Can e^x+x=5 be solved without graphing using algebraic methods?
  • Thread starter physicsdreams
    Algebra
4 replies · 2K views · last reply
physicsdreams
e^x+x=5
Lambert W-function?
I moved everything around and got: Ln(5-x)=5...
It doesn't really help.
I looked at wolframalpha, and it said I need the Lambert W-function (no clue what that is).
Can this equation be solved Without graphing it, only using algebraic methods?
Nope, can't be solved with algebraic methods. It's Lambert W or a numerical solution.
You might want to check your rearrangement of the original equation.
What is ln(e^x)?
physicsdreams said:
e^x+x=5
Lambert W-function?
What you want to do. IF you want to find exact solution then i think it is task of machines(wolfarmalpha) and too tough for me.
If you want to know the number of solutions this equations will have then. It is possible.
draw curve of e^x and 5-x.rough e^x curve is as a^x(a>0). and 5-x is straight line with slope -1. So these two curve will intersect each other at one point hence it will have one solution.
You can get the root of the equation with an iterative method for the desired accuracy. Rearrange the equation:
x=ln(5-x)
Choose an x0 <5, determine x1=ln(5-x0) as the next approximation. Substitute again, to get the next x and repeat the procedure: xk+1=ln(5-xk)
Starting with x=1, the following values are obtained: 1.386, 1.284, 1.312, 1.305, 1.307, 1.3064, 13066, 1.3066
ehild
