Can Force Change Mass w/ Constant Velocity?
9 replies · 2K views
hackhard
can a resultant external force on a body change its mass but keep velocity of its centre of mass constant ? Is it practically possible -
##\vec{F}_{ext}=\vec{v}_{com}\frac{\mathrm{d} M}{\mathrm{d} t}##
where F is nonzero
If the mass is increasing by picking up stuff of different velocity, a force is required to keep velocity constant.
no body isn't picking up things. mass increases due to relativistic speed
Then you would be wise to rewrite the equation since an object's [invariant] mass does not increase due to relativistic speed.
Dale said:
Relativistic mass is a deprecated concept.
Regardless of that, even "relativistic mass" doesn't increase when velocity is constant.
A resultant external force and constant velocity of the center of mass without mass exchange? I'm afraid that's impossible.
i just needed to know that
where F is nonzero
If the net force on a body is nonzero, it must accelerate, therefore the velocity of its center of mass will not be constant if a net force is present.
It is possible to have a pair of opposing forces acting on different parts of a distributed body (which is not a single particle). If this pair of forces is doing net work on the body, the body will gain energy without gaining momentum, which implies that both its relativistic and invariant mass of the body will increase. Note that the energy needs to be stored somewhere, for instance by heating the body (which is due to internal vibrations of its molecules). Usually there is some limit on how much energy a realistic body can absorb in this manner - for instance, if you imagine that the pair of forces is turning a wheel agains some brake drums, the wheel and brakes will heat up, and eventually they'll fail.
