Can I Build a Homebrew Analog Computer Using Op Amps?
Building a homebrew analog computer using op amps is feasible, with a focus on creating a +/- 10V system to solve 2nd order differential equations and simple algebra problems. The discussion highlights the consideration of using two op amps for a summer followed by an integrator versus a summing junction on the integrator's input, noting that modularity may offer more flexibility. The TL084 op amp is preferred over the 741 due to its lower error rates, higher bandwidth, and improved input impedance, which enhances performance. Participants emphasize the importance of detailed schematics, which are scarce, and the need for experimentation with partial designs. Overall, the conversation revolves around optimizing design choices for effective analog computing.
mikejp56
Hi All,
This is a great forum for both newbies and advanced techies alike. I am a senior level tech and I have rediscovered analog computers. I would like to build a homebrew analog computer with op amps, obviously. I have done extensive research and found that detailed schematics are in rather short supply. I have come up with a few partial schematics that I am going to try to cobble together, and see how it performs. I will be building a +/- 10V system. I want to be able to solve 2nd order differential equations, and have my young nephews use it to solve simple algebra problems.
However I have a few questions:
1) Is there any advantage to using 2 op amps, one to do a summer function followed by an integrator op amp; as opposed to using a summing junction on the input of the integrator op amp, thereby saving 1 op amp?
2) I have available both 741s and TL084s. Any preference?
Thanks for any feedback that comes my way!
Regards,
Mike
I think you want to keep things modular at the smallest level, so separating the summer from the integrator makes for more possible interconnections. But I don't know that there's any technical reason to not combine the functions if you will always be using them together.
IIRC TL084s have less error on the input, higher bandwidth, and much higher input impedance which would improve fanout. Compare the specs and see...
Hi Schip666!,
Thanks for the prompt response. I will probably go with the TL084s. At about .50 each I can spliurge and separate summing junctions from integrators!
mikejp56
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 130 ·
12K
