Can external forces change the momentum of an exploding system of particles?
  • Thread starter Thread starter HWGXX7
    System
The discussion revolves around the effects of internal and external forces on the momentum of a system of particles, particularly in the context of an explosion. Participants explore concepts related to work done on a system, the behavior of particles during explosions, and the implications of external forces on momentum changes.
  • One participant questions whether the inclusion of internal forces in calculating work is only relevant if the body is distorted.
  • Another participant suggests that internal forces must lead to distortion, using the example of water in a tube under pressure to illustrate the concept.
  • A third participant notes that during an explosion, while internal forces may be the same, the particles do not follow the same trajectory, raising questions about the nature of their motion.
  • One participant asserts that the total momentum of the particles after an explosion will equal the momentum of the body before the explosion, regardless of individual trajectories.
  • Another participant introduces the principle of work and energy, suggesting that external forces can change the momentum of an exploding body, especially if it is initially at rest or moving.
  • There is a discussion about the relationship between kinetic energy and work done on a system, with examples involving inflating a balloon and the behavior of a sealed box with a CO2 cartridge.
Participants express differing views on the role of internal and external forces in momentum changes, with no clear consensus on the implications of these forces during explosions. The discussion remains unresolved regarding the interpretation of how external forces interact with internal dynamics.
Participants reference various scenarios and principles, such as the behavior of incompressible fluids and the conservation of momentum, but do not reach a definitive conclusion on the complexities involved in the interactions of forces during explosions.
HWGXX7
Hey,
question about the work done onto a system of particles. I have to include the work of the internal force because the particles itself can undergo different displacements. I don't understand this very well..Is this only possible if the body is distorted ?
ty
Hey HWGXX7! :smile:
HWGXX7 said:
… question about the work done onto a system of particles. I have to include the work of the internal force because the particles itself can undergo different displacements. ..Is this only possible if the body is distorted ?
More or less.
Suppose you have water in a tube, and you press down on it to increase the pressure …
water is pretty nearly incompressible, so would you say that it was distorted?
But generally speaking, if the internal forces in a body change, there must be distortion, for example a beam that is under tension will bend, or will get shorter.
General case, it's very logically indeed that the body will be distorted. So an explosion for example is an extreme case where the body initially fall apart and each subparticle will undergo the same internal force. But why doesn't travel all the particle the same traject?
I suppose that de internal forces are the same 'during' the explosion...Perhaps too complex to explain in this fashion..
ty
all of the particles don't have the same trajectory, but the sum of their momentums (mass times velocity) will be the same as the momentum of the body before the explosion
here's something to think about
work = change in kinetic energy
so, if you take a balloon at 1 ATM and 273.15 K, with zero volume, and inflate it to 22.4 liters, you've inserted 6*10^23 molecules into it. each molecule has a velocity and mass, so it has kinetic energy
Ke = .5*mv^2
assume all particles have the same m and v
sum of Ke = 6*10^23*.5*m*v^2
so when you inflate a balloon, you do work on it (since the Ke of the system has changed)
now- take a hermetically sealed rigid box, and put a CO2 cartridge in it, open the cartridge, and observe the pressure change in the box.
internal work
If the body was first in rest, the momentum was zero. After the explosion the sum = 0. So the the 'exploding object' will first rise in the sky, because some particle must have momentum towards earth.
But what if I can exert external force to counteract the internal forces, which creates the explosion.
Prinicple of work and energy states: that the change in kinetic energy equals the sum of work done by external forces and interal forces. So zero in this case, logic.
Momentum states that external work done on een object will change it's momentum. So an exploding body at rest/constant velocity doesn't change momentum (as you stated) .
But if I push the exploding (moving) body I do work on it so I change the momentum of the total body (now sum of particles).
Is this somehow a correct interpretation?
ty
  • · Replies 52 ·
  • · Replies 33 ·
24K
