Can I use a Fortran module for subroutines?
  • Topic: Fortran
  • Thread starter sketos
    Fortran module
16 replies · 7K views · last reply
sketos
Hello,
I want to create one file test.f95 where i can keep all my subroutines and use them whenever i create a new program
new.f95.
Is the modules the right way to do it?? because when i create a file let's say test.f95 with the module and one other with my main program (new.f95) when i compile test.f95 i get this :
/usr/lib/gcc/x86_64-linux-gnu/4.6/../../../x86_64-linux-gnu/crt1.o: In function `_start':
(.text+0x20): undefined reference to `main'
collect2: ld returned 1 exit status
And if i try to compile my main program (new.f95) i get this:
My programs are:
test.f95 ::
module module1
integer:: n
contains
recursive subroutine sub1(x)
integer,intent(inout):: x
integer:: y
y = 0
if (x < n) then
x = x + 1
y = x**2
print *, 'x = ', x,', y = ', y
call sub1(x)
end if
end subroutine sub1
end module module1
new.f95 ::
program main
use module1
integer:: x = 0
print *, 'Enter number of repeats'
read (*,*) n
call sub1(x)
end program main
What commands did you use to compile the programs?
Code:
gfortran new.f95 test.f95
works for me. Or if you want to compile the subroutines separately,
Code:
gfortran -c test.f95
gfortran new.f95 test.o
Maybe the errors are because your IDE doesn't understand what you are doing. (Personally I tend to solve that problem by not using an IDE).
i compile it using : f95 test.f95 -o test --> ./test
f95 new.f95 -o new -->./newThis doesn't work?
It doesn't work, because you are not compiling whole project, only part of it. Compiler has no way of knowing where the missing procedures are - you have to tell it explicitly where they are. Either by giving a list of Fortran sources in the command line, or by giving list of sources to compile and objects containing already compiled sources in the "link ready" format.
Yes.
It is also possible to use the make utility, then you need to put the information about files in the makefile - but IMHO for small, two file projects it doesn't make sense.
One extra comment on that: when you compile test.f95, you will create a "module interface file" called module1.mod. When the compiler reads the "use module1" statement in main.f95, it will automatically read module1.mod, or produce an error message if it can't find it. But the .mod file only contains information about the argument lists of the subroutines in the module, so the compiler can check you are calling them correctly. It doesn't contain the compiled code. You also have to tell the compiler to read test.o.
Note, if you have several modules, it is simpler to have the module name the same as the source file name, so the code for "module1" is in module1.f95, and compiling it creates module1.mod and module1.o.
Also, the Fortran 95 standard doesn't say how the module interface information should be stored, and some Fortran systems do store the module interface definition and the compiled code in the same file. But gfortan doesn't do that.
This doesn't work because 'test' does not contain a main program.
This doesn't work because, although 'new' does contain a main program, it does not contain the subroutine 'sub1'.
If you use the command:
f95 new.f95 test.f95 -o new
this should compile both source files, and link (combine) the output into 'new' which should be a complete executable program that you can run via the commad './new'.
Or, if you want to do the compiling and linking separately for some reason, you can do this:
f95 new.f95 -o new.o (creates a file 'new.o' which contains the compiled main program)
f95 test.f95 -o test.o (creates a file 'test.o' which contains the compiled module with the subroutine)
f95 new.o test.o -o new (links the two '.o' files and places the result in the executable 'new')
Thank you all guys.
I have one last question:
When i compile my main program with the module (which contains one function and 2 subroutines) i get the following error:
/tmp/ccToz1RS.o: In function `__statistictests_MOD_kstwo':
StatiTests.f95:(.text+0x208): undefined reference to `probks_'
are you guys familiar with what that means?? (my function name in probks and the module name is statistictests)
Without seeing the code, and exactly what you did to compile it, we are just guessing.
'ld' is the "linker" utility that f95 (and most other compilers on Unix-like systems) uses to link compiled modules together into an executable program. The error message means that your program wants to use something named 'probks_', and 'ld' can't find it. It's probably a subroutine or function named 'probks' (with the compiler adding the '_' internally).
I can offer two guesses: (1) You've simply misspelled the name of one of your own subroutines when you call it. (2) Your program uses a subroutine or function named 'probks' from a third-party library, and you didn't specify the library when you tried to compile the program.
If it's (2), how you specify the library in the compilation command depends on how and where it's installed on your system.
MY FILE ( StatiTests.f95) WHICH CONTAINS THE MODULE:
module StatisticTests
implicit none
contains
SUBROUTINE kstwo(data1,n1,data2,n2,d,prob)
INTEGER n1,n2
REAL d,prob,data1(n1),data2(n2)
!CU USES probks,sort
INTEGER j1,j2
REAL d1,d2,dt,en1,en2,en,fn1,fn2,probks
call sort(n1,data1)
call sort(n2,data2)
en1=n1
en2=n2
j1=1
j2=1
fn1=0.
fn2=0.
d=0.
1 if(j1.le.n1.and.j2.le.n2)then
d1=data1(j1)
d2=data2(j2)
if(d1.le.d2)then
fn1=j1/en1
j1=j1+1
endif
if(d2.le.d1)then
fn2=j2/en2
j2=j2+1
endif
dt=abs(fn2-fn1)
if(dt.gt.d)d=dt
goto 1
endif
en=sqrt(en1*en2/(en1+en2))
prob=probks((en+0.12+0.11/en)*d)
return
END
FUNCTION probks(alam)
REAL probks,alam,EPS1,EPS2
PARAMETER (EPS1=0.001, EPS2=1.e-8)
INTEGER j
REAL a2,fac,term,termbf
a2=-2.*alam**2
fac=2.
probks=0.
termbf=0.
do 11 j=1,100
term=fac*exp(a2*j**2)
probks=probks+term
if(abs(term).le.EPS1*termbf.or.abs(term).le.EPS2*probks)return
fac=-fac
termbf=abs(term)
11 continue
probks=1.
return
END SUBROUTINE sort(n,arr)
INTEGER n,M,NSTACK
REAL arr(n)
PARAMETER (M=7,NSTACK=50)
INTEGER i,ir,j,jstack,k,l,istack(NSTACK)
REAL a,temp
jstack=0
l=1
ir=n
1 if(ir-l.lt.M)then
do 12 j=l+1,ir
a=arr(j)
do 11 i=j-1,1,-1
if(arr(i).le.a)goto 2
arr(i+1)=arr(i)
11 continue
i=0
2 arr(i+1)=a
12 continue
if(jstack.eq.0)return
ir=istack(jstack)
l=istack(jstack-1)
jstack=jstack-2
else
k=(l+ir)/2
temp=arr(k)
arr(k)=arr(l+1)
arr(l+1)=temp
if(arr(l+1).gt.arr(ir))then
temp=arr(l+1)
arr(l+1)=arr(ir)
arr(ir)=temp
endif
if(arr(l).gt.arr(ir))then
temp=arr(l)
arr(l)=arr(ir)
arr(ir)=temp
endif
if(arr(l+1).gt.arr(l))then
temp=arr(l+1)
arr(l+1)=arr(l)
arr(l)=temp
endif
i=l+1
j=ir
a=arr(l)
3 continue
i=i+1
if(arr(i).lt.a)goto 3
4 continue
j=j-1
if(arr(j).gt.a)goto 4
if(j.lt.i)goto 5
temp=arr(i)
arr(i)=arr(j)
arr(j)=temp
goto 3
5 arr(l)=arr(j)
arr(j)=a
jstack=jstack+2
if(jstack.gt.NSTACK)pause
if(ir-i+1.ge.j-l)then
istack(jstack)=ir
istack(jstack-1)=i
ir=j-1
else
istack(jstack)=j-1
istack(jstack-1)=l
l=i
endif
endif
goto 1
ENDend module StatisticTests
AND MY MAIN PROGRAM:
program main
use StatisticTests
implicit none
integer i,n1,n2,n3
real pi,HI,Mfof,RA,DE,Vcdm,CDz
parameter(pi=3.1415,n1=3071,n2=1032,n3=2005)
real Z_obs1(n1),Z_obs2(n2),Z_obs3(n3)
real d12,d23,d31,prob12,prob23,prob31
open(unit=1,file="halo_cone_mock_lcdmw5_c2592_n1024.dat",status="old")
open(unit=2,file="halo_cone_mock_rpcdmw5_c2592_n1024.dat",status="old")
!n1=3071 !# of data-points for the ΛCDM
!n2=1032 !# of data-points for the RPCDMdo i=1,n1
read(1,*) HI,Mfof,Z_obs1(i),RA,DE,Vcdm,CDz !Read data of ΛCDM
end do
do i=1,n2
read(2,*) HI,Mfof,Z_obs2(i),RA,DE,Vcdm,CDz !Read data of RPCDM
end do
call kstwo(Z_obs1,n1,Z_obs2,n2,d12,prob12)
print*,"The KS two-sample test fot the LCDM-RPCDM"
print*,
print*,d12,prob12
end program
FOR THE COMPLILE : f95 main.f95 StatiTests.f95 -o new
sorry for the long post :)
Suggestion for the OP: When posting source code, please use the
Code:
 tags around the source statements.  The [CODE] tags help preserve the formatting of the source file, which is lost if it is inserted directly into the Reply Box.
I don't understand this yet.
If you remove the use of modules, the error message goes away.
But this minimal example compiles and runs OK:
Code:
program test
use mymod
call sub(x)
print *,x
end
Code:
module mymod
contains
subroutine sub(y)
x = 10
y = func(x)
end
function func(x)
func = 42 + x
end
end module mymod
One way to solve the mystery would be to add one thing at a time to the working example until it stop working, and then figure out why.
I've never used modules, but can you use 'implicit none' at the beginning of a module? I've always used it at the beginning of each subroutine or function.
I never used IMPLICIT NONE that way either, but that's not the problem.
It seems like the compiler thinks you have declared probks twice: once by writing the actual function, and again in subroutine kstwo when you say
Code:
If you change that line to
Code:
it compiles and links OK.
You can make my trivial example fail the same way, without IMPLICIT NONE. This fails:
Code:
module mymod
contains
subroutine sub(y)
real x, y, func
x = 10
y = func(x)
end
function func(x)
real func, x
func = 42 + x
end
end module mymod
but this works:
Code:
subroutine sub(y)
real x, y
I don't understand this. IMO either this is a very obscure feature of Fortran 95, or else it's a compiler bug. But at least we now know what to do about it!
Note, in F95 you can write "overloaded functions" similar to C++, where you have several functions with the same name and the compiler calls the correct one based on the type of the parameters passed to it. Maybe the "failed" version is somehow declaring two different functions with the sane name, but of course the link editor can only find one so it gives an error about the other one. But the "proper" way to use overloaded functions is write your own "interface" block between the "module" and "contains" statements, not let it happen by default. :confused:
