} = 1##. (All the other inner products vanish.)
Another point related to the topic. I would like to show that any 4-vector in Minkowski spacetime can be written as the sum of a timelike vector plus a spacelike one.
Take a timelike vector ##\boldsymbol {u}##. It has components ##(u_0,u_1,u_2,u_3)## in Minkowski standard basis.
Consider the set of vectors ##\boldsymbol {w}## of components ##(w_0,w_1,w_2,w_3)## orthogonal to it, namely the set of vectors such that ##u_0w_0 - u_1w_1 - u_2w_2 - u_3w_3=0## in Minkowski standard basis. Such a set defines a 3-dimensional linear subspace of the vector space ##V##. Furthermore each vector in such set is spacelike.
This way we get a basis of one timelike vector ##\boldsymbol {u}## and three linear independent spacelike vectors orthogonal to it. So the subspace spanned by ##\boldsymbol {u}## and the subspace ##\boldsymbol {u}\perp## are in direct sum, hence any vector in ##V## can be uniquely written as the the linear combination of vector ##\boldsymbol {u}## and a vector in ##\boldsymbol {u}\perp##.
Does it make sense ? Thanks.
Take an arbitrary vector ##v^a## and an arbitrary unit timelike vector ##t^a##. Then ##v_at^a## is the component of ##v^a## parallel to ##t^a##, so ##s^a=v^a-v_bt^bt^a## is the part of ##v^a## that is orthogonal to ##t^a## (note: flip the sign on the second term if your metric is -+++). It's just algebra to show that ##s^a## is a spacelike vector. Hence we have shown that ##v^a=(v_bt^b) t^a+s^a## as required.
Ibix said:
Take an arbitrary vector ##v^a## and an arbitrary unit timelike vector ##t^a##. Then ##v_at^a## is the component of ##v^a## parallel to ##t^a##, so ##s^a=v^a-v_bt^bt^a## is the part of ##v^a## that is orthogonal to ##t^a##.
##s_at^a=v_at^a - (v_bt^b)t_at^a##. Since ##t^a## is unit timelike then ##s_at^a=v_at^a - v_bt^b=0##, hence ##s^a## is orthogonal to ##t^a##.
vanhees71 said:
Yes, and a vector Minkowski-orthogonal to a time-like vector is...
Spacelike (if non-zero vector).
I was assuming you'd calculate ##s_as^a## and see that it's opposite sign to ##t_at^a##, but yes.
##s_as^a = (v_a - (v_bt^b)t_a)(v^a-v_bt^bt^a) = v_av^a - (v_bt^b)v_at^a - (v_bt^b)t_av^a + (v_bt^b)^2t_at^a = ##
##s_as^a = v_av^a - 2(v_bt^b)^2 + (v_bt^b)^2 = v_av^a - (v_bt^b)^2##
Yup. From your final expression ##s_as^a## is manifestly negative if ##v_av^a\leq 0##, but in the case that ##v_av^a>0## there's a tiny bit more work to do to show that ##(v_av^a)\leq(v_at^a)^2##.
Supposing I did not any mistake before, I've no idea how to proceed 🤔 .
The vectors can't be completely arbitrary since they must be linearly independent.
Yeah, you're right. If ##v^a=kt^a## for some constant ##k## then ##s^a=0##. So you have to choose a unit timelike vector ##t^a##, arbitrary except that it isn't parallel to ##v^a##.
What's ##v_at^a## in terms of ##v_av^a## and ##t_at^a##, assuming ##v^a## is timelike?
Since ##v_av^a > 0## there is a Lorentz-orthonormal basis such that the components of ##v^a## and ##t^a## are ##(v^0,0,0,0)## and ##(t^0,t^1,t^2,t^3)##.
In this basis ##v_at^a=v^0t^0 \Rightarrow (v_at^a)^2=(v^0)^2(t^0)^2##. Since ##t^a## is unit timelike we get ##(t^0)^2 > 1## then ##(v_at^a)^2 > (v^0)^2 = v_av^a##.
Note that in the above we are assuming ##v^a## and ##t^a## not collinear otherwise ##s^a=0##.
Let ##(a^{\mu})## be a time-like future-pointing vector, i.e., ##a_{\mu} a^{\mu}=(a^0)^2-\vec{a}^2>0##, ##a^0>0##, and ##(b^{\mu})## a vector with ##a^{\mu} b_{\mu} =a^0 b^0-\vec{a} \cdot \vec{b}=0##. Then ##(b^{\mu})## is spacelike. We have
$$b^0=\frac{1}{a^0} \vec{a} \cdot \vec{b} <\frac{1}{|\vec{a}|} \vec{a} \cdot \vec{b} \leq |\vec{b}| \; \Rightarrow \; b^0<|\vec{b}| \; \Rightarrow \; b_{\mu} b^{\mu} =(b^0)^2-\vec{b}^2<0,$$
i.e., ##(b^{\mu})## is spacelike, as claimed.
If ##(a^{\mu})## is past-pointing you can use the same argument with ##(-a^{\mu})##, i.e., if ##(b^{\mu})## is Minkowski-orthogonal to an arbitrary time-like vector, it's necessarily space-like.
Why two cases (futur-poiniting and past-pointing) for the timelike vector ##a^{\mu}## ? Assuming it is timelike we always have ##
a_{\mu} a^{\mu}=(a^0)^2-\vec{a}^2>0## so the above argument does not change, I believe.
Well, yes. You can divide by ##|a^0|## in the first step of my proof, i.e., using
$$|a^0 b^0|=|\vec{a} \cdot \vec{b}| \; \Rightarrow \; |b^0|=\frac{1}{|a^0|} |\vec{a} \cdot \vec{b}|<\frac{1}{|\vec{a}|} |\vec{a} \cdot \vec{b}| \leq |\vec{b}| \; \Rightarrow \; |b^0|^2-|\vec{b}|^2=b_{\mu} b^{\mu}<0.$$
