Can computers understand?Can understanding be simulated by computers?
  • Thread starter Thread starter quantumcarl
    China
201 replies · 21K views
Please excuse the lack of links for each of the descriptors associated with "understanding" in my post.
Somehow I have lost the ability to edit and parce links. I, personally don't parce why this is happening and I've had no time to utilize my program X to find out.
May the electricity be with you at a moderate price!
Spooky All Hallow's Eve!
MF said:
To say that "understanding is a process" is not the same as saying that "all processes possesses understanding". It simply means that "being a process" is necessary, but not sufficient, for understanding. This would explain your "an abacus does not understand" position.
I agree competely. It is exactly this that makes me reconsider the idea that a calculator could potentially be considered to possesses understanding. The simple fact that it utilizes a process does not mean it understands. Agian I'm not sure exactly how a calculator's program works but if it is really just a more complex version of what a slide rule or abacus does then it would say that it does not understand.
MF said:
I agree that designed agents can and do reflect to some extent the understanding of the designer. But is this the same as saying that "no designed agent can be said to understand"? I think not.
Again I agree. I would not argue that any designed agent can only reflect understanding. I only argue that this "passive understanding" may better be described as "reflected understanding". The designer or teacher has done the work of "actively understanding" and deriving information based on this. The designer or teacher then passes the information on to a device or pupil. The device or pupil may be capable of coveying the information on to yet another agent but the information is not necessarily "understood" by any of the sucessive agents that may memorize and transmit it. In this case I would prefer to consider that the agents reflect the understanding of the information's progenitor rather than possesses any sort of understanding themselves. The logic here does not preclude the ability of a device or pupil to "actively understand" it only changes the concept of "passive understanding" to what I personally think is a more logical conception of what is occurring.
Tisthammerw said:
You implied it when you said that you do not agree that my statement was analytic statement and did not agree with my definitions.
“Y does not agree with X” is not synonymous with “Y thinks X is wrong”.
There are such things as “matters of opinion”. You and I may have different opinions on some issues (such as the definition of understanding), which means that “we do not agree on the definition of understanding”, but does NOT mean that one of us is necessarily “wrong”.
Tisthammerw said:
In these circumstances, “disagree” usually means believing that the statement in question is false.
I disagree. I thought that we already established that definitions of words are normally not things that can be “true” or “false”….. or are you now changing your mind?
Tisthammerw said:
Why is the fact that other people use different definitions of the terms make the statement “understanding requires consciousness” synthetic?
The answer is given already in my previous post. Because
moving finger said:
it is NOT clear that all possible forms of understanding DO require consciousness
As I pointed out several times already, two people may not be able to agree on whether a given statement is analytic or not if those two people are not defining the terms used in the statement in the same way. Do you agree with this?
Tisthammerw said:
The only sense I can think of is that what definitions a person is using must be determined by observation, but once that is done (e.g. in my case) “understanding requires consciousness” becomes analytic.
To my mind, whether or not “understanding requires consciousness” needs to be determined by observation. Thus the statement is indeed synthetic.
moving finger said:
How do I know whether the computer you have in mind is acquiring, interpreting, selecting, and organising (sensory) information?
Tisthammerw said:
Because I have described it to you.
In fact you did NOT specify that the computer you have in mind is interpreting the data/information. Interpreting is part of perceiving.
Tisthammerw said:
I am merely pointing out that my definitions are not the ones that are unconventional.
My definitions can also be found in dictionaries, scientific textbooks, encyclopaedias and reference works. Just because I do not use the same dictionary as you does not mean my definitions are unconventional. In psychology and the cognitive sciences, the word perception (= the act of perceiving) is usually defined as “the process of acquiring, interpreting, selecting, and organising (sensory) information”. It follows from this that “to perceive” is to acquire, interpret, select, and organise (sensory) information.
Tisthammerw said:
Are you saying an entity can “perceive” an intensely bright light without being aware of it through the senses?
I have already answered this in a previous post, thus :
moving finger said:
I am not saying this, where did you get this idea?
Tisthammerw said:
Programs are nothing more than set of instructions (albeit often a complex set of instructions). Bob is not an instruction, he is the processor of the program X.
What makes you think that a person is anything more than a “complex set of instructions”?
Tisthammerw said:
Can a computer (the model of a computer being manipulating input via a complex set of instructions etc.) have TH-understanding?
If the computer in question is conscious, then yes, it can (in principle) possesses TH-Understanding.
Can you show that no possible computer can possesses consciousness?
Tisthammerw said:
If what you say is true, it seems that computers are not capable of new understanding at all (since the person in the Chinese room models the learning algorithms of a computer), only “memorizing.”
This does not follow at all. How do you arrive at this conclusion?
It is not clear from Searle’s description of the thought experiment whether or not he “allows” the CR to have any ability of acquiring new understanding (this would require a dynamic database and dynamic program, and it is not clear that Searle has in fact allowed this in his model).
I am simply saying that memorising is not synonymous with understanding. This applies to all agents, humans as well as computers.
MF
MovingFinger said:
How does MF know whether the agent Tournesol understands English? The only way MF has of determining whether the agent Tournesol understands English or not is to put it to the test in fact the Turing test -fann to ask it various questions designed to test its understanding of English. If the agent Tournesol passes the test then I conclude that the agent understands English.
Why should it be any different for a machine?
Because there is another piece of information you have about me: I have a
human brain, and human brains are known to be able to implement semantics,
consciousness, etc. Silicon is not currently known to -- it is not known
not to , it just not known to.
I am not suggesting that Turings test is definitive. But in the absence of any other test it is the best we have (and certainly imho better than defining our way out of the problem). I am sure we would all love to see a better test, if you can suggest one.
If you reject the Turing test as a test of machine understanding, then why should I believe that any human agent truly understands English?
The TT is more doubtful in the case of a machine than that of a human.
You are missing another point as well: the point is whether syntax is
sufficient for semantics. What fills the gap in humans, setting aside
immaterial souls, is probably the physical embodiment and interactions
with the surroundings. Of course,
any actual computer will have a physical embodiment, and its
physical embodiment *might* be sufficient for semantics and cosnciousness.
However, even if that is true, it does not mean the computer's
possession of semantics is solely due to syntactic abilities,
and Searle's point is still true.
Whether it is a valid analytical argument depends on whether the definitions it relies on are conventional or eccentric.
Conventional by whose definition? Tournesols?
In rational debate we use words as tools so long as we clearly define what we mean by the tools we use then we may use whatever tools we wish.
Redefine "fanny" to mean "dick" and your auntie is your uncle.
yes, by definition. That is the difference between understanding, and instinct intuition, etc. A beaver can buld dams, but it cannot give lectures on civil
engineering.
I cannot report that I know anything if my means of reporting has been removed.
A beaver might in principle understand civil engineering, but it can't give lectures if it cannot speak.
Are you seriously asserting that the only think that prevents a beaver from lecturing on civil
engineering is its lack of a voicebox ?
You don't seem to have an alternative.
Consciousness imho is the internal representation and manipulation of a self model within an information-processing agent, such that the agent can ask rational questions of itself, for example what do I know?, how do I know, do I know that I know?, etc etc. The ability of an agent to do this is NOT necessary for understanding per se,
That depends on what you mean by "understanding".
The question is whether syntax is sufficient for semantics.
Im glad that you brought us back to the Searle CR argument again. Because I see no evidence that the CR does not understand semantics
Well, I have already given you a specific reason; there are words in human languages which refer specifically to sensory experiences.
Why do you consider this is evidence that the CR does not understand semantics? Sensory experiences are merely conduits for information transfer, they do not endow understanding per se, much less semantic understanding.
There are terms in language with specifically sensory meanings, such as "colour", "taste", etc.
given the set of sentences.
"all floogles are blints"
"all blints are zimmoids"
"some zimmoids are not blints"
[ ... etc ... ]
This type of misunderstanding can happen between two human agents. There is nothing special about the CR in this context.
That's the point! There is nothing special about the inability of the CR to derive semantics from syntax, since
that is not possible in general.
Now, the point you should be arguing is that the CR does in fact have semantics; you need to show
that it is an *exception* to the general rule.
Agreeing that its specific inability to grasp semantics through syntax
is an instance of a general rule is not mounting an argument
against the CR -- it is tantamount to accepting the CR.
This argument does not show that the CR does not understand semantics, it shows only that there may be differences between the semantics of two different agents.
If there is a difference between two agents, each is failing to grasp the semantics of the other.
Although they agree on syntax. So why should the CR specifically be able to avoid that problem ?
Human agents are likely to do so using their embededness in the world -- "*this* [points] is what I mean by zimmoid"--
but the CR does not have that capacity.
= more than one semantic model can be consistently given to
the same symbols.
This type of misunderstanding can happen between two human agents. There is nothing special about the CR in this context. This argument does not show that the CR does not understand semantics, it shows only that there may be differences between the semantic understanding of two different agents.
So..are you saying that the CR has the wrong semantics, and that having the wrong semantics
counts as "understanding" in a way that having no semantics does ? And how does A TT
distinguish between having the wrong semantics and having no semantics (since the
symbol-manipulation is the same in each case ?) And *how* does the CR have the
wrong semantics, since it does not get them from syntax alone ?
Now the strong AI-er could object that the examples are too
simple to be realistic, and if you threw in enough symbols,
you would be able to resolve all ambiguities succesfully.
See above.
Why? You haven't said what it is that allows the CR to plug semantic gaps. Your observation
that there is nothing special about the CR's inability to derive semantics from syntax is
far short of a demonstration that Searle is wrong, and it actually *can* derive semantics from syntax ?
(Too put it another way: we came to the syntax/semantics distinction by
analysing language. If semantics were redundant and derivable from syntax,
why did we ever feel the need for it as a category?)
Who has suggested that semantics is redundant?
You have, in effect. If semantics can be derived from syntax, it is informationally redundant.
Using your logic, one might equally ask why do we have the separate concepts of programmable computer and pocket calculator both are in fact calculating machines therefore why not just call them both calculating machines and be done with it.
I am not saying that semantics is redundant as a term because it can be subsumed under some more
general term, in the way that "computer" can be subsumed under "calculating machine";
people who directly counter Searle's argument are effectively saying that semantic information
is redundant, since it can derived from syntactic information.
I have been consistently suggesting that establishing definitions is completely different to establishing facts. Defining a word in a certain way does not
demonstrate that anything corresonding to it actaully exists.
Excellent! Therefore we can finally dispense with this stupid idea that understanding requires consciousness because it is defined that way
Dreadful! Truths-by-definition may not amount to empirical truths, but that does not mean they
are emprical falsehoods -- or do you think there are no umarried bachelors ?
How can you establish a fact without definitions?
Ask yourself what are the essential qualities of understanding that allow me to say this agent understands avoid prejudicial definitions and and avoid anthropocentrism
You haven't shown how to do all that without any pre-existing definitions.
I am suggesting that no-one can write a definition that conveys the
sensory, experiential quality.
Experiential qualities are agent-dependent (ie subjective). Tournesols experiential quality of seeing red is peculiar to Tournesol subjective - it is meaningless to any other agent.
Even if that is true, it is a far cry from the argumentatively relevant point that "red" has no meaning.
And I don't see why it should be true anyway; if consciousness is generated by the brain, then anatomically normal
brains should generate the same qualia. To argue otherwise is to assume some degree of non-physicalism. Need I point
out the eccentricity of appealing to anti-physicalism to support AI?
This does not mean that writing the definition is impossible, it just means that it is a subjective definition, hence not easily accessible to other agents
The semantics of a phrase like "the taste of caviare" are easily supplied by non-syntactic means -- one
just tastes caviare. Are you saying we should reject the easy option , and stick to the hard-to-impossible one just to keep the semantics-is-really-syntax flag flying ?
I have denied that experiential knowledge is synonymous with understanding, I have NOT denied that experiential knowledge is knowledge
I have said that experiential semantics is part of semantics, not all of it.
As to your distinction between knowledge and understanding , I don't think it is
sustainable. To know what a word means is to understand it.
Your assertion assumes that vision is required for understanding. Vision provides experiential information, not understanding. I understand the terms X-ray and ultra-violet and infrared and microwave even though I possesses no experiential information associated with these terms. What makes you think I need experiential information to understand the terms red and green? The onus is on you to show why the experiential information is indeed necessary for understanding red and green, but not for x-rays or ultra-violet rays..
You need experience to grasp the semantics of "red" and "green" as well as other people, because
they base their semantic grasp of these terms on their experiences.
You don't need experience to grasp the semantics of "infra-red" and "ultra violet" as well as other people, because
they don't have appropriate experiences to base their semantics on.
You have no grounds to suppose that understanding X-rays is just understanding per se -- it is
only partial understanding compared to understanding visible colours.
It doesn't have any human-style senses at all. Like Wittgenstien's lion, but more so.
Information and knowledge are required for understanding, not senses.
You have conceded that experiential knowledge is knowledge.
If knowledge is required for understanding, as you say, experiential knowledge
is required for understaning. Since eperience is needed for
experiential knowledge, that means experience is required for
understanding.
However, I do not need to argue that non-experiential knowledge is not knowledge.
Why not - is this perhaps yet another analytic statement?
It doesn't affect my conclusion.
It affects whether your conclusion is simply your opinion or not
"Not-experiential knowledge is not knowledge" is not something
I need to assume, not something I am claiming, and not my opinion
(not that that matters).
Sigh..that is a very anthropocentric viewpoint.
ces.
AI needs to be anthropocentric..up to a point.
Humans acquire most of their information from their senses in the form of reading, listening etc the same information could be programmed directly into a machine.
We could copy the data across -- as in standard, non-AI computing-- but would that be sufficient for
meaning and understanding ? If a system has language, you can use that to cnvey
3rd-person non-experiential knowledge. But how do you bootstrap that process -- arrive
at linguistic understanding in the first place? Humans learn language through interaction
with the environment. As the floogle/blint/zimmoid argument shows, you cannot safely
conclude that you have the right semantics just because you have the right syntax.
An AI that produce the right answers in a TT might have the worng semantics or no semantics.
The fact that humans are so dependent on sense-receptors for their information gathering does not lead to the conclusion that understanding is impossible in the absence of sense-receptors in all possible agents.
And that argument does not show that syntax is sufficient for human-type semantics. Would a putative AI have
quite a different form of language to a human (the Lion problem) ? Then Searle
has made his case. Would it have the same understanding , but not achieved solely
by virtue of syntax ? Again, Searle has made his case.
It makes the point that ability to fly a plane is not synonymous with understanding flight
The ability is part of an understanding which is more than merely theoretical understanding.
What red looks like is not understanding it is simply subjective experiential information.
And you don't live in a house, you live in a building made of bricks with doors and windows.
What red looks like to Mary is not necessarily the same as what red looks like to Tournesol
Naturalistically , it should be.
The full meaning of the word "red" (remember, this is ultimately about semantics).
Your argument continues to betray a peculiar anthropocentic perspective.
Strong AI is about duplicating human intelligence -- it should be anthopocentric.
What makes you think that the experiential quality of red is the same to you as it is to me?
Physicalism. Same cause, same effect. Why do you think it isn't ?
If the experiential qualities are not the same between two agents, then why should it then matter (in terms of understanding semantics) if the experiential quality of red is in fact totally absent in one of the agents? How could such an agent attach any meaning to a term like "qualia" if it has no examples whatsoeve
to draw on.
I can understand semantically just what is meant by the term red without ever experiencing seeing red, just as I can understand sematically just what is meant by the term x-rays without ever experiencing seeing x-rays.
They are not analogous, as I have shown. You don't need experience to understand X-ray as well
as anyone can understand it because no-one has experience OF THAT PARTICULAR PHENOMENON, not
because experience in general never contributes to semantics.
I claim that experience is necessary for a *full* understanding of *sensory* language, and that an entity without sensory exprience therefore lacks full
semantics.
There is no reason why all of the information required to understand red, or to understand a concept cannot be encoded directly into the computer (or CR) as part of its initial program.
Yes there is. If no-one can write down a definition of the experiential nature of "red" no-one can encode it into a programme.
Now (with respect) you are being silly. Nobody can write down a universal definition of the experiential nature of red" because it is a purely subjective experience.
It is a subjective experience because no-one can write down a definition.
And that holds true without making the physicalistically unwarranted assumption that
similar brains produce radically different qualia.
There is a pattern of information in Tournesols brain which corresponds to Tournesol seeing red, but that pattern means absolutely nothing to any other agent.
SO you can't teach a computer what "red" means by cutting-and-pasting information (or rather data)
from a human brain -- because it would no longer make sense in a different context.
Note that data is not information for precisely that reason -- information is data that
makes sense in a context. You seem to have got the transferability of data mixed
up with the transferability of information. Information can be transferred,if the "receiving" context
has the appropriate means to make sense of the data already present, but how the CR is to
have the means is precisely what is at stake.
Again you are missing the point. Information is not synonymous with understanding (if it was then the AI case would be much easier to make!)
We can ask questions about how things look (about the "carriers" of information as opposed to
infomation itself) , and a system with full semantics needs to understand those questions.
In principle, no sense-receptors are needed at all. The computer or CR can be totally blind (ie have no sense receptors) but still incorporate all of the information needed in order to understand red, syntactically and semantically. This is the thesis of strong AI, which you seem to dispute.
Yes. No-one knows how to encode all the information. You don't.
Oh really Tournesol. Whether MF knows know how to do it or not is irrelevant.
Whether anyone else does is highly relevant:"No-one knows how to encode all the information".
You still haven't shown , specifically, how to encode experiential infomation.
I don't see why you seem to think its such a problem.
Information is information.
If that were true, you could write a defition of the
experiential nature of "red". You can't, so it isn't.
The interesting aspect of experiential information is that it has meaning only to the agent to which it relates. In other words the information contained in the experiential state of Tournesol seeing red only means something to the agent Tournesol, the same information means nothing (indeed does not exist) to any other agent.
Wrong on several scores. I would have no way of telling whether a detailed
description of a brain state was a description of a "red" or "green" quale,
even if it was my own brain. So the "everyone has different qualia" definition
of "subjectivity" you are appealing to -- which is contradicted by physicalism --
is not the same as the "explanatory gap" version, which applies even to one's own
brain-states.
When we staunchily remain steadfast in our separate and personal definitions of "understanding" we do not allow for any progress in the refinement of a "universal" and terminologically correct use of the concept or the word "understanding and the phenomenon it refers to.
It may be more constructive if we were to find, amongst ourselves, commonalities in our definitions that help us "reach an understanding" between all parties with regard to the meaning, definition and concept of the descriptor, "understanding".
1.) I propose that "understanding" is a result of a series of processes... not a process in itself. Understanding is a description of a plateau one reaches and from which one is able to continue in pursuit of other plateaus of understanding. (if you agree, please indicate by repeating the number of this proposal with an "agree" or "disagree" beside it. If in disagreement, please offer an explanation.
2.) Understanding is a result of cognitive processes. (agree or disagree)
Here are some secondary descriptors of the primary (in this case) descriptor "cognitive":
of, relating to, or being conscious intellectual activity (as thinking, reasoning, remembering, imagining, or learning words)
www.prostate-cancer.org/resource/gloss_c.html[/URL]
* Awareness with perception, reasoning and judgement, intuition, and memory; The mental process by which knowledge is acquired.
[PLAIN]www.finr.com/glossary.html[/URL]
* Refers to the ability to think, learn and remember.
[url]www.handsandvoices.org/resource_guide/19_definitions.html[/url]
* brain functions related to sense perception or understanding.
altweb.jhsph.edu/education/glossary.htm
* Relating mental awareness and judgment.
science.education.nih.gov/supplements/nih3/alcohol/other/glossary.htm
* Pertaining to the mental processes of perceiving, thinking, and remembering; used loosely to refer to intellectual functions as opposed to physical functions.
professionals.epilepsy.com/page/glossary.html
* Refers to a mental process of reasoning, memory, judgement and comprehension - as contrasted with emotional and volitional processes.
[PLAIN]www.into.ie/downloads/gloss1.htm[/URL]
* Pertaining to cognition, the process of being aware, knowing, thinking, learning and judging.
[url]www.memorydisorder.org/glossaryterms.htm[/url]
* thought processes
[PLAIN]www.macalester.edu/~psych/whathap/UBNRP/synesthesia/terms.html[/URL]
* relating to or involving the act or process of knowing, including both awareness and judgement. Cognition is characterized by the following: attention, language/symbols, judgement, reasoning, memory, problem-solving.
[PLAIN]www.inspection.gc.ca/english/corpaffr/publications/riscomm/riscomm_appe.shtml[/URL]
* Pertaining to functions of the brain such as thinking, learning, and processing information.
[PLAIN]www.azspinabifida.org/gloss.html[/URL]
* Thinking, getting, evaluating and synthesizing information.
oaks.nvg.org/wm6ra3.html
* in cognitive psychology this is the component of attitude that involves perceptual responses and beliefs about something (knowledge and assumption)
[PLAIN]www.oup.com/uk/booksites/content/0199274894/student/glossary/glossary.htm[/URL]
* an adjective referring to the processes of thinking, learning, perception, awareness, and judgment.
[url]www.nutrabio.com/Definitions/definitions_c.htm[/url]
* Most neuroimaging studies in mood disorders are largely restricted to patients with MDD. Magnetic resonance imaging (MRI) studies demonstrate that patients with late-life MDD have smaller focal brain volumes and larger high-intensity lesion volumes in the neocortical and subcortical regions than control subjects. 102,103 The focal reductions in brain volume have been identified in the prefrontal region, hippocampus, and the caudate nucleus. ...
ajgp.psychiatryonline.org/cgi/content/full/10/3/239
* Having to do with a person's thoughts, beliefs, and mental processes including intelligence.
access.autistics.org/resources/glossary/main.html
* function, all the normal processes associated with our thoughts and mental processes.
[PLAIN]www.srht.nhs.uk/sah/Glossary/Glossary.htm[/URL]
* Teacher takes all the responsibility for the process and the result The input-output during a lesson get more and more complex Learners get involved in individual, pair and group activities A lesson is notable for a variety of diverse activities Learners' output is either a monologue or a dialogue learned by heart Communicative message is in focus Learners are positively dependent on each other Lexis and grammar are in focus Listening and reading are in focus Activation of thought processes ...
tsu.tmb.ru/millrood1/interact/modern_e/mel10.htm
* Mental ability to gain knowledge, including perception, and reason.
cgi.[PLAIN]www.care.org.uk/student/abortion/fs/fs11.htm[/URL]
* of or being or relating to or involving cognition; "cognitive psychology"; "cognitive style"
wordnet.princeton.edu/perl/webwn
* The term cognition is used in several different loosely related ways. In psychology it is used to refer to the mental processes of an individual, with particular relation to a view that argues that the mind has internal mental states (such as beliefs, desires and intentions) and can be understood in terms of information processing, especially when a lot of abstraction or concretization is involved, or processes such as involving knowledge, expertise or learning for example are at work. ...
en.wikipedia.org/wiki/Cognitive[/quote]
We may note that 99.9% of the above descriptors describe "mental" processes. Beliefs, reasoning, thought/mental process (this brings up the previously noted idea that the physics of the brain and the physics of a computer are vastly different and perhaps require vastly different terminology to distiquish the two different processes), awareness, judgement, thinking and intuition.
What I'm still trying to demonstrate is that terminology serves the purpose of distinguishing processes and states that belong in certain categories.
To use the word "understanding" to describe a set of data being stored in a computer (on or off) is like describing an "organelle" in an animal cell as an "organ". It is clearly an example of incorrect use of terminology.
If you want to write prose or poetry about a computer... you are more than welcome to use the word "understanding" to describe what a computer does. However, in the world of professionals, I believe there are more appropriate terms that apply to the digital domain.
Thanks.
But normally that is what is implied when it comes to philosophical discussions e.g. “I do not agree with ethical relativism.”
Yes we did, but at the time I was not aware you knew this.
It is not clear why “understanding is a synthetic statement” logically follows form this. “Synthetic” in this context means “something that can be determined by observation.” As I said before:
To which you reply:
Which really doesn’t answer my question why you believe it is synthetic. So far your argument is this:
  • People mean different things when they use the term “understanding.”
Therefore: whether understanding requires consciousness can be determined by observation.
It is terribly unclear why this is a valid argument, except for the sense that what definitions a person is using must be determined by observation, but once that is done (e.g. in my case) “understanding requires consciousness” becomes analytic.
Yes and no. Think of it this way. Suppose I “disagree” with your definition of “bachelor.” Does it then logically follow that “bachelors are unmarried” is no longer an analytic statement because we as two people do not agree on the term “bachelor”?
In fact I DID describe the computer I had in mind and I left it to you to tell me whether or not this scenario involves “interpreting the data/information” as you have defined those terms. To recap: I described the scenario, and I have subsequently asked you the questions regarding whether or not this fits your definition of perceiving etc.
Can they? You yourself use terms that are unclear (by what you mean by them) in part because you have refused to answer my questions of clarification.
Yes and no. Let me rephrase: under your definition of the term “perceive,” can an entity “perceive” an intensely bright light without being aware of it through the senses?
Because people possesses understanding (using my definition of the term, what you have called TH-understanding), and I have shown repeatedly that a complex set of instructions is insufficient for TH-understanding to exist.
Given the computer model in question, I think I can with my program X argument (since program X stands for any computer program that would allegedly produce TH-understanding, and yet no TH-understanding is produced when program X is run).
As I said earlier, because the man in the Chinese room models a computer program. I can also refer to my program X argument, in which case there is no “new understanding” in this case either.
Again, the variant I put forth does use a dynamic database and a dynamic program. We can do the same thing for program X.
Part One of my reply :
consciousness, etc.
Not all human brains “implement semantics”.
A person in a coma is not “implementing any semantics” – a severely brain-damaged person may be conscious but may have impaired “implementation of semantics”.
I know that MF’s human brain “implements semantics”, but I have no evidence that any other brain, human or otherwise, does – apart from the evidence afforded by interrogating the owners of the brains – asking them questions to test their knowledge and understanding of semantics.
The solution to this problem is to try and develop a better test, not to “define our way out of the problem”
I’m not missing that point at all. Searle assumes that a computer would not be able to understand semantics – I disagree with him. It is not a question of “syntax being sufficient for semantics”, I have never asserted that “synatx is sufficient for semantics” or that “syntax somehow gives rise to semantics”.
That the AI argument is necessarily based on the premise “syntax gives rise to semantics” is a fallacy that Searle has promulgated, and which you have swallowed.
Once again – place me in a state of sensory deprivation, and I still understand semantics. The semantic knowledge and understanding is “encoded in the information in my brain” – I do not need continued contact with the outside world in order to continue understanding, syntactically or semantically.
I am not arguing that “syntax gives rise to semantics”, which seems to be Searle’s objection. I am arguing that a computer can understand both syntax and semantics.
I am saying that “possession of understanding alone” is not sufficient to be able to also “report understanding” – to report understanding the agent also needs to be able “to report”.
Goes without saying that we disagree on some definitions
Mary understands objectively everything there is to understand about “red”, but she has no subjective experiential knowledge of red.
MF claims that despite her lack of experiential knowledge, Mary nevertheless has complete semantic understanding of red.
Tournesol (presumably) would argue that experiential knowledge is necessary for full semantic understanding, hence there must be something which Mary “does not semantically understand” about red.
Can Tournesol provide an example of any sentence in the English language which includes the term “red” which Mary necessarily cannot “semantically understand” by virtue of her lack of experiential knowledge of red?
But sematics is not derived from syntax. Why do you think it needs to be? Because Searle wrongly accuses the AI argument of assuming this?
Again : Semantics is not derived from syntax.
There are many other ways of conveying and learning both meaning and knowledge apart from “pointing and showing”.
No, I’m saying that any two agents may differ in their semantic understanding, inlcuding human agents. Two human agents may “semantically understand” a particular concept differently, but it does not follow that one of them “understands” and the other “does not understand”.
Tournesol said:
And how does A TT
The rules of sematics, along with the rules of syntax, are learned (or programmed). Any agent, including humans, can incorporate errors in learning (or programming) – making one error in syntax or semantics, or disagreeing on the particular semantics in one instance, does not show that the agent “does not understand semantics”.
Tournesol said:
Your observation
Once again - I have never said that semantics is derived from syntax – you have said this!
Both syntax and semantics follow rules, which can be learned, but it does not follow that “one is derived from the other”. Syntax and semantics are quite different concepts. Just as a “programmable computer” and a “pocket calculator” are both calculating machines, but one cannot necessarily construct a programmable computer by connecting together multiple pocket calculators.
There you go again! I have never said that semantics is derivable from syntax, you have!
We may agree on the definitions of some words, that it does not follow that we agree on the definitions of all words.
There is a balance to be struck. You seem to wish to draw the balance such that “understanding requires consciousness by definition, and that’s all there is to it”, whereas I prefer to define understanding in terms of its observable and measurable qualities, and from there work towards discovering whether it is possible for a non-conscious agent to possesses those qualities of understanding. I am not saying your definition is wrong, just that I do not agree with it.
I never said that “red has no meaning”. But the “experiential knowledge of red” is purely subjective.
Tournesol – Really, if you wish to continue misquoting me there is not much point in continuing this discussion.
Why should it be the case that the precise “data content” of MF seeing red should necessarily be the same as the “data content” of “Tournesol seeing red”? Both are subjective states, there is no a priori reason why they should be identical.
Tournesol said:
Need I point
Need I point out that I have never appealed to such a thing?
Again you are either “making things up to suit your arguments”, or you are misquoting me.
One more time : I never said that “semantics is syntax”! You really have swallowed Searle’s propaganda hook, line and sinker!
“experiential knowledge of red” has nothing to do with “knowing what the word red means”. I know what the word “x-ray” means yet I have no experiential knowledge of x-rays.
What I see as green, you may see as red, and another person may see as grey – yet that would not change the “semantic understanding that each of us has of these colours” one iota.
Only “partial understanding”?
What then, do I NOT understand about X-rays, which I WOULD neceessarily understand if I could “see” X-rays?
understanding.
I have said that knowledge is necessary for understanding, but it does not follow from this that all knowledge conveys understanding.
Experiential knowledge is 100% subjective, it does not convey any understanding at all.
And once learned, all that data and knowledge is contained within the brain – there is no need for continued interaction with the environment in order for the agent to continue understanding. Thus interaction with the environment is simply one possible way of “programming” the data and knowledge that is required for understanding. It does not follow that this is the only way to program data and knowledge.
(see part 2)
MF
Part 2 :
Tournesol said:
you cannot safely
Wrong assumption again. I have never suggested that syntax gives rise to semantics.
In a poorly constructed Turing Test it might have, yes. Just as any human also might have. That is why we need to look at (a) trying to get a better understanding of just what understanding is (the qualities of understanding) with resorting to “defining our way” out of the problem and (b) improving the Turing Test
There you go again! I have never said that “syntax is sufficient for semantics” – this is a false assumption attributed to AI which is promulgated by Searle and his disciples.
has made his case.
Do you mean spoken language? Why would it necessarily be any different to an existing human language? Why would it necessarily be the same? What bearing does this have on the agent’s ability to understand?
Again, Searle’s case and yours is based on a false assumption – that AI posits syntax gives rise to semantics!
Ability is not necessarily anything to do with understanding. I can learn something “by rote”, and reproduce it perfectly – it does not follow that I understand what I am doing
I don’t need to “see” a house to understand what a house is.
I don’t need to “see” red to understand what red is
You have no way of knowing whether it is or not
Humans are also carbon based – does that mean all intelligent agents must necessarily be carbon-based? Of course not.
AI is about creating intelligence artificially. Humans happen to be just one example of a species that we know possesses intelligence, it does not follow that intelligence must be defined anthropocentrically.
There is reason to doubt, because you have no way of knowing if the effect is indeed the same (you have no way of knowing what red looks like to Mary).
I said “What red looks like to Mary is not necessarily the same as what red looks like to Tournesol”.
to draw on.
If I have never seen a house I can nevertheless attach a meaning to the word “house” by the way the word is defined and the way it is used in language and reasoning. I can attach a meaning to “x-rays” even though I have absolutely no experiential knowledge (no qualia) associated with x-rays whatsoever. I can do the same with the word “red”.
Maybe so – but as you recall, experiential knowledge is not part of understanding so it doesn’t really matter
I have simply cautioned you against the opposite unwarranted assumption – that the precise data connected with your experience of red is necessarily the same as the precise data connected with Mary’s experience of red.
Nor would you need to in order to impart understanding to the computer. Experiential knowledge has nothing to do with understanding, remember?
Good point. You could in principle transfer the precise data corresponding to “Tournesol sees red” into Mary’s brain, but it does not follow that Mary’s brain will be able to make any sense of that data. But as you recall, experiential knowledge is not part of understanding so it doesn’t matter anyway
What colour is a red object? Red. What is there to “understand semantically” about that which requires me to have experiential knowledge of “what red looks like”?
Once again, experiential knowledge has nothing to do with understanding
With respect, to suggest that “it is not possible because nobody yet knows how to do it” seems like a rather churlish and infantile argument. Nobody “knew how to construct a programmable computer” in the 18th century, but that did not stop it from eventually happening.
Again very churlish, Tournesol.
Just because “MF cannot do it” does not lead to the conclusion “it cannot be done”
The subjective experiential nature of red is different for each agent. There IS no universal definition – the experience is subjective. Do I need to explain what subjective means?
And besides all this, experiential knowledge is not part of understanding so it doesn’t matter (in the context of producing a machine with understanding) if nobody ever succeeds in writing it down anyway.
brain-states.
It is not “contradicted by physicalism”. Tournesol is not MF, therefore there is no reason to expect that Tournesol’s brain-states will be identical to MF’s brain states when both agents are “seeing red”.
Simply because I cannot write down a complete description of either of these brain-states does not lead to the conclusion that they cannot in principle be fully described physically.
Neither MF nor anyone else can accurately predict the weather, but there is no doubt in my mind that it is a deterministically chaotic process which is entirey physical.
MF
If you do not see a house or red (or a red house), you will never attain a complete understanding of red, house or red house. Experiencing the visual stimulus that is caused by a house or the colour red is part of completely understanding the colour or the structure.
In fact, humans are able to experience red without seeing the colour. This is because humans are comprised of cells and everyone of these cells reacts to colours in a photosensitive manner that releases hormones in the human body. Experiencing this hormonal release results in part of what I'd call the experiencial understanding of the colour red. Similarily, the hormonal reaction to seeing a house would entail about 2 million years of instinctual, hormonal and basic human reactions to the concept of attaining shelter.
It is by way of these processes that humans are able to experience and understand red in a way that is thouroghly separate and distiquished from the programmed or auto-programmed data-storage and physics of a computer.
As I have already pointed out, when professional computer scientists describe digital processes they are, or should be, bound by terminological protocol to distiquish these processes and results from biological processes and results to aggressively avoid confusion and the mis-directed trust of the lay-public.
Intellegence was defined by humans in the first place.
When it comes to digital computing we call it "artificial intelligence".
Yes, isn't it amazing? However, we can tell what red looks like to any computer because we built the things and we set up their parameter of definnitions. If we had built Mary, we'd know what red looked like to her. She does, however, have the ability to describe "red" to us using her unique "understanding" of the colour.
I maintain that an incomplete "understanding" is not "understanding" per sey. An incomplete understanding demonstrates a process that is working toward understanding. It may never be reached and there is no law that says it will be reached.
moving finger said:
Maybe so – but as you recall, experiential knowledge is not part of understanding so it doesn’t really matter.
The way I see it, all knowledge is experencial. I can't say this is true for computers because they do not "experience" as far as I know. I would maintain that understanding is fully dependent upon experience (with requires a form of consciousness).
Why do you keep saying this?
See what I've written about the effect of red on hormones... (in biologically active agents)
Repeating a false statement does not make it correct.
Actually, the idea of a programable computer stems from the mechanisms involved in "programming" a loom for weaving and this process dates from before the 1700s. Once a "card with holes in it" was introduced to facilitate a speedy programing of the loom, the path was clear for IBM to intervien... some 100 years later.
MF
These are weak arguments. The very fact that Mary and T are biological agents is enough to warrent the use of the word Understanding to describe their personal experiences of phenomena.
The only thing that warrents the consideration of using human terms and terminology to describe a machine's functions such as those in a computer is the fact that humans created computers. When we create something, we use our own impression of how we function to serve as a blueprint in our machines. However, this does not warrent confusing hourds of people with words that apply to subtle human interactions by applying them to the machines that a very small number of people have built.
I don’t need to “see” red to understand what red is.
"See" I believe has just been used as an arbitrary way in which to experience something but not the sole way in which to experience it as QC has pointed out that there are other fashions by which a person could gain experiencial knowledge either directly or indirectly with which to help them understand a concept. There are other senses other than sight.
But consider this. Imagine a person has been born with only one of five senses working. We'll say the person's hearing is the only sense available to it. None others what so ever. How would you go about teaching this person what the colour "red" is?
What do you “understand” about the “colour” of red simply by experiencing seeing red? You “know what red looks like for quantumcarl”, yes – but “knowing what red looks like for quantumcarl” is NOT “semantic understanding of red”. And “knowing what red looks like” tells you nothing about the “structure” of red - whatever that might mean).
“A picture paints a thousand words” – that is indeed a common expression in English.
All (ALL) of the “information” contained in any picture (visual image) can be reduced to a string of binary digits. A house is “defined” by the relational aspects of components such as door, windows, roof, etc. “What a house looks like” can be reduced to words, and also to mathematical language.
Granted that my 6-year old son has a “picture dictionary” with nice images of houses inside. Why? Because a young child “takes in more information, and more easily” through pictures rather than through words. This is clearly the case with children.
But my own dictionary does not use any pictures or visual images in its definitions of words. Why? Because images (though sometimes useful, especially for young people) are not essential to convey the meaning of words (ie to convey semantic understanding).
Suppose that Mary claims to possesses semantic understanding of the term “house”, but she has never seen a house. Presumably quantumcarl would say there is something missing from Mary’s semantic understanding of “house”.
What exactly is missing? What is it that Mary necessarily CANNOT understand about the term “house”, which she WOULD understand if only she could see a house? Would you care to tell us?
Does this “hormonal release” convey any semantic understanding to the human?
No.
“Hormonal reaction” is not “semantic understanding”
With respect, I suggest it is the “lay-public” confusion between “knowing what a colour looks like” (ie subjective “hormonal reaction” to use your phrase) and “knowing what a colour IS” (ie semantic understanding of the term) which is responsible for your own confusion here. These are two very different types of “knowing”.
In science, we have a duty to avoid lay-person-type confusion and to distinguish very carefully between the subjective “experiential knowledge of X” (which has nothing to do with semantic understanding of X) and the objective “definitional understanding of X”, which has everything to do with semantic understanding of X.
All human words are defined by humans. It does not follow that all words must be defined anthropocentrically (unless we deliberately wish to create an anthropocentric bias in everything).
With respect, if we create a computer which is able to “consciously and subjectively perceive the colour red” then we will have no way of knowing what that subjective experience is like for the computer, whether we “set up the parameters” or not.
Even if I know everything there is to know (objectively) about a bat, I can NEVER know “what it feels like” to be a bat, because “what it feels like” is purely subjective.
Why should this follow?
“Mary knowing what red looks like” is a subjective experience that is peculiar to Mary, nobody on the outside of Mary “knows what this is like for Mary”, only Mary does.
What does red look like? Can you describe “what red looks” like to someone who can only see shades of grey?
No.
Why? Because your subjective experience of “red” is peculiar to you, it has no objective basis in the outside world, it cannot be described in objective terms which another person can understand.
Have you shown that Mary has incomplete understanding of the term “red” simply because she has never experienced seeing red?
What Mary does not understand about red
Suppose Mary understands objectively everything there is to understand about “red”, but she has no subjective experiential knowledge of red.
Mary claims that despite her lack of experiential knowledge, she nevertheless has complete semantic understanding of red.
Quantumcarl (presumably) would argue that experiential knowledge is necessary for full semantic understanding, hence there must be something which Mary “does not semantically understand” about red.
Can quantumcarl provide an example of any sentence in the English language which includes the term “red” which Mary necessarily cannot “semantically understand” by virtue of her lack of experiential knowledge of red?
This simply betrays your anthropocentric bias again.
Objective knowledge is derived from information and the relational rules of that information (which in turn is also information). All information can be encoded into binary digits and “programmed” into an agent. Humans cannot be programmed (yet), therefore the only way they can acquire knowledge of or from the outside world is through their senses. But nevertheless I can still acquire a complete semantic understanding of the term “red” without ever seeing red.
As I said, this simply shows your anthropocentric bias.
Because it is true!
I have suggested a thought experiment (“What Mary does not understand about red” above) which would allow you to show (if you can) that experiential knowledge is a necessary part of understanding – can you do so?
Can you show that experiential knowledge is necessary for understanding (rather than simply saying that it is)? Can you answer the “What Mary does not understand about red” example above?
With respect, a weak argument is better than none at all.
My position is that I can “semantically understand” all there is to know about red without ever seeing red, and there has been no rational counter-argument provided!
All quantumcarl and Tournesol have been able to do is to assert the equivalent of “experiential knowledge is required for semantic understanding” – but this has NOT been shown to be the case! Where is your evidence that this is the case? Can you answer the “What Mary does not understand about red” example above?
quantumcarl said:
In the absence of any evidence, The very fact that Mary and T are biological agents is enough to warrent the use of the word Understanding to describe their personal experiences of phenomena.
This again shows a lay-person’s confused use of the word “know”. To “know what red looks like” is subjective experiential knowledge, it has nothing to do with semantically understanding what is meant by the term red.
If you genuinely believe that Mary needs to see red in order to understand what is meant by red, then please reply to the “what Mary does not understand about red” argument above
A more responsible and objective approach to scientific understanding of “understanding” would be to avoid anthropocentric bias at all costs.
MF
Agreed. The role of the senses as far as human semantic understanding is concerned is to convey information and knowledge about the world – the senses are merely conduits for information and knowledge transfer to the brain. If you like, they are the means by which we “program” our brains. But once the brain is programmed and we “understand” by virtue of the information and knowledge that we possess, then we do not need the senses in order to “continue understanding”.
That is a very good question – and it gets right to the heart of the matter, hence I will answer it fully so that we all might understand what is going on.
The confusion between “experiential knowledge” and “semantic understanding” arises because there there are two possible, and very different, meanings to (interpretations of) the simple question “what is the colour red?”
One meaning (based on subjective experiential knowledge of red) would be better expressed “what does the colour red look like?”. Let us call this question A.
The other meaning (the objective semantic meaning of red) would be better expressed as “what is the semantic meaning of the term red?”. Let us call this question B.
Now, TheStatutoryApe, which question have you asked above? Is it A or B? I will answer both.
A - “what does the colour red look like?”
What the colour red looks like is a purely subjective experiential brain state. I have no idea what the colour red looks like for TheStatutoryApe, I only know what it looks like for MF. I cannot describe in objective terms what this colour looks like. Can you? Can anyone? The best I can do is to point to a red object and to say “there, if you look at that object then you will see what the colour red looks like”, but that STILL does not mean that the colour red “looks the same” for TheStatutoryApe as it does for MF. And seeing the colour red is NOT necessary in order to convery any semantic understanding of the term “red”.
B - “what is the semantic meaning of the term red?”
The semantic meaning of the term red is “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. I do not need to be able to see red in order to understand from this definition that “this is what red is”.
Thus, it all depends on what your question is.
If you are asking “what does the colour red look like?”, then it is not possible for anyone to objectively describe this, and it is impossible to “teach” this to an agent who cannot “see” red. But “what the colour red looks like” has nothing to do with semantic understanding of the term “red”, which is in fact the second question. An agent can semantically understand the term “red” (question B) without being able to see “red” (question A).
This is a perfect illustration of the fact that we need to be very careful when using everyday words in scientific debate, to make sure that we are not confusing meanings.
MF
consciousness, etc.
That is a silly objection. Anyone I can actually speak to obviously has a
functioning brain. I am not going on their external behaviour alone; I have
an insight into how their behaviour is implemented, which is missing in the CR
and the TT.
I have already suggested a better test. You were not very receptive.
It would help if you spelt out what, IYO, the (strong) AI arguemnt does say.
Throughout this debate you seem to be assuming that there is some set of
rules that are sufficient for semantics. Above you reject the idea that
they are the same rules as syntax. Very well: let us call the thesis
you are promoting
"The Symbol Manipulation According to Rules Technique is sufficient for semantics thesis"
w is
or
"The SMART is sufficient for semantics thesis"
Where SMART is any kind of Symbol Manipulation According to Rules.
Note, that this distinction makes no real difference to the CR.
Searle uses "syntax" and "symbol manipulation" interchangably because it
does not strike him that semantics is or could be entirely rule-based. In fact,
it as never struck anybody except yourslef, since there are so many objections
to it.
Once again, BECAUSE YOU HAVE ALREADY ACQUIRED SEMANTICS.
How is that relevant to the CR ? Are you saying that the CR can *acquire*
semantics despite its lack of interaction and sensory contact with an
evironment ? Are you saying you can "download" the relevant information
from a human -- although you have already conceded that information may
fail to make sense when transplanted from one context to anothera ?
By virture of SMART ?
By standard semantics, possession of undertanding is *necessary* to report.
1) "What red looks like"
2) "The experiential qualities of red which cannot be written down"
To say that semantics is not derived from the syntactical SMART does not mean
it is derived from some other SMART. You have yet to issue a positive argument
that SMART is sufficient for semantics. You have also yet to explain what
you consider the "correct" AI argument to be.
*Some* direct demonstrations can be deferred in *some* cases. It is not clear
whether they can all be removed completely. The alternative would be a system
of essentially circular definitons -- like
"Gift: present"
"Present: gift"
but more complex.
What relevance does that have to the CR? If the TT cannot establish that a
system understands correctly, how can it establish that it understands at all
The fact that errors in semantics may be undetectable to a TT implies absence of
semantics may be undetectable to a TT.
The argument that syntax undeterdetermines sematics relies on the fact that
syntactical rules specify transformations of symbols relative to each other --
the semantics is not "grounded". Appealing to another set of rules --
another SMART -- would face the same problem.
I most people agree on the definitons of the words in a sentence, what
would stop that sentence being an analytic truth, if it is analytic ?
How do you know they are its qualities, in the complete absence of a
defition ? Do they have name-tags sewn into their shorts ?
It is not a question of misquoting you, it is a question of guessing how your
comments relate to the CR. Why should it matter that "the “experiential knowledge of red” is purely subjective".
Are you supposing that subjective knowledge doesn't matter for semantics ?
They should be broadly similar if our brains are broadly similar.
They should be precisely similar if our brains are precisely similar.
They should *not* be radically different if our brains are similar -- that
would be a viloation of the physicalist "same cause, same effecct" principle.
Need I point
The idea that similar brains can have radically different qualia is
non-physicalism in my and most people's book.
Or you are not aware that some of the things you are saying have implications
contrary to what you are trying to assert explicitly.
Aagh! Firstly that is a classically anti-physicalist argument.
Secondly, it doesn't mean that we are succeeding in grasping the experiential
semantics in spite of spectrum inversion; it could perfectly well be a
situation in which the syntax is present and the semantics are absent.
What they look like, experientially.
understanding.
That does not follow. Clearly experiential semantics conveys understanding of
experience.
meaning and understanding ? If a system has language, you can use that to convey
What is the alternative ? We might be able to transfer information directly
form one computer to another, or even from one brain to another
anatomically similar one. But how do you propose to get it into the CR?
you cannot safely
You haven't supplied any other way the CR can acquire semantics.
I'll concede that if you solve the Hard Problem, you might be able to
programme in semantics from scratch. There are a lot of things
you could do if you could solve the HP. But that does not show
Searle is wrong; solving the HP is showing how mind emerges
from physics; it might tell you that artificially intelligent
agents need certain material substrates (or that certan semantics-
the semantics of feelings and expriences -- needs a certain physical
embededness). The resulting AI would not have therefore
have its intelligence/consicousness/semantics purely by virtue
of SMART.
has made his case.
Because human languages contain vocabulary relating to human senses.
If its ability to understand cannot be established on the basis of having
the same features asd human understanding -- how else can it be established.
By definition ?
Achieved solely by SMART has the same problems as achieved solely by syntax.
Do I have a way of knowing whether phsycialism is true ?
It does if we are to avoid a situation where "is this a computer" is a matter
of idiosyncratic definition. We have been through all this: you can be too
anthropocentric, but you can be insufficiently anthropocentric too.
Well, that's the anti-physicalist's argument.
to draw on.
The question was the term "qualia". You could infer "house" on analogy with
"palace" or "hut". You could infer "X Ray" on analogy with "light". How
can you infer "qualia" without any abalogies ?
Tu quoque.
It is not necessarily the same, it naturalistically the same. For all your
adherence to the central dogma of anti-physicalism, inverted spectra, you
claim to be a physicalist.
Why should I "remember" something that relates to a definition of
"understanding" which *I* don't accept..as *you* point out.
Anyway, experience has to do with the semantics of expreiential language.
It is not part of your definition of understanding -- how remarkably
convenient.
Ask a blind person what red looks like.
Is that any easier than solving the Hard problem, or is it part of the Hard
problem?
brain-states.
Yes there is: all brains are broadly similar anatomically. If they were not,
you could not form a single brain out the two sets of genes you get from your
parents. (Argument due to Steven Pinker).
Summary:-
You might be able to give the CR full semantics by solving the HP; but that
leads to a version of AI that Searle does not disagree with.
You might be wriggle off the hook of full semantics by stipulating that
experience has nothing to do with understanding; but this is a style of
argument you dislike when others use it.
You might be able to give the CR full semantics by closing the explanatory
gap in some unspecified way; but that is speculation.
It is not an objection, it is an observation. Do you dispute it?
functioning brain.
Tournesol, your arguments are becoming very sloppy.
I can (if I wish) “speak to” my table – does that mean my table has a functioning brain?
and the TT.
What “insight” do you have which is somehow independent of observing their behaviour?
How would you know “by insight” that a person in a coma cannot understand you, unless you put it to the test?
How would you know “by insight” that a 3-year old child cannot understand you, unless you put it to the test?
Sorry, I missed that one. Where was it?
I am not here to defend the AI argument, strong or otherwise.
I am here to support my own position, which is that machines are in principle capable of possessing understanding, both syntactic and semantic.
Agreed
you are promoting
w is
or
Not “any kind” of symbol manipulation – a particular symbol manipulation
Can you show this, or are you simply asserting it?
That’s his opinion. I do not agree
Tournesol said:
In fact,
to it.
I do not think this is true. Even if it were true, what relevance does this have to the argument?
evironment ?
I am saying that the information and knowledge to understand semantics can be encoded into the CR, and once encoded it does not need continued contact with the outside world in order to understand
Where did I say that the information needs to be downloaded from a human?
Are you perhaps suggesting that semantic understanding can only be transferred from a human?
The only “information” which I claim would fail to make sense when transplanted from one agent to another is subjective experiential information – which as you know by now is not necessary for semantic understanding.
By virtue of the fact that semantic understanding is rule-based
The question is not whether “the ability to report requires understanding” but whether “understanding requires the ability to report”
If you place me in situation where I can no longer report what I am thinking (ie remove my ability to speak and write etc), does it follow that I suddenly cease to understand? Of course not.
Mary can semantically understand the statement “what red looks like” without knowing what red looks like. The statement means literally “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. This is the semantic meaning of the statement “what red looks like”.
Mary can semantically understand the statement “the experiential qualities of red which cannot be written down” without knowing the experiential qualities of red. The statement means literally “the sense-experiences created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. This is the semantic meaning of the statement “the experiential qualities of red which cannot be written down”.
Thus I have shown that Mary can indeed semantically understand both your examples.
Now, can you provide an example of a statement containing the word “red” which Mary CANNOT semantically understand?
What red looks like is nothing to do with semantic understanding of the term red – it is simply “what red looks like”. What red looks like to Tournesol may be very different to what red looks like to MF, but nevertheless we both have the same semantic understanding of what is meant by red, because that semantic understanding is independent of what red looks like.
The experiential qualities of red are nothing to do with semantic understanding of the term red – these are simply “the experiential qualities of red”. The experiential qualities of red for Tournesol may be very different to The experiential qualities of red for MF, but nevertheless we both have the same semantic understanding of what is meant by red, because that semantic understanding is independent of the experiential qualities of red.
The confusion between “experiential qualities” and “semantic understanding” arises because there there are two possible, and very different, meanings to (interpretations of) the simple question “what is the colour red?”
One meaning (based on subjective experiential knowledge of red) would be expressed “what does the colour red look like?”.
The other meaning (the objective semantic meaning of red) would be expressed as “what is the semantic meaning of the term red?”.
You are the one asserting that semantics is necessarily NOT rule-based. I could equally say the onus is on you to show why it is not.
Answered above
Very relevant. If the CR passes most of the Turing test, but fails to understand one or two words because those words are simply defined differently between the CR and the human interrogator, that in itself is not sufficient to conclude “the CR does not understand”
“Grounded” in what in your opinion? Experiential knowledge?
What experiential knowledge do I necessarily need to have in order to have semantic understanding of the term “house”?
If X and Y agree on the definitions of words in a statement then they may also agree it is analytic. What relevance does this have?
You are not reading my replies, are you? I never said there should be no definitions, I said there is a balance to be struck. Once again you seem to be making things up to suit your argument.
I am suggesting that subjective experiential knowledge is not necessary for semantic understanding. How many times do you want me to repeat that?
“Broadly similar” is not “identical”.
A horse is broadly similar to a donkey, but they are not the same animal.
You are perhaps trying to read things into my arguments that are not there, to support your own unsupported argument. When I say “there is no a priori reason why they should be identical” this means exactly what it says. With respect if we are to continue a meaningful discussion I suggest you start reading what I am writing, instead of making up what you would prefer me to write.
I certainly do not. Red is the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm. This is a semantic understanding of red. What more do I need to know? Whether or not I have known the experiential quality of seeing red makes absolutely no difference to this semantic understanding.
It may be a true argument, but it is not necessarily anti-physicalist.
The semantics is completely embodied in the meaning of the term red – which is the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm.
What they look like is an experiential quality, it is not semantic understanding.
Perhaps you would claim that I also do not have a full understanding of red because I have not tasted red? And what about smelling red?
experience.
I can semantically understand what is meant by the term “experience” without actually “having” that experience.
The CR already contains information in the form of the rulebook
Sematics is rule-based, why should the CR not possesses the rules for semantic understanding?
Please define the Hard Problem.
And I can have complete semantic understanding of the term red, without ever seeing red.
By definition ?
By reasoning and experimental test.
You have not shown that semantic understanding requires anything other than a knowledge and an understanding of the relevant semantic rules
You don’t. And I understand that many people do not believe it is true.
And my position is that I believe arbitrary definitions such as “understanding requires consciousness” and “understanding requires experiential knowledge” are too anthropocentrically biased and cannot be defended rationally
It’s my argument. I’m not into labelling people or putting them into boxes.
I see no reason why X’s subjective experience of seeing red should be the same as Y’s
By “how do I semantically understand the term qualia”, do you mean “how do I semantically understand the term experiential quality”?
Let me give an example – “the experiential quality of seeing red” – which is “the sense-experiences created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. What is missing from this semantic understanding the experiential quality of seeing red?
Tournesol said:
you
To my knowledge I have made no such claim in this thread
Semantic understanding has nothing necessarily to do with experiential qualities, as I have shown several times above
convenient.
And remarkably convenient that it is part of yours?
The difference is that I can actually defend my position that experiential knowledge is not part of understanding with rational argument and example – the Mary experiment for example.
He/she has no idea what red looks like, but it does not follow from this that he does not have semantic understanding of the term red, which is “the sense-experiences created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. Experiential knowledge is not part of this semantic understanding.
problem?
Please define what you understand to be the Hard Problem
As before, “broadly similar” is not synonymous with “identical”.
Tournesol said:
. If they were not,
Genetically identical twins may behave similarly, but not necessarily identically. Genetic makeup is only one factor in neurophysiology.
Please define what you mean by the Hard Problem
Tournesol said:
this is a style of
It is not a question of “disliking”.
If a position can be supported and defended with rational argument (and NOT by resorting solely to “definition” and “popular support”) then it is worthy of discussion. I have put forward the “What Mary does not understand about red” thought experiment in defence of my position that experiential knowledge is not necessary for semantic understanding, and so far I am waiting for someone to come up with a statement including the term red which Mary cannot semantically understand. The two statements you have offered so far I have shown can be semantically understood by Mary.
What “explanatory gap” is this?
MF
An incomplete understanding of a house means not experiencing the house as a whole. It means not receiving the entire gammut of information with regard to a house. Mary does not see, smell or understand the plumbing of the house... therefore, her understanding of a house is incomplete... and this does not constitute an understanding of a house. Mary has not seen the blueprints and has not inspected the foundations. Mary has not walked into the house and inspected or had an inspection done for insects or pests. These are things that a house can contain. She perhaps doesn't understand that and so, her understanding is incomplete and still in the process of being formed. Mary does not understand these implications with regard to the term "house".[/quote]
No.
Yes. The hormonal release demonstrates how red makes the human feel in the presence of red. This is true in every human although not widely known. Note: eg. red light districts. Note: eg. (the popular saying in advertising) "red sells".
Hormonal reaction is an experience and therefore constitutes knowledge. As noted above it is understood by many professionals as "common knowledge" or a "semantic understanding".
You're repeating yourself again.
With continued respect, part of knowing what a colour is includes experiencing its effects. When a colour stimulates the cones of the retina this experience helps one toward an understanding the physics of colour. When you read an equation that explains the physical properties of colour... the experience helps one toward an understanding of colour.
We don't have to "create" the anthropocentric bias. As humans we cannot escape the bias. However, we can avoid using terms that only apply to human physiology and function and process such as the word "understanding". If you you can build a computer that "loves" and "understands" you... I'd really like to see that.
I agree. In fact, there are more things that we don't know or understand than there are things we do know or understand. That's why caution is imperitive in every endevour, especially in the sciences that directly effect humankind, such as computer sciences.
That's right. That's why you will never have a complete understanding (and therefore will not understand a bat) of a bat. That's why when you asked me if the individual components of the brain, ie. neurons, "understand" the tasks they perform and their implications... I said... I don't know, I'm not a neuron.
Yes, that's what I'm getting at. That is one of the many determiners of understanding. It is individual, relative and dependent upon the person understanding. I have given examples of "reaching and understanding" between more than one person, however.
No.
Yes it can... but, its not a scientific language people use... its also not binary language. One uses words to describe red like "warm", "to the yellow", " a little blue", "makes me horney"... "makes me want to buy"... and so on... There are some studies that have yeilded standard results with regard to the qualities of red... but... you'll just have to believe me cause we're almost out of time.
Mary said sitting in the red room made her feel sexy, horney and warm all over. This room also triggered a memory of her father who happened to be Satin and it reminded her of the places that glowed deep like the reddened coals of a fire where her dad would take her on Christmas eve.
I disagree. Please see my above statements.
Oh my god, is it showing!... yes I admit it... I'm a f@cking human!
Done and done(r). All knowledge is experiencial. It must be experienced before it can be stored as knowledge.
Let me tell you how things are shaping up in my mind with regard to the terminology of the CR experiment.
Computers store data.
Humans Understand.
Computers are programmed.
Humans experience.
That's my take on it.
The rest of your argument seems to repeat most of the above points. Got to run. This is most enlightening because the more you try to discredit the state of understanding as a specifically human trait... the more you expose how it really is. Thank you.
Yes, and I'm sorry I through that in. Just getting cocky I suppose. My respect. Cheers.
MF[/QUOTE]
Ahhhh, I see now! Perhaps Mary actually needs to “be” the house to really understand it? Mary cannot really understand what a house is unless she is part of the house. Yes, I see what you mean…… :smile:
Yes. And it follows that Mary can never truly understand what a house “IS” unless she herself is part of the house….. built into the foundations…. Cemented into the brickwork….. why didn’t I see that before? :biggrin:
“how red makes the human feel” – this is semantic understanding to you?
Or is it perhaps an emotional response to a stimulus?
With respect - I think you and I are on different planets.
Bye!MF
moving finger said:
“Y does not agree with X” is not synonymous with “Y thinks X is wrong”.
If X does not agree with Y’s opinion it does not follow that X thinks Y is wrong. They may simply have different opinions. X can have different opinions to Y and still respect Y’s right to hold his/her opinion. Simple as that.
I can see that perhaps some may not respect the right of others to hold different opinions, but I'm not one of them.
I here shall trim most of the parts on “analytic vs synthetic” because I consider we have done that to death, we are simply repeating things over and over again.
moving finger said:
As I pointed out several times already, two people may not be able to agree on whether a given statement is analytic or not if those two people are not defining the terms used in the statement in the same way. Do you agree with this?
If Tisthammerw has a different definition of bachelor then it is up to Tisthammerw to decide whether the statement “bachelors are unmarried” is analytic or not according to his definitions of bachelor and unmarried. I cannot tell you since I do not know what Tisthammerw’s “different definition of bachelor” actually is.
Whether a statement is “analytic or not” depends on the definitions of the words used in the statement.
moving finger said:
How do I know whether the computer you have in mind is acquiring, interpreting, selecting, and organising (sensory) information?
Tisthammerw said:
Because I have described it to you.
moving finger said:
In fact you did NOT specify that the computer you have in mind is interpreting the data/information.
With resepct, what part of “you did NOT specify that the computer you have in mind is interpreting the data/information” do you not understand?
If I do not know whether the computer YOU have in mind is interpreting the data/information then I have no idea whether it is perceivng or not. So tell me – is the computer you have in mind interpreting the data/information?
I also trim the parts on “my definition is better than yours” since I consider this rather puerile.
There is more than one meaning of “to perceive”. There is the “introspective-perception” meaning, which does NOT require any sense receptors. There is the “sense-perception” meaning, which does require sense receptors.
For an entity to “sense-perceive” a bright light it must possesses suitable sense receptors which respond to the stimulus of that light.
Whether that entity is necessarily “aware” of that bright light is a different question and it depends on one’s definition of awareness. I am sure that you define awareness as requiring consciousness. Which definition would you like to use?
moving finger said:
What makes you think that a person is anything more than a “complex set of instructions”?
And I have shown repeatedly that you have “shown” no such thing – your argument is not necessarily sound because the premise "Bob's consciousness is the only consciousness in the system" is not necessarily true - (see post #256 in the “can artificial intelligence……” thread)
moving finger said:
Can you show that no possible computer can possesses consciousness?
see above
Tisthammerw said:
If what you say is true, it seems that computers are not capable of new understanding at all (since the person in the Chinese room models the learning algorithms of a computer), only “memorizing.”
moving finger said:
This does not follow at all. How do you arrive at this conclusion?
see above
moving finger said:
It is not clear from Searle’s description of the thought experiment whether or not he “allows” the CR to have any ability of acquiring new understanding (this would require a dynamic database and dynamic program, and it is not clear that Searle has in fact allowed this in his model).
see above
Suggestion : If you wish to continue discussing the Program X argument can we please do that in just one thread (let’s say the AI thread and not this one)? That way we do not have to keep repeating ourselves and cross-referencing.
MF
This last part again is a straw man. No One here has argued that continued sensory information is necessary for understanding. I myself have said this a number of times so continually responding with it gets us no where.
The contention is that aquisition of information is necessary for understanding. You have said that "possession" of information is what is necessary as opposed to the "aquisition". The fact is that you can not possesses information unless you acquire it in some fashion and the manner in which you acquire that information will influence your "understanding" of it.
When I say "experience" I am referring to the aquisition and correlation of information in one fashion or another. I agree that continuous aquisition (a steady feed) of information is not necessary.
MF
Unfortunately this does not answer my question but I'll respond to it before I go back to what my original question was.
For one I would say that unless there is some sort of difference between our "software" and "hardware" that you and I do in fact see the same or very nearly the same thing when we look at red. Considering that the software and hardware are nearly identical there is not reason to believe otherwise and after we have correlated our experiences side by side with samples of colours I'd say that we will find we can deduce that we see the same thing.
Next, why is the sensory experience of "red" insufficient information for understanding? As far as I see it this is one of multiple viable manners by which to acquire information for the purpose of understanding.
Would you say that your average kindergartener has no understanding of what the word "red" means because they have never been explained to the scientific definition of "red"? If so then we'd probably have to say that the majority of the people in the world have no idea what the word "red" (or it's equivilent in their own language) means. We'd further probably have to conclude that the persons who came up with the word themselves had no idea what the word meant. I wonder what the word meant to the people who came up with it?
At any rate, I'd personally say that the two manners of aquiring the information about rede you have defined above would probably best be described as "direct" and "indirect" understanding. Or rather understanding by virtue of direct experience or understanding by virtue of parallel experience. Let me get into the "parallel experience" a bit more.
Remember my question? How would you go about teaching a person who possesses only hearing and no other sense what so ever? You never actually answered this. With Mary, even though she lacks the ability to see colour, she still had several other forms of experiencial knowledge to fall back on and use by parallel to understand in some fashion what the colour "red" is. With our new student, let's call him Tim, we are severely limited. Until he somehow discovers otherwise nothing exists outside of the realm of sound. Sound is the only sort of information he has by which to understand anything. Now how is he to understand what red is? It would somehow have to be based on that which he experiences otherwise he will not be capable of comprehending. There needs to be a parallel drawn. Is his experience sufficient for conveying the concept of red do you think?
In the sense that “acquisition of data” must be followed by “interpretation of data” before the agent can make sensible use of that data, then yes I agree that the precise form of the acquisition of the data may “colour” the interpretation of the data. But it does not follow from this that a particular sense-experience is necessary for semantic understanding – only that all understanding may be coloured by the manner in which data is acquired and interpreted. A Chinese person’s understanding of the meaning of the word “house” (or it’s Chinese equivalent) may not be precisely the same as an English person’s understanding of the meaning of the same word – but this does not mean that “one of them understands and the other does not” – it means simply that they attach slightly different meanings to the same word.
With respect, I have indeed answered your question(s), but perhaps it was not the answer you wanted.
In the case of human beings, I agree our experiential data may be similar (but not necessarily identical). But what happens if you confront an intelligent alien (with visual ability)? The alien can look at a red object, and it will have an experiential quality associated with seeing that red object, but it may be completely different to the experiential quality that you have when you look at the same object. Yet the alien can learn English, and it can then refer to the colour it sees as “red”. The key point is that the meaning of the term red is the same for both you and the alien, even though the experiential data may be vastly different – because the definition of the term red (the meaning of the word) is not determined by any particular experiential quality.
I will agree that you and I would probably see similar things – but not that we necessarily see exactly the same.
However in the above example of the alien intelligence, you cannot deduce that you and the alien see even similar things. Yet the alien can still have a semantic understanding of the word red which may be identical to your understanding – because semantics is determined by the definitions of and relationships between words, not necessarily by any associated sense-experience
A young child may have a semantic understanding of red, but it would not necessarily be the same as my own semantic understanding of red. Presumably quantumcarl (based on his recent post regarding "understanding a house") would say that a young child does not understand anything.
As to the question "is experiential knowledge alone sufficient for semantic understanding?" - Would you say that an agent can claim to understand the meaning of any word before the agent has developed a reasonably basic vocabulary? A newly-born baby might start visually-sensing objects which have the colour “red” at a very early age, but that sensory experience alone is not sufficient for it to claim that it understands the meaning of the word red. The infant needs to develop a basic vocabulary before it can do that. It follows that sensory experience of "red" is insufficient for understanding the meaning of the term “red”.
To take the position that “everyone must mean exactly what I mean when I refer to the word red” would be unreasonable arrogance akin to the anthropocentriuc arrogance displayed by those who insist on defining terms with a human bias. Of course it goes without saying that the meaning of a word may be different to different agents, and the meaning of a word to an agent may change over time as the agent acquires more knowledge and understanding of the world. None of this makes one agent “right” and the other “wrong”.
Mary may start to grasp the understanding of a word like “consciousness” at a very early age – let's say as a young teenager. If Mary grows to become a neurophysiologist, her understanding of the word will likely change dramatically as she learns more about the subject. This does not mean that the teenager Mary “did not understand the meaning of the word consciousness”, just that the word consciousness had a different meaning to the teenager Mary compared to what it does to the adult Mary. But at the same time I think it is reasonable to assume that the adult Mary’s understanding of the meaning of the word is much more highly developed, more complex, and more subtle, and shows a much greater “depth” of understanding, than the teenager Mary’s understanding. Wouldn’t you agree?
Why would we conclude this? The meanings of words change over time. As we have seen above, the meanings of words can even change over an agent’s lifetime. A caveman might attach a meaning to the word “red”, but he certainly knows nothing of “wavelengths of electromagnetic radiation”. He would be totally confused by such words. From his position of a very limited and shallow understanding of the world about him, he might even deny that there IS any other meaning to the word “red” apart from his experiential knowledge of red (shock, horror!) - simply because his semantics is more basic, more crude and less developed than the semantics of modern man. From our vantage point we can see that the caveman’s semantics are not the only possible semantics, we can also see it is not the case that one meaning is “wrong” and the other is “right”, there can be enormous differences in the complexity, subtlety and depth of understanding of meaning between two agents. The important thing is that (unlike the caveman) we know that this depth of understanding is possible without experiential knowledge.
I'd personally say that the two manners of aquiring the information about red you have defined above would probably best be described as "direct" and "indirect" understanding. Or rather understanding by virtue of direct experience or understanding by virtue of parallel experience.
That is your opinion and of course you are entitled to it. I would personally say that experiential knowledge is not synonymous with, and is not necessary for, semantic understanding.
With respect, remember my answer? I pointed out that your question is ambiguous. I pointed out the two different possible meanings, and I asked you which one you actually meant. You never actually clarified what you meant. In fact I did provide answers to both possible meanings of your question. Perhaps my answers were not the answers you wanted, but that is beside the point. Please go check again.
Again, your question is ambiguous and I ask again the same question that you still have not answered. Your question is (if I understand correctly) “is his experience sufficient for conveying the concept of red?” – yes?
This question MIGHT mean :
A : “is his experience sufficient for conveying his experiential quality of seeing red?”
Or it MIGHT mean :
B : “is his experience sufficient for conveying his semantic understanding of red?”
These are two very different questions. Only the latter question (B) explicitly refers to semantic understanding.
As before, I must ask : Which question are you asking?
Let me know which one, and I will then answer it.
Let me repeat once again what I said in my previous reply, in case you missed it - this is a perfect illustration of the fact that we need to be very careful when using everyday words in scientific debate, to make sure that we are not confusing meanings.
Now I have a question for you.
TheStatutoryApe (presumably) would argue that experiential knowledge is necessary for semantic understanding, hence there must be something which Mary “does not semantically understand” about red.
Can TheStatutoryApe provide an example of any sentence in the English language which includes the term “red” which Mary must necessarily and demonstrably fail to semantically understand by virtue of her lack of experiential knowledge of red?
Thanks
MF
Mary must experience every aspect of a house in order to understand the implications of the word house. If all Mary possessed in order to understand a house was binary language... all Mary would understand would be the binary interpretation of a house.
That's you're understanding of what I have written?
Yes. Evaluating emotional response to a phenomenon is a part of understanding the effects of a phenomenon and thusly the phenomenon itself.
This really sums things up (not). Let's hope its true.
Hi, Once information is stored in a human brain upon retreaval the stimulus of that retreaval is an connection and an experience that is a building block of understanding.
Drawing on an earlier understanding is an experience that leads to further understanding... or can... but not necessarily in every case... in fact it is a rare occurrence by my observations.
Lets say Larry got hit by lightning. Now, no one understands the phrase, "hit by lightning" as well or as correctly as Larry and the 1400 other people who have been hit by lightning and lived.
Lets say Tim, who has never seen anything and relys on his hearing to experience the world has several different coloured lights shone on his skin. One is red. Now Tim has tactile understanding of red... and can use that to build on his total understanding of the colour red.
Lets say Hal the computer can only interpret the world through its use of binary language. He can't experience anything because he is not as complex as an organic organism like a human.
The data Hal recovers from its environment is immediately translated into 0s and 1s and stored in a specific area of its storage capacity. When it either stimulates itself to build a data base on what it has analyzed or is asked to regurgitate what it has compiled with regard to its environment, it does so, unknowing of the purpose of the task or even how it feels to be following the orders of an independent operator or a program that was installed to provoke this process.
Understanding is a rare comodoty. It doesn't come fast, cheap or easy. It requires am empathetic and gallant attempt of someone willing to put themselves in the actual currcumstances they need to understand. That's how I understand it.
What is red?
Suppose Houston makes radio contact with an alien intelligence on the far side of our galaxy. Over a long period of time the Houston scientists are teaching the aliens, via radio, the meanings of our words and language - in other words our semantics.
It has been established already in previous communications that the aliens have visual sense-perception organs similar in function to our "eyes", and they can sense-perceive electromagnetic radiation with wavelengths in the range 400nm to 700nm.
Here we listen in on one of the radio conversations between Houston and the Aliens…..
Alien : You have taught me that to understand your language, to grasp your semantics, I must understand the meanings of your words, which in turn means I must understand the defining properties and characteristics of your words as used within your language. Is this not so?
Houston Yes, that’s exactly right
Alien Then I have a question please, to help me understand
Houston OK, let’s have it
Alien What is “red”?
Houston Ummmm, well, red is a colour
Alien What is “colour”?
Houston “colour” is the set of things such as red, yellow, green
Alien Thus, red is characterised by being a member of the set of colours, and a colour is the set of things one member of which is red. Is this supposed to help me truly understand what is meant either by “red” or by “colour”?
Houston ummmm, well no I guess not
Alien When you were teaching me what is “horse”, you did not simply tell me “horse is an animal”. This tells me only that horse is a member of the set of animals, it does not tell me what is horse. Likewise, telling me that “red” is a member of the set of “colours” does not tell me what is red.
Houston Yes, I guess you are right
Alien For me to understand what is horse, I needed to know the defining properties and characteristics of horse, was it not so?
Houston Yes, that’s true
Alien Thus – for me to understand what is red, I need to know the defining properties and characteristics of red, is it not so?
Houston Yes, that’s correct
Alien Thus – what are the defining properties and characteristics of red?
Houston (after a long pause) – ummmmm, redness?
Alien Redness? If I ask what are the defining properties and characteristics of horse, and you reply “horsiness”, would you expect me to then understand from this reply what is horse?
Houston ummm, well no of course not
Alien Then let us stop wasting time. Let me ask again - what are the defining properties and characteristics of red?
Houston OK, we’ll try a bit more detail. You aliens have visual sense-receptors, right? Red is the experiential quality that you have when you sense-perceive a red object with those visual sense-receptors
Alien Human, do I need to explain the circularity of your explanation? “Red is the experiential quality when one perceives a red object” – this is much like saying “horse is the entity which is characterised by being a horse object”. How can I understand from this what is horse if I do not first know what a horse object looks like? How can I understand what is red from your explanation, if I have no idea what is a red object?
Houston (embarrassed silence)
Alien With respect, human, for me to understand what is red, you need to explain the defining properties and characteristics of red without tautologically defining these characteristics in terms of redness.
Houston (still more silence)
Alien Let me help you. It is clear from what you have told me so far that “red” is an experiential quality associated with visual sense-receptors. As you know, we aliens have visual sense-receptors similar in function to your human “eyes”, and like you humans we aliens can sense-perceive electromagnetic radiation in the wavelength range 400nm to 700nm.
Houston yes, that’s correct
Alien Then is it possible to define red in terms of something we both understand - sense-perceiving electromagnetic radiation of a particular wavelength?
Houston (lots of applause and cheers) Yes – of course! That’s it!
Alien Well?
Houston : OK, here goes…. Red is the experiential quality that you have when you sense-perceive electromagnetic radiation with wavelengths of the order of 650nm
Alien Ahhhhh, NOW I see! We call that experiential quality “qrkzmnthlog” – thus “red” is equivalent to qrkzmnthlog. NOW I understand. Thank you!
MF
Alien Well?
MF
Shared knowledge about a colour or an animal doesn't constitute a shared understanding of the colour or the animal.
It is the shared experience of a horse or red that can allow for an understanding to take place between Houston and Alien.
If the Alien has its visual receptors in its arm pits, his understanding of red will be a different understanding of red from a human's, who's eyes are in his head. In fact it may be that aliens percieve green to be what we call red. Please note "colour blindness". This isn't necessarily a condition of "blindness" but, perhaps a different way of seeing and experiencing colour. In fact, if you look at red lights and green lights and yellow lights on traffic controlers... you will notice that the red is shifted more to the yellow... the green to the blue and the yellow to the red to facilitate the percentage of the population that has difficulty understanding a pure red etc...
Similarily, if the alien has never been on a horse, brushed down the horse, shoveled the fresh dung of the horse or fed a horse, the alien doesn't not possesses a complete understanding of a horse.
The stimulus that is the shared knowledge or data of a phenomenon is insufficient to use in arriving at what I am terming as an understanding of the said phenomena.
Neither does "shared sense perception".
Understanding is not an absolute property like "the speed of light". No two agents (even two human "genetically identical" twins) will have "precisely" the same understanding of the world. Nevertheless, two agents can still reach a "shared understanding" about a word or concept, even the world in general, even if their individual understandings of some ideas and concepts is not identical. If you are demanding that agent A must have completely identical understanding to agent B in order for them to share understanding then no two agents share understanding in your idea of the word.
And just because there may be some differences in understanding between agent A and agent B does not necessarily give agent A the right to claim that agent B "does not understand".
It is the shared information and knowledge that can allow for an understanding to take place between Houston and Alien
I disagree. If I could transplant your eyes from your head to your armpits, your semantic understanding of red could remain exactly the same - what red "is" to you does not necessarily change just because your eyes have changed location.
In fact it may be that I perceive green to be what you call red (and red to be green - ie just a colour-swap). How would we ever find out? We could not. Would it make any difference at all to the understanding of red and green of either of us, or between us? It would not.
Colour blindness is an inability to correctly distinguish between two or more different colours.
If red looked to me the same as green looks to you, and green looks to me the same as red looks to you, this would not change anything about either my understanding of traffic lights, or about your understanding of traffic lights, or about the understanding between us.
In that case neither do I.
What is "complete understanding"?
I could argue that no agent possesses "complete understanding" of Neddy the horse except possibly for Neddy himself (but arguably not even Neddy "completely underdstands" Neddy). Thus no agent possesses complete understanding of anything. Is this a very useful concept? Of course not. There is no absolute in understanding, different agents understand differently. This does not necessarily give one agent the right to claim its own understanding is "right" and all others wrong.
You are entitled to your rather unusual definition of understanding - I do not share it. Information and knowledge are required for semantic understanding, experiential data are not necessary.
MF
I have already agreed with you that one can arrive at an understanding without direct experiencial knowledge several times. Why you continue to treat my statements as if I don't agree I have no idea.
I think I have also been quite clear that by "experiencial knowledge/information" I mean any sort of information that is acquired and correlated without any restrictions on the apparati used for this purpose while you seem to continue to regard my statements as if I mean a person must have eyes like I have.
So from now on if you could possibly remember that I have agreed a person can understand the concept of red without ever having actually seen "red". And also please remember that when I state "experience" I am not referring to "seeing" with ones eyes or aquiring information in the same exact manner that I do but only the aquisition and correlation of information in what ever form it may take.
Now my question was: How would you teach a person with 'hearing' as their sole means for aquiring information what 'red' is so that the person understands?
I would think the question of whether I mean the direct visual experience or not is rather moot by the sheer fact that Tim's eyes do not work and never have. Tim must then learn what "red" is via some indirect method. You have already communicated the definition you would give in this instance which I already knew. You have yet to give me the "How". HOW would you communicate your definition in such a manner that such a person understands what you mean?
I have never asserted that Mary must have experienced red to understand what it is or that she lacks semantic understanding. I have asserted that her definition will be different than others and have never stated that this makes her definition any less viable or usable. The only other thing that I have asserted is that she does in fact require some sort of "experiencial knowledge" to understand what red is (At this point please refer to what I have stated is my definition of "experience" or "experiencial knowledge"). I believe that Mary is capable of understanding through indirect experience. That is to say that her experiencial knowledge contains information that she can parallel with the information she is attempting to understand and by virtue of this parallel she can come to understand this new information. I believe I more or less already stated this here...
In that last line I am specifically referring to Tim. The reason for my Tim scenario is for us to discuss what I see as the importance of experience to understanding (again note my earlier definition of experience). Ultimately the questions in my mind are "Can we even teach Tim english?" "How would we go about this?" "Does his experience afford sufficient information for understanding?" and "Will his understanding be limited by the nature of the information his experience can afford him?".
MF
Yes I got your drift upon reading one of your first posts.
My "unusual (on your planet) definition" of "understanding" stems from the original meaning of the word which is described in a number of dictionaries. The origin is middle english and it describes standing under something.
Standing under something is a curcumstance one attains by going to meet it and going to experience it in order to further oneself toward an understanding of it.
When you speak of "understanding' a world or "understanding" a traffic light without ever having seen one or having experienced the effects of its emfs etc... what you mean... by my standard of english and use of certain terminologies... is knowledge as in Having knowledge of a world or a traffic light. This is not what I would term as an understanding of a world or of a traffic light.
You can share knowledge about a world or you can share knowledge about a traffic light...but, by your own admission, you cannot share understanding without both parties having experienced being in the currcumstances created by the subject.
So, when we program a computer are we getting it to brush the horse and shovel the horse hockeys? No.
We are sharing the knowledge we have of a horse with the computer through the use of binary language.
By this process, and by many scholar's definitions of "undertstanding", does the computer understand what a horse is? Or does the computer only hold a repository set of data that defines, for its records, a horse? I choose the latter.
(Don't forget to buy our Flammable Safety Cabinets, they burn like hell!) another example of poor english... what what?
And this definition implies to you that to have semantic understanding of the term "horse" an agent must necessarily have groomed a horse, and shovelled the horses dung? With respect, that is plain silly. But if this is what you choose to believe then that's OK with me.
"Standing under something" in this context does not mean literally "physically placing your body underneath that thing" - or perhaps you do not understand what a metaphor is?
I am talking here about semantic understanding - which is the basis of Searle's argument. Semantic understanding means understanding the meanings of words as used in a language - it does not mean (as you seem to think) making some kind of "intimate physical or spiritual connection" with the objects that those words represent. An agent can semantically understand what is meant by the term "horse" without ever having seen a horse, let alone mucked out the horses dung.
No, I have admitted no such thing. You are mistaken here.
And by your definition, I and at least 95% of the human race do not semantically understand what is meant by the term "horse". Ridiculous.
Billions of humans share knowledge with each other through the use of binary language - what do you think the internet is? Are you suggesting that the internet does not contribute towards shared understanding?
You choose to define understanding such that only an agent who has shared an intimate physical connection with a horse (maybe one needs to have spent the night sleeping with the horse as well?) can semantically understand the term "horse".
I noticed that you chose not to reply to my criticism of your rather quaint phrase "complete understanding". Perhaps because you now see the folly of suggesting that any agent can ever have complete understanding of anything. There are many different levels of understanding, no two agents ever have the same understanding on everything, none of these levels of understanding can ever be said to be "complete", and no agent can simply assert that "my understanding is right and yours is wrong"
As I have said many times already, you are entitled to your rather eccentric definition of understanding, but I don't share it.
Bye
MF
Perhaps you will understand later in this post why your position on “experience is not necessary for understanding” seems rather confusing and contradictory to me…..
Actually this was NOT your original question. Never mind.
It is always good to seek confirmation of meaning where any ambiguity of meaning is even remotely possible – this is all part of better understanding. Wouldn’t you agree?
Thus – we now agree that the meaning of your original question was NOT “is his experience sufficient for conveying his experiential quality of seeing red?”, but in fact it was “is his experience sufficient for conveying his semantic understanding of red?”
And my answer to this is very clearly “YES”.
Tim’s semantic understanding of “red” is “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. It makes no difference whether or not Tim actually has the physical ability to “perceive electromagnetic radiation with wavelengths of the order of 650nm”, his blindness does not change the semantic understanding of red that he has. Even though blind himself, Tim can introspectively perceive the possibility of an agent which does have such sense receptors, and which can then “perceive electromagnetic radiation with wavelengths of the order of 650nm”. Similarly, Tim does not need to have seen, heard, touched, smelled, or mucked out a horse to semantically understand the term “horse”.
Thus, when you ask “is his experience sufficient for conveying his semantic understanding of red?” the answer is Yes – because Tim can simply state that “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm” IS his understanding of the term red. By the way, it’s also my understanding of the term red. And it is the only understanding of the term red which allows any mutual understanding of the concept red to take place between Houston and the aliens in my earlier example.
If one probes closely enough, I think one will find that most agents do not agree on all aspects of semantic understanding – there are differences in semantic understanding between most humans (witness my discussion with quantumcarl on the semantic understanding of the term “semantic understanding” in this very thread). And it seems we agree that this does not necessarily give one human agent the right to claim that the other human agent “does not understand”. It simply means that all agents, human or otherwise, might understand some terms or concepts in different ways.
In my example of Houston and the Aliens, could one say that they had the same understanding of the term red? On one (objective) level they did have the same understanding – because both Houston and the Aliens finally agreed that red is “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. But on another (subjective) level they did not, because the data corresponding to the sense-experience of red to a human agent means nothing to an alien agent (in fact the precise data corresponding to the sense-experience of red to TheStatutoryApe does not necessarily mean anything to MF). The ONLY common factor between all agents is the objective definition of red as “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”. It seems to me that such an objective semantic understanding, which can then be understood by all agents, is a much greater and deeper level of understanding than one based solely on a subjective experientially-based semantic understanding.
I’m sorry, but there is that ambiguous phrase again – “what red is”. Please explain exactly what you mean by this phrase, because (as I have shown several times now) this phrase has at least two very different possible meanings. It might mean “what red looks like”, or it might mean “the semantic meaning of the term red”.
Remember - you have already agreed quite pointedly that experiential knowledge is not necessary for the latter. Now - Which meaning of “what red is” do you actually mean here?
You have in fact stated something rather stronger than this - that experience is not necessary for understanding. I agree with this.
That ambiguous phrase again!
Please clarify.
If you mean “how is he to have any semantic understanding of the term red” then I have already shown how – and you have agreed that he needs no experience to understand.
If you mean “how is he to know what red looks like” then I think we both agree this is a meaningless question in Tim’s case – but this is not important because we already agree that an agent does not “need to know what X looks like” to have semantic understanding of X.
This statement contradicts your earlier very strong assertion that experience is not necessary for semantic understanding. Are you now saying that experience IS necessary for semantic understanding?
By “the concept of red” do you mean some universal, objective concept of red? The only possible universal concept of red that means the same to you as to me, and the same to Houston and the Aliens, is “the sense-experience created within an agent which is endowed with visual-sensing apparatus when it perceives electromagnetic radiation with wavelengths of the order of 650nm”
Of course we can. Blind people can learn English, or are you suggesting otherwise? The additional lack of the perceptions of touch-feeling, smell and taste I do not see as any greater impediments to understanding than the lack of sight.
His precise understanding may differ in some ways to yours and mine. But my understanding differs to yours anyway. There is no “absolute” in understanding. ALL agents understand differently to a greater or lesser externt. We have already agreed this does not mean that one agent understands and the other does not. And arguably a semantic understanding of a concept like “red” in objective terms which can be translated between all agents is a much greater and deeper understanding of red than a simple subjective experiential understanding.
MF
I'm not sure where to start and what to quote so I will try to just recreate your points that we are having issues with...
Is experience required for understanding?
I never stated that experience is not required for understanding. I stated that direct experience is not required for understanding, that indirect experience could suffice.
Remember again my definition of experience... aquisition and correlation of information in what ever manner this may take shape. If a person can not acquire and correlate information about something then they can not understand it. Again you say that possession and correlation of the information is enough but all you are doing is skipping the step of aquiring the information in the first place. In my mind it is necessary to be considered because I believe that the actual act of gathering the information, aside from being necessary to possessing it, is important to the process of understanding in and of itself. I'll expand more on this later if you would like me to.
So once again I have not stated that experience is not necessary but that direct experience is not necessary.
Please clarify.
Yes I have already agreed that "seeing" isn't necessary and stated I do not mean "seeing" since this would be moot in Tim's case because we already know he can not "see" red.
The problem here is that you still have not answered the question. You have asserted that theoretically he can understand what "red" is and asserted a definition that he would be theoretically capable of understanding. You have yet to explain how this definition would be imparted to him in such a manner that he would understand. HOW as in the manner method or means by which.
It's so obvious is it? Then explain how.
I do not suggest that blind people are unable to learn english. Yet another strawman. It would help us greatly in our discussion if you would drop this tactic.
How it is that you do not see there being any stronger impediment to understanding for tim than for any other blind person is really quite beyond me.
Your average human possesses five avenues by which to gather information. A blind person only has four which will naturally hinder the blind persons ability to gather information by which to understand relative to the person with a total of five. Helen Keller, both blind and deaf, had only three and had great difficulty in learning to understand things. Tim has only one avenue by which to gather information. Considering this extreme lack of ability to gather information in comparison to your average human how do you justify your idea that it should pose no more of an impediment to be in Tim's shoes than it does to be in those of a blind person?
Can you accurately define the location of an object in three dimensional space with only one coordinate? Do you see the parallel between this and the difficulty that an agent with only one avenue for information gathering may have in understanding the world around it let alone the words that are supposed to describe it?
Given your definition I agree with this conclusion, though I do find your definition rather strange. Because of this strange definition we must be very careful to distinguish between “purely informational experience” on the one hand (which does not involve any “sensory experiential quality or data”), and “sensory experience” on the other hand (which is directly associated with “sensory experiential quality or data”). Sensory experience may be classed as a subset of informational experience, but purely informational experience involves no sensory experience. Would you agree?
I understand what you are saying. And I think you will find that I have already, in a previous post, agreed that the precise form in which the data and information are acquired may “colour” the interpretation of that information and hence may also “colour” any subsequent understanding that the agent may derive from that data and information. This is also at the root of my argument that all agents understand things differently to a greater or lesser extent, because our understanding is based on our experience (your definition of experience), and our experiences are all different. Thus it seems we agree that agents may understand some things (more or less) differently because their experiences are different, yes?
Getting back to the subject of this thread - the important point (I suggest) is “whether a machine can in principle semantically understand at all”, and not whether “all agents understand everything in exactly the same way”
Understood. I apologise, because I always have in mind a slightly different definition of experience, which is “sensory experience”, rather than “informational experience”. It is now clear to me what you mean by “indirect experience”. I suggest to avoid future misunderstanding that we explicitly refer to indirect experience whenever we mean indirect experience (and not simply to experience, which may be misinterpreted).
I do not understand what you mean by “theoretically” here.
Do I only “theoretically” semantically understand what is “horse” if I have never seen, heard, smelled or touched a horse?
To my mind, Tim “semantically understands” the definition of red as given. Period. There is nothing "theoretical" about it. Semantic understanding is semantic understanding.
If you can explain your distinction between “theoretical semantic understanding” and “practical semantic understanding” then I may be able to grasp what you are trying to say here.
BTW – I have indeed answered the question that you asked.
Your original question was :
My answer was :
Once again, you may not “like” this answer, and it may not answer the question that YOU think you asked, but it certainly answered the question as I understood it. I'm sorry, but I cannot help it if the meanings of your questions are ambiguous.
You now seem to be asking “how is this definition of red imparted to Tim?”. With respect, this was not your original question (at least it was not my understanding of your question - again perhaps because the way you phrased the question was ambiguous).
Tim has the sense of hearing, yes? In Tim’s case he can learn his semantic understanding of English, including his semantic understanding of the term “red”, via his sense of hearing. Is this the answer you are looking for?
With the greatest respect, TheStatutoryApe, it would help us greatly in our discussion if you would state your argument clearly at the outset, instead of making one ambiguous statement and question after another, which forces me to guess at your meaning and to ask for clarifications, after which you then frequently (it seems to me) change the sense of your questions.
When I ask a question in an attempt to clarify what I see as an ambiguity or an uncertainty in a post, that is just what it is - a question to seek clarification. You may call it a "strawman" if that makes you feel any better - but I'm afraid that as long as your statements and questions remain ambiguous then I must continue to ask questions to seek clarification on your meaning.
Please understand that I’m not guessing at the meaning of your questions because I want to – with the greatest respect, I am forced to guess at your meanings, and to offer up a question in the form of what you term a "strawman", because your questions are unclear, ambiguous, or keep changing each time you re-state them.
Here, with respect, is the error in your reasoning at this point : It is not the “number” of senses which are available to an agent which is important – it is the information content imparted via those senses. In most human agents the data and information required for semantic understanding of a language are imparted mainly via the two senses of hearing and sight – thus in humans these two senses are much more critical in learning semantics than the other 3 senses. An agent which possesses neither hearing nor sight must try to acquire almost all of the external data and information about a language via the sense of touch (the senses of taste and smell would not be very efficient conduits for most semantically useful information transfer). In other words, most of the agent's learning about language would be via braille. This would indeed be a massive problem for the agent - but it STILL would not necessarily mean that the agent would have NO semantic understanding, which is the point of the CR argument.
No, I don’t see the parallel. Why does having only the sense of hearing necessarily limit an agent to “one coordinate space”? Or is this a bad metaphor?
I am not suggesting that Tim will not have problems learning. Of course he will. He needs to learn everything about the outside world via his sense of hearing alone. Of course this will be a problem. But your analogy with Helen Keller is poor – as I have stated already arguably the two most important senses for human language learning are sight and hearing, both of which Helen lacked, and one of which Tim has. Thus I could argue that Tim’s problem will in fact be less severe than Helen’s.
But I have no interest in going off at a tangent just to satisfy your curiosity about Tim’s unusual predicament in your pet thought experiment. What relevance does any of this have to the subject of this thread, and what is the point you are trying to make? With respect I am tired of continually guessing your meanings.
The CR argument is not based on the problems that a severely disabled human agent will have in “learning about the world”. The CR argument is based on the premise that a machine “cannot in principle semantically understand a language”. If you can show the relevance of Tim’s predicament and your thought experiment to the subject of this thread then I’ll be happy to continue this line of reasoning.
MF
