Can I Use Graphics Programs to Visualize Coordinates Inside a Ball?
  • Level: Undergrad
  • Thread starter Thread starter bogie
    Ball Coordinates
10 replies · 3K views
bogie
A ball can be defined as the inside of a sphere. It is made up of all points inside the sphere. Is there a customary way to describe the location of points in a ball, i.e. a coordinate system to define each point?
Is there a graphics program that can be used that let's you input the coordinates and visualize the defined points graphically?
Mathematics news on Phys.org
The equation of a sphere, having the radius R, and center (a, b, c) is:
[tex](x - a) ^ 2 + (y - b) ^ 2 + (z - c) ^ 2 = R ^ 2[/tex]
Now, a ball is a collection of the points whose distances from the center are less than or equal to R, so, the ball has the equation:
[tex](x - a) ^ 2 + (y - b) ^ 2 + (z - c) ^ 2 \leq R ^ 2[/tex]
I found this graphic: http://mathworld.wolfram.com/SphericalCoordinates.html
It is for defining points on a sphere, but I can see how the same coordinate system would be used to define the location of points in the ball.
Are your x, y and z the same as the x axis, y-axis and z axis in the graphic?
How do you’re a, b and c relate to the graphic?
Instead of having the center at (0, 0, 0), my sphere has its center at (a, b, c), you can look at the attachment below. Srry, if my drawing is just so bad... :frown:
The red little dot is the center having the co-ordinate (a, b, c).
The sphere is green.
And R is its radius.
Is it clearer now? :)
Yes. Your drawing is very good.
Using your drawing can you give me an example of how your formulas work, replacing the xyz and abc with numbers that relate to the drawing? Or do your formulas represent a general definition of a sphere and are not intended to describe a specific point on or in the sphere.
If want to try a simple programming environment, you might try writing a simple program using http://vpython.org/ and the formulas above to visualize these points in 3D.
If you don't want to write a program [which would be very instructive for you], you can try http://www.gnuplot.info/ .
Some useful interactive visualization, try this flash-based tutorial on spherical coordinates
http://mathdl.maa.org/mathDL/3/?pa=content&sa=viewDocument&nodeId=614
Thank you for the helpful links.
I am over 60 :) and was writing programs in basic in the seventies. I once spent a few weeks writing an accounting general ledger program. It worked great but then Lotus came out with 123 and I programmed the same procedures in Lotus in one day. I am afraid that my programming career ended there. I have dabbled in visual basic but my skills never got fully developed.
This link is beautiful. It gives me the tool I need to show the change in location in the ball with each change in rho, and each change in rho can be determined by the change in r if it is given that the length of rho varies with changes in r.
I was hoping to input a series of points and watch how those points move as I change r under the rule that a % increase in r will translate to the same % increase in each rho for each point (I refer to it as proportional expansion).
