Can a polynomial have an irrational coefficient?
36 replies · 8K views
barryj
can a polynomial have an irrational cooeficient?
is this is poloynomial? y = x^2 + sqrt(5)x + 1
Is this a polynomial? y = x^2 + sqrt(5)x + 1
I was told NO, the coefficients had to be rational numbers. I this true?
It seem to me this is an OK polynomial.
I can graph it and use the quad formula to find the roots? so why or why not?
It is a polynomial over the reals. The only time it would not be called a polynomial is if the coefficients were specifically specified as restricted to rational numbers. That is when you would specify that it is a "polynomial over the rationals". In general, given a field, ##F##, you can talk about "polynomials over the field ##F##" when the coefficients are required to be in the field ##F##. (see http://mathonline.wikidot.com/polynomials-over-a-field )
PS. It is even common to have polynomials with complex coefficients. They would be called "polynomials over the complex numbers".
barryj said:
Homework Statement:: can a polynomial have an irrational cooeficient?
Relevant Equations:: is this is poloynomial? y = x^2 + sqrt(5)x + 1
Yes, in modern mathematics the coefficients may be any real number. In Medieval times, the coefficients had to be rational. Here's the history of it:
https://www.cambridge.org/core/jour...ance-algebra/38391278E789631131A9F9BFC4DC8B0B
I had a homework problem that asked , given these roots, 3i, -3i, and (sqrt)5 , what is the smallest degree polynomial could I have. I said degree 3, a cubic. It can be found by multiplying the three factors...
(x+3i)(x-3i)(x-(sqrt)5) = x^3 -(sqrt)5x^2 + 9x - 9(sqrt)5
This polynomial has a coefficient of (sqrt)5 and the teacher said it was wrong??
Yes? I know, I need to learn to use Text.
Thank you for confirming what I thought was correct.
This is an Algebra 2 class.
I do not think the term "polynomial over rationals" has been mentioned.
In LaTeX this is ##(x + 3i)(x - 3i)(x - \sqrt 5) = x^3 - \sqrt 5 x^2 + 9x - 9\sqrt 5##
The raw, unrendered script looks like this:
One coefficient is ##-\sqrt 5## and another is ##-9\sqrt 5##. I don't know why your teacher said it was wrong.
That's Tex, not Text. Take a look at our LaTeX Guide -- the link is in the lower left corner.
I think that the concept of "polynomials over rationals" (or over any other field) is a subject for Abstract Algebra and would not be mentioned in Algebra 2.
I believe it's quite common among maths students (and possibly high-school maths teachers) that coefficients such as ##a, b, c## represent whole numbers. And, quite erroneously, they believe that, for example:
$$x^2 + 2\pi x + 1 = 0$$ is not a valid quadratic equation.
PS they allow rational coefficients because you can multiply by a suitable factor to make all coefficients whole numbers.
  • Wow
I just remembered something from 40 years ago! When I was a maths student, we were given the question to find a quadratic equation with ##\pi## as a root. This stumped many in the class, because they were only trying whole numbers for the coefficients.
In those pre-Internet days we had never heard of a "transcendental" number.
And, I think I saw something a few years ago about a study that found that many maths students through that ##a, b, c## must be whole numbers.
  • Wow
Do you remember what level the students were at? I would think that it must be a beginning level.
FactChecker said:
I agree with your answer. The only reason I can imagine that the teacher would object is if he specified somewhere that the polynomial was over the rationals.
"Minimum degree of a polnomial with [itex]n[/itex] distinct roots" is going to be [itex]n[/itex] unless "with rational coefficients" or similar is specified, in which case other rationalizing factors may be necessary and the problem is no longer trivial.
That's not a function, that is a relation. And I don't see how you can multiply this by anything to make all coefficients rational, algebraic, or whole numbers. 🤔
Edit: I misinterpreted you last part, but most of my last point I think is right... Maybe?
Sorry, I don't understand what you mean.
I mean how can one multiply through to make a non whole number go away?
PeroK said:
Multiply by the LCM of the denominators of the coefficients. Or, any common multiple thereof.
But that may work for certain cases of expressions, but not functions... I guess that was my initial thought. Not that I disagree with the concept.
Shoot, what I'm thinking is that you can write a (say) quadratic equation or relation with any real coefficients. For all cases, I don't see a relation that would lead to all coefficients necissarily being whole numbers.
I guess you are speaking about rational numbers...
PeroK said:
Yes. Polynomials with rational coefficients are essentially the same as Polynomials with integer coefficients.
I got off track from your specific example... No reason that can't be a polynomial either. 👍
What @PeroK posted (post #9) was an equation; namely ##x^2 + 2\pi x + 1 = 0##, so your comment above is a bit bewildering.
Well I guess my line of thinking was that it's a bit different multiplying both sides by a factor when one side equals zero.
That registers high on my bewilderment scale!
  • Love
No, it's not different. If some expression = 0, then k times that expression = k * 0 = 0.
Why? A quadratic relation has at most two exact solutions. A quadratic function has infinite many "solitions".
  • Skeptical
The difference in treating a relation vs an edit: equation function
And sorry, I'm using the wrong terminology. I should say equality, not relation.
valenumr said:
The difference in treating a relation vs an equation.
This is irrelevant here. @PeroK explicitly wrote an equation and described it as such. There was no mention of either a function or relation.
What PeroK was talking about was the difference between an equation such as ##x^2 + \frac 3 2 x + 5 = 0## on the one hand, vs. his example of ##x^2 + 2\pi x + 1 = 0##.
The first equation can be converted to the equivalent equation ##2x^3 + 3x + 10 = 0## by multiplying both sides of the equation by 2.
The second equation cannot be converted to a quadratic equation with integer coefficients.
