Can a Pendulum-Spring System Achieve Linear Motion with Matching Periods?
  • Thread starter Thread starter Doc37
    Shm System
23 replies · 11K views
Doc37
Hey,
I have a debate that needs to be resolved. Here is the diagram of the problem and I will describe below:
It is essentially a string that has a spring attached to the bottom with a weight of mass m attached to the spring. This is system is pulled back and released. Is it possible that if the period of both spring and the pendulum in simple harmonic motion are matching, that the weight of mass m will travel linearly, i.e. the spring will compress and expand at a rate that the weight is neither raised nor lowered by the system. Is this possible even on a theoretical level? When I work think about it, it seems like it should be possible to get a spring and a pendulum to both oscillate in such a way that the weight travels in a straight line. Maybe not, but I thought I would run it by some experts to get your opinions. If you need more information just respond to this letting me know and I can answer any questions you might have.
Thanks in advance for any help.
My intuition says no. Since the mass remains at a constant potential energy, there is no exchange between potential and kinetic energy to drive the system. This mode of motion could not be sustained.
And, at "time 2" the spring should be more streched than at times 1 and 3 because at time 2, more centripetal force is in the direction of the spring.
I find that under the condition that the spring constant exactly equals the weight of the mass divided by the length from mass to pivot (when mass is at the centre of its stroke), then vertical forces exactly cancel and there is no up-down movement.
In answer to Integral, the potential energy is in the spring, no longer in the gravitation.
Also, the diagram is wrong, since the spring will remain in line with the string.
I was concerned that the motion might not be close to simple harmonic -
but the acceleration goes as tan(theta) , so it's pretty good.
For the spring Force's vertical component to equal Earth's gravity Force,
then F_spring cos(theta) = ks cos(theta) = mg .
Modelling the spring as a Hooke's law spring with relaxed length R,
the mass is at (R+s) cos(theta) = L (constant) below the pivot,
so the stretch must be s = L/cos(theta) - R = (mg/k)/cos(theta).
For this to be valid at all theta, R must be zero, and k = mg/L .
A relaxed length of zero can be simulated by putting the mass on a string,
guided over a pulley to the spring, which is relaxed when the mass is at the pivot.
m a = F_spring sin(theta) = -(mg/cos(theta)) sin(theta) = - mg tan(theta) .
Daniel_i_l : a straight-line path does not curve around any "center",
so the direction of a center is undefined; can't take Force components in the direction of it. The closest you can do is to look at Force components
perpendicular to the velocity (that is, vertical Force components).
Wait a minute, from your replies I see that you think that the spring is on the same line as the string. In the picture it looks like the spring was held from the top and released with the spring facing down.
So, in the "time 1" position, only gravity pulls the spring down and
Fh - mg =0,
but as it gets to "time 2" the spring is hanging is line with te string and:
Fh - mg = 1/2mv^2
any way during the whole trip there's atleast mg pulling on the string so how could it ever get shorter than it was at "time 1" ?
Even if it was released in this fasion, in 'time3' the spring and the string should align unlike shown in the picture.
Still we can ask the question, between stage1 and stage 2, will the mass m remain horizontal. If you consider the mass and the spring as one whole unit, say mass M, it is now like a simple pendulum with a mass M at its end. What upward force is acting on 'M' which result in the comression of the spring? we know mg is downward. I don't see any upward forces. Therefore I believe the mass level will be lower than that of stage 1.
It is not hard to do this experiment. You need to choose a spring of known k and choose the string length such that the periods match as stated in the problem. Would be interesting.
Gamma.
Well, the equation of motion for the pendulum is:
[tex]\ddot{\theta}+\omega _0 ^2 \sin{\theta} = 0[/tex]
so the solutions aren't simple sinusoidal unless you take the small angle approximation. So maybe it would work for small angles, but even then it wouldn't be exact.
I thought a bout it some more and now I'm sure that it can't happen. For one thing - the energy problem - for the spring PE to turn into KE, the spring has to be less compressed when it gets to "time 2", this is impossible, there is no force that would "push" the mass up, if anything the greater tension at "time 2" would result with the spring being streched more, not less. Also, as mentioned, at "time 3" the spring would be in the same direction as the string, this means that for the mass to be at the same height the spring has to be longer tham it was at "time 1" - this clearly contridicts energy conservation.
That's for an ordinary pendulum whose length is constant. That's not the case here.
Say the length at centre is L, and when it is at angle [itex]\theta[/itex], it is longer by length e. Say the spring constant is k, so this adds a force ek in the direction along the pendulum. We want to arrange things so the resultant vertical force on the bob is zero, so it only moves horizontally. The total force is [itex]F_0+ek[/itex], where [itex]F_0[/itex] is the force when the pendulum is un extended, namely mg. Then the vertical force equation is
[tex]mg=(mg+ek)\cos\theta[/tex]
But from the geometry, it is clear that
[tex]\cos\theta={L\over L+e}[/tex]
Plug this into equation above, and you find e cancels:
[tex]mg=kL[/tex]
The fact that e cancels means that this balancing out of the vertical force will continue even as e changes with time. Which is what you want for the motion to continue horizontal.QED
[tex]mg=kL[/tex]
woops. thanks for the explanation
Oh krab, from you explanation I see that at time 1 the spring is streched past its equilibrium, if that is true than I see how it was possible, I was assuming that it was released from rest. I also see that unlike the picture, it is possible if the spring is released when it is on the same line as the string
In the drawing you can see that the tension tends to rotate the mass, both at points one and two in the motion, around the com, in such a manner that the point of application of the tension and the com are brought in line with each other.
In attachment 1 we are looking at the motion of the mass along the line of the string. It is experiencing two forces along the direction of the string, the [itex]W\cos(\theta)[/itex] component of its weight and the restoring force [itex]R[/itex] of the spring. This weight component varies between a minimum [itex]W_{min}[/itex] and maximum [itex]W_{max}[/itex] as the pendulum swings between its amplitudes [itex]\theta_A \ and \ -\theta_A[/itex] as shown in attachment 2. As the component of the weight therefore varies between its minimum and maximum values the mass will therefore oscillate along the line of the string with amplitude [itex]A[/itex]. The pendulum will therefore be at its longest when at [itex]\theta=0[/itex] with a length of [itex]l+A[/itex] and at its shortest when at [itex]\theta_A \ and \ -\theta_A[/itex] with length [itex]l-A[/itex] - see attachment 1. The position of the mass as it swings to and fro will therefore be as showm in attachment 3. Clearly it is not possible for it to stay on the same level during its swing.
The mentioning of amplitudes A in my previous post implies that the motion of the mass along the line of the string is SHM, something that I did not investigate. Therefore one should rather think of a single extension of the spring from the the one extreme position to the other. The rest I stand by unless someone is so kind as to convince me otherwise.
[tex]mg=kL[/tex]
Wow, I disappear due to the holidays and a big discussion ensues. I appreciate everyones input into this question. From what I see, there are two differing opinions between krab and andrevdh. Looking at both of the explanations krab makes the most sense to me. I find it interesting though because it is two different approaches to the same problem and it seems that two different answers resulted. Any thoughts from anyone on who they think makes the most sense?
The problem I have with krab's remark that the total force is [itex]F_o+ek[/itex] is that he is forcing the pendulum to get longer as it swings up from [itex]\theta=0[/itex] (which is what is required if the mass is to stay on the same height), but will this be the case in real life? As I see it the spring responds to the component [itex]W\cos(\theta)[/itex] of the weight. As this component decreases as the pendulum swings up from the bottom the spring will respond by contracting, not extending.
The Tension in a spring depends on its stretch (it does not "respond to" external Force components except via its stretch).
The original post asked whether horizontal motion was possible, which is what krab and I have answered. There are conditions on the apparatus (must arrange for spring with zero effective length) and on initial conditions (v=0 at L = mg/k), which have been mentioned in the posts.
It is most straight-forward to analyze straight-line using rectangular coordinates, not circular coordinates.
There are certainly other motions of a mass-on-spring that are possible!
Hang a mass from a long spring, bouncing around its vertical equilibrium.
Adjust the length (with string, if necessary) until a small-angle swing angular frequency [tex]\omega_h[/tex] is ½ of the vertical angular frequency [tex]\omega_v[/tex] .
Now displace the mass by a small angle, and a small distance downward, before letting go. The mass will peak at the center, and have lowest heights at each end of the swing.
Or displace by a small angle, and a small distance upward, before letting go. The mass will peak at the ends of the swing, and be lowest in the center.
The horizontal path asked about in this thread is, in a sense, halfway between these two initial conditions.
Oh, I see the motion have much more interesting possibilities than I originally thought. Another mistake I made is reasoning with Newton's laws in a noninertial frame of reference - the motion along the line of the pendulum is in an accelerating system.
Wow these conditions are however tough to replicate in real life. I tried to do it last weekend but i couldn't get it to work. Really close a couple of times but nothing exact, it seems to me that period definitely plays into it, the couple of times it seemed good it would all of a sudden become out of whack in the 2nd, 3rd, 4th, etc. passes. You guys have any insight on this problem?
So I think we might have a problem with the solution. In real world applications. I have a hunch that the proposed solutions only work if they are a simple pendulum with no mass for the string. If we are to take this into the real world where very few actually are "massless", I think the solution breaks down due to the period:
The first thing I did was find the period of a spring-mass system:
T = 2(pi)*sqr(m / k)
Use the equation from the solution to substitute for k (k=(mg)/L):
T = 2(pi)*sqr(m / ((mg) / L))
T = 2(pi)*sqr(L / g)
That right there is the period of a simple pendulum. The problem is that I could probably never recreate a simple massless pendulum.
Therefore I solved for the period of a physical pendulm:
T = 2(pi)*sqr(I / (mgh))
(Rod) (Point Mass)
I = (1/3)(m1)L^2 + (m2)L^2
(m1)+(m2) = m now known as M
T = 2(pi)*sqr( (L^2)( (1/3)(m1) + (m2) ) / (MgL) )
T = 2(pi)*sqr( (L)( (1/3)(m1) + (m2) ) / (Mg) )
I do not think this will equal therefore I do not think this situation will occur unless the pendulum is massless. Am I correct or am I wrong?
You seem to be thinking of L as the average length of a swinging pendulum ...
it is NOT ... instead, L is the minimum length of the swinging pendulum.
We do NOT want the spring oscillation period to EQUAL the swing period ...
instead, we want the spring oscillation period to be HALF the swing period.
But you have to use the REAL oscillation periods:
swinging pendulum using the average of its (varying) length
spring oscillator, including the portion of the spring that moves (1/3?)
A simple pendulum is always just an approximation to Reality.
Similarly, treating a spring as massless is only an approximation.
We model real situations with such fictions because
1) they make the math easy enough to actually solve (if you try)
2) the solutions point out aspects of the situation (zero-length spring)
3) the corrections to them can often be estimated simply.
For example, if you have a real spring that has mass and is not zero-length,
the period of swinging will be shorter than the approximate period,
while the period of spring oscillation will be longer that the approximation.
The difference in periods means that in-step will get out-of-step : "beats".
