Can Air Really Block Our View of the World?
  • Thread starter Thread starter Dremmer
    Air
The discussion revolves around the visibility of air and the conditions under which it can be perceived. Participants explore the nature of light interaction with air, including scattering and refractive effects, and consider evolutionary aspects related to human vision. The scope includes conceptual reasoning and technical explanations related to optics and atmospheric science.
  • Some participants suggest that air is not visible unless it is opaque, while others argue that we can see air through its refractive effects, such as shimmering over hot surfaces.
  • One participant claims that humans are evolved not to see air, and that phenomena like mirages are due to changes in the refractive properties of air rather than direct visibility of air itself.
  • Another viewpoint emphasizes that light scattering in the atmosphere, such as the blue sky, indicates that air can be seen under certain conditions, as it scatters light more than other wavelengths.
  • Some participants discuss the visibility of air in relation to its refractive index and how it differs from other materials like water or glass, which can be seen due to their reflective properties.
  • There is mention of the evolutionary adaptation of human vision to perceive light in the solar spectrum, suggesting that if the atmosphere were more opaque, our perception of the environment would be significantly different.
Participants express differing views on whether air can be seen directly or only through its effects on light. There is no consensus on the nature of visibility concerning air, with multiple competing perspectives presented throughout the discussion.
Limitations include the dependence on definitions of visibility and the conditions under which light interacts with air. The discussion does not resolve the complexities of how air's refractive properties influence perception.
Dremmer
Would we be able to see anything else? Or would the air just block out the view of anything else?
Biology news on Phys.org
Only if it were opaque. Actually, you are seeing air when objects appear to waver when viewed over a hot surface.
Actually, we are evolved not to see air. Mirages and shimmering over heat sources are not "seeing" air - they are effects of changes in the refractive properties of air.
What does it mean to be able to see an object? It means that we can detect the light that is reflected by that object. In the case of very sparse gasses like air, the amount of light reflected (scattered) by the object is very small but still detectable. For example, if you look up at the sky and see that it is blue, you are seeing the air; the blue light is scattered by the air to a greater extent than the shorter wavelengths, so the sky appears more blue than other objects around it.
Now if you were to concentrate the air, it would be much easier to see the light reflected by the air. This is actually possible; air is mostly nitrogen and if you liquify nitrogen, you can see the nitrogen as clearly as one would see any other liquid like water.
Perhaps you argue that we similarly can't see water or glass?
We can see these materials because they differ in refractive index from air, and exhibit some reflectivity at their surfaces. The way we "see" air is primarily from refractive effects due to temperature gradients. Go out at night and look at stars that twinkle. Are you "seeing" air, or are you seeing the effects of temperature gradients in air on the light-path from the star to your eye?
I'm seeing regions of differing refractive index. Those regions are composed chiefly of, well, air.
You can see air quite easily by looking at a daytime blue sky. Although it is apparently quite transparent the scattered blue light overwhelms the dimmer star light, at least to our eyes. So you can see air, but you need many miles of it and good lighting.
Maybe you'd have to consider it from another angle. The sun produces a certain frequency band of the electromagnetic spectrum, for which the mixture of gasses, which is called atmosphere, happens to be reasonable transparent. Evolution took advantage of that by develloping sensors aka eyes, which are the most sensitive in the center of that frequency band.
Should the atmosphere have been more opaque for the solar spectrum then we would have seen eternal fog.
http://en.wikipedia.org/wiki/Transparency_and_translucency
We can 'see' the air indeed sometimes when simmering hot and cold air mix with have differenrent refraction indexes, causing 'simmering' distortions of the background and mirages.
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 26 ·
19K
